//标题:4乘4键盘的输入函数
// 函数描述: char gotkey(void)
// 从4*4小键盘输入数据,返回0~9,及其它数据.
//时间迟延函数
void delay (void)
unsigned char i,j;
for(i=0;i5;i++)
for(j=0;j255;j++);
//检查是否有按键按下
char keypad_scan()
char key,i;
p2=0xF0;
while(p2!=0XF0);
do{
for(i=0;i=3;i++)
{ p2=ksp;
if(p2!=ksp)
delay();
key=p2;
if(key!=ksp)
return(key);
}while(1);
//取得键值
char gotkey()
char temp,i;
temp=keypad_scan();
for(i=0;i=15;i++)
if(temp==key_code)
return(i);
//93c66驱动程序
unsigned char read_byte(int address)
{int i, command;
unsigned char temp;
CS=1;
command=(READ|address);
write_command(command);
for(i=0;i8;i++)
{SK=1;
SK=0;
temp=(temp1);
if(DO==1)
temp=(temp|0X01);
CS=0;
return(temp);
void write_enable()
{int command;
CS=1;
command=EWEN;
CS=0;
void write_disable()
{int command;
CS=1;
command=EWDS
CS=0;
void write_byte(int address,unsigned char write_date)
{int i,command;
write_enable();
CS=1;
command=(WRITE|address);
for(i=0;i8;i++)
{if(write_date0X80)}
DI=1;
elae
DI=0;
SK=1;
SK=0;
write_date=(write_data1);
check_busy();
write_disable();
void write_command(int command)
{int i;
command=(commandshiftbit);
for(i=0;i12;i++)
{if(command0X8000)
DI=1;
else
DI=0;
SK=1;
SK=0;
command=(command1);
void check_busy(void)
{CS=0;
CS=1;
while(DO==0);
//标题:ISD4004驱动法程序
//功能:语音选段播放
void delay(unsigned int time) //延迟n微秒
while(time!=0)
time-- ;
void delayms(unsigned int time) //延迟n毫秒
{ TMOD=0x01;
for(time;time>0;time--)
TH0=0xfc;
TL0=0x18;
TR0=1;
while(TF0!=1)
TF0=0;
TR0=0;
//ISD4004 spi串行发送子程序,16位数据
void spi_send(unsigned char isdx)
{ unsigned char isx_counter;
SS=0; //ss=0,打开spi通信端
SCLK=0;
for(isx_counter=0;isx_counter8;isx_counter++)
//先发低位再发高位,依次发送。
{ if ((isdx0x01)==1)
MOSI=1;
else
MOSI=0;
isdx=isdx>>1;
SCLK=1;
delay(2);
SCLK=0;
delay(2);
//发送stop指令
void isd_stop(void)
{ delay(10);
spi_send(0x30);
SS=1;
delayms(50);
//发送上电指令,并延迟50ms
void isd_pu(void)
{ delay(10);
SS=0;
spi_send(0x20);
SS=1;
delayms(50);
//发送掉电指令,并延迟50ms
void isd_pd(void)
{ delay(10);
spi_send(0x10);
SS=1;
delayms(50);
//发送分段语音setplay指令
void isd_setplay(unsigned char adl,unsigned char adh)
isd_pd();
delayms(1);
spi_send(adl);
delay(2);
spi_send(adh);
delay(2);
spi_send(0xe0);
SS=1;
spi_send(0xf0);
SS=1;
if(ISD_INT==0)
isd_stop();
isd_pd();
