* 串口1 初始化
void USART1_Initial(void)
USART_InitTypeDef USART_InitStruct;
// 设置复用到串口的IO口 PA10 PA11
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //USART1 TX
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
GPIO_Init(GPIOA, &GPIO_InitStructure); //A端口
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART1 RX
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //复用开漏输入
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);//
USART_DeInit(USART1); //首先复位
/*!< This member configures the USART communication baud rate.
The baud rate is computed using the following formula:
- IntegerDivider = ((PCLKx) / (16 * (USART_InitStruct->USART_BaudRate)))
- FractionalDivider = ((IntegerDivider - ((u32) IntegerDivider)) * 16) + 0.5 */
USART_InitStruct.USART_BaudRate=2400;
USART_InitStruct.USART_WordLength=USART_WordLength_8b;
USART_InitStruct.USART_StopBits=USART_StopBits_1;
USART_InitStruct.USART_Parity=USART_Parity_No;
USART_InitStruct.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
USART_InitStruct.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
USART_Init(USART1, &USART_InitStruct);
USART_ITConfig(USART1,USART_IT_RXNE,ENABLE); //USART1 接收中断使能
USART_Cmd(USART1,ENABLE); // USART1 模块使能
void USART1_IRQHandler(void)
ITStatus ItState=RESET;
ItState=USART_GetITStatus(USART1,USART_IT_RXNE);
if(ItState==SET)
ReceivedData=USART_ReceiveData(USART1);// 发送收到的数据
ReceiveFlag=1;
//USART_SendData(USART1,ReceivedData);// 注释掉,放到主函数中异步发送试试
USART_ClearITPendingBit(USART1,USART_IT_RXNE); // 清除标志位
使用USART_SendData()函数非连续发送单个字符是没有问题的;当连续发送字符时(两个字符间没有延时),就会发现发送缓冲区有溢出现象。若发送的数据量很小时,此时串口发送的只是最后一个字符,当发送数据量大时,就会导致发送的数据莫名其妙的丢失。
如:
1 2 | for(TxCounter = 0;TxCounter RxCounter; TxCounter++) USART_SendData(USART1, RxBuffer[TxCounter]); |
