以下是详细程序:
/*****Program Author : ZhengWen(ClimberWin) *****/
/*****E_mail :cooldianzi@163.com *****/
/*****File Function : IR Soft Recode(SAA3010) *****/
/*****Compile Date : 2009/2/4 *****/
/*****Edition Info : V1.0 *****/
/*****Amend Date : *****/
/************红外软件解码,遥控器型号,SAA3310芯片************/
/***********************2009.2.4******************************/
/***********可以红外解码LCD显示*************/
#include
#include "intrins.h "
#include "SAA3010_Recode.h"
#include "LCD12864.H"
#include
#include
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
sbit speaker=P2^1;
uchar LCD_IR_da
void Delay1ms(unsigned int count);
void Key_Beep(void);
void Delay_Beep(unsigned int count1);
void init_rs232(void);
/***************************1秒延时子程序start***************************/
unsigned int i,j;
for(i=0;i
/***************************1秒延时子程序end***************************/
/*****************按键声音********************/
void Key_Beep(void)
{ uchar i;
for (i=0;i<250;i++)
{ speaker=1;
Delay_Beep(30);
speaker=0;
Delay_Beep(30);
speaker=1;
/***************************蜂鸣器延时子程序start**********************/
void Delay_Beep(unsigned int count)
unsigned int i,j;
for(i=0;i
/***************************蜂鸣器延时子程序end************************/
/* 串口通信初始化设置 */
AUXR=74; //设置波特率是普通51的12倍 ,允许AD中断
SCON=0x50;
PCON=0x00;
TH1=0xFA; //波特率 115200 22.1184MHZ 时候(F4 4800 FA 9600 FDH 9600)*12
TL1=0XFA;
TMOD=0X20;
TR1=1;
void main(void)
uchar key_co
uchar key_co
uchar key_co
Delay1ms(1000);
init_rs232();
TI=1;
printf("STC12C5410AD学习板 红外遥控解码\n");
printf("ClimberWin 2009.2.4\n\n");
Delay1ms(5000);
LCD_INIT();
Delay1ms(1000);
LCD_LOCAL(1,1,"STC 单片机学习板");
LCD_LOCAL(2,1,"MCU:STC12C5410AD");
LCD_LOCAL(4,1,"Date:2009.2.4 ");
LCD_LOCAL(3,1,"By ClimberWin ");
Delay1ms(50000);
LCD_LOCAL(1,1,"红外遥控测试界面");
LCD_LOCAL(2,1,"遥控芯片:SAA3010");
LCD_LOCAL(3,1,"测试结果: ");
LCD_LOCAL(4,1," ");
printf("红外遥控测试界面\n");
//Delay100us(8); // 实为760uS
Key_Beep();
IR_Input = 1;//先把信号线拉高,等待接收红外信号
while(1)
LCD_IR_da
LCD_IR_da
LCD_IR_da
if(!IR_Input) SAA3010_Recode();
if(SAA3010_CO
{Key_Beep();
SBUF=SAA3010_CO
key_co
key_co
key_co
LCD_IR_da
LCD_IR_da
LCD_IR_da
LCD_LOCAL(4,1,LCD_IR_da
SAA3010_CO
SAA3010_CO
SAA3010_CO
SAA3010_CO
else
{SAA3010_CO
LCD12864.H 如下:
/*****File Function : LCD12864 Display Module *****/
/*****Compile Date : 2009/1/28 *****/
#ifndef __LCD12864__
#define __LCD12864__
#include
sbit LCD_CS = P1^7;//片选 高电平有效 单片LCD使用时可固定高电平rs
sbit LCD_SID = P1^6;//数据 r/w
sbit LCD_SCLK = P1^5;//时钟 e
/********************LCD12864**************************/
void LCD_SEND(uchar date);
void LCD_SCOM(bit st,uchar date);
void LCD_DELAY(void);
void LCD_INIT(void);
void LCD_write(uchar *p);
void LCD_LOCAL(uchar x,uchar y,uchar *p);
void LCD_cblank(uchar x,uchar y);
void LCD_count(long s,uchar x1,uchar y1,uchar x,uchar y,uchar *p);
void DELAYLCD(uchar t);
/****************************lcd12864************************************/
while(--t);
uchar i;
LCD_SCLK=0;
for(i=0;i<8;i++)
LCD_SID=date&0x80;
LCD_SCLK=1;
LCD_SCLK=0;
date<<=1;
uchar st_temp,hdate,ldate;
if(st)
st_temp=0xfa;
else st_temp=0xf8;
hdate=date&0xf0;
ldate=date&0x0f;
ldate <<= 4;
LCD_CS = 1;
LCD_SEND(st_temp);
LCD_SEND(hdate);
LCD_SEND(ldate);
LCD_CS = 0;
DELAYLCD(38);
{ uchar s;
s=10;
while(--s)
DELAYLCD(250);
void LCD_INIT(void)
LCD_SCOM(0,0x30);
LCD_DELAY();
LCD_SCOM(0,0x0c);
LCD_DELAY();
LCD_SCOM(0,0x01); //清屏,将DDRAM的地址计数器归零
LCD_DELAY();
while(*p)
LCD_SCOM(1,*p);
p++;
void LCD_LOCAL(uchar x,uchar y,uchar *p) //lcd string (x,y) write!
switch (x)
case 1:LCD_SCOM(0,0x7f+y); LCD_write(p);break;
case 2:LCD_SCOM(0,0x8f+y); LCD_write(p);break;
case 3:LCD_SCOM(0,0x87+y); LCD_write(p);break;
case 4:LCD_SCOM(0,0x97+y); LCD_write(p);break;
default :LCD_SCOM(0,0x7f+y); LCD_write(p);
switch (x)
case 1:LCD_SCOM(0,0x7f+y); LCD_SCOM(0,0x0d);break;
case 2:LCD_SCOM(0,0x8f+y); LCD_SCOM(0,0x0d);break;
case 3:LCD_SCOM(0,0x87+y); LCD_SCOM(0,0x0d);break;
case 4:LCD_SCOM(0,0x97+y); LCD_SCOM(0,0x0d);break;
default :LCD_SCOM(0,0x7f+y); LCD_SCOM(0,0x0d);
#endif
SAA3010_Rncode.H 如下:
/*****File Function : SAA3010 IR_Input soft recode *****/
/***************对红外遥控器SAA3010软件解码*******************/
#ifndef __SAA3010_Rncode__
#define __SAA3010_Rncode__
#include
sbit IR_Input=P3^4;
uchar SAA3010_CO
void SAA3010_Recode(void);
void Delay100us(uchar i);
/*************SAA3010解码程序**************/
unsigned char i, j;
bit FBIT;
// IR_Input 由高变低,跳过第一次采样
for (i=0; i<4; i++)
SAA3010_CO
曼彻斯特码:
输入二元码 Manchester码
0 01
1 10
// 设为第二次采样,采样时间间隔800uS
Delay100us(8);
if (!IR_Input)
// 因为SAA3010的起始位为1
SAA3010_CO
SAA3010_CO
// 起始第二位一次采样
Delay100us(8);
if (IR_Input)
{ // 采样是1
SAA3010_CO
FBIT = 1;
else
{ // 采样是0
FBIT = 0;
if (FBIT)
{ // 若第一次采样是1
while (IR_Input);
else
while (!IR_Input);
// 二次采样
Delay100us(8);
// 采样控制位
// 一次采样
Delay100us(8);
if (IR_Input)
SAA3010_CO
FBIT = 1;
else
FBIT = 0;
if (FBIT)
while (IR_Input);
else
while (!IR_Input); // 等待IR_Input上升
// 二次采样
Delay100us(8);
// 收集系统码(5位)
for (j=0; j<5; j++)
// 一次采样
Delay100us(8);
if (IR_Input)
SAA3010_CO
FBIT = 1;
else
FBIT = 0;
if (FBIT)
while (IR_Input);
else
while (!IR_Input);
// 二次采样
Delay100us(8);
SAA3010_CO
// 收集数据码(6位)
for (j=0; j<6; j++)
// 一次采样
Delay100us(8);
if (IR_Input)
SAA3010_CO
FBIT = 1;
else
FBIT = 0;
if (FBIT)
while (IR_Input);
else
while (!IR_Input);
// 二次采样
Delay100us(8);
SAA3010_CO
else
{ // 是抖动
for (i=0; i<4; i++)
SAA3010_CO
return;
SAA3010_CO
/************760us延时程序********************/
uchar j;
while(i<50)//50
for(j=0;j<50;j++)
{ _nop_();}
i++;
#endif
