下面先给个crc32的计算函数,这个函数计算的结果与STM32F单片机上硬件单元的计算结果相同。
- uint32_tcrc32(uint32_t*addr,intnum,uint32_tcrc)
- inti;
- for(;num>0;num--)
- crc=crc^(*addr++);
- for(i=0;i<32;i++)
- if(crc&0x80000000)
- crc=(crc<<1)^POLY;
- else
- crc<<=1;
- crc&=0xFFFFFFFF;
- return(crc);
在我写的文章《写给嵌入式程序员的循环冗余校验(CRC)算法入门引导》(/zixunimg/eepwimg/blog.csdn.net/liyuanbhu/article/details/7882789)中给了个利用查表法计算crc的程序。那个程序稍微修改一点就能计算CRC32。下面给出改动后的程序。
- //crc32.h
- #ifndefCRC32_H_INCLUDED
- #defineCRC32_H_INCLUDED
- #ifdef__cplusplus
- #if__cplusplus
- extern"C"{
- #endif
- #endif/*__cplusplus*/
- #include
- *TheCRCparameters.CurrentlyconfiguredforCRC32.
- *CRC32=X32+X26+X23+X22+X16+X12+X11+X10+X8+X7+X5+X4+X2+X1+X0
- #definePOLYNOMIAL0x04C11DB7
- #defineINITIAL_REMAINDER0xFFFFFFFF
- #defineFINAL_XOR_VALUE0x00000000
- *ThewidthoftheCRCcalculationandresult.
- *Modifythetypedefforan8or32-bitCRCstandard.
- typedefuint32_twidth_t;
- #defineWIDTH(8*sizeof(width_t))
- #defineTOPBIT(1<
- *InitializetheCRClookuptable.
- *ThistableisusedbycrcCompute()tomakeCRCcomputationfaster.
- voidcrcInit(void);
- *ComputetheCRCchecksumofabinarymessageblock.
- *@paramessage,用来计算的数据
- *@paranBytes,数据的长度
- *@noteThisfunctionexpectsthatcrcInit()hasbeencalled
- *firsttoinitializetheCRClookuptable.
- width_tcrcCompute(unsignedchar*message,unsignedintnBytes,width_tremainder);
- #ifdef__cplusplus
- #if__cplusplus
- #endif
- #endif//CRC32_H_INCLUDED
对应的C程序如下:
- #include"crc32.h"
- *Anarraycontainingthepre-computedintermediateresultforeach
- *possiblebyteofinput.Thisisusedtospeedupthecomputation.
- staticwidth_tcrcTable[256];
- voidcrcInit(void)
- width_tremainder;
- width_tdividend;
- intbit;
- /*Performbinarylongdivision,abitatatime.*/
- for(dividend=0;dividend<256;dividend++)
- /*Initializetheremainder.*/
- remainder=dividend<
- /*ShiftandXORwiththepolynomial.*/
- for(bit=0;bit<8;bit++)
- /*Trytodividethecurrentdatabit.*/
- if(remainder&TOPBIT)
- remainder=(remainder<<1)^POLYNOMIAL;
- else
- remainder=remainder<<1;
- /*Savetheresultinthetable.*/
- crcTable[dividend]=remainder;
- }/*crcInit()*/
- unsignedintoffset;
- unsignedcharbyte;
- //width_tremainder=INITIAL_REMAINDER;
- /*Dividethemessagebythepolynomial,abyteatatime.*/
- for(offset=0;offset
- byte=(remainder>>(WIDTH-8))^message[offset];
- remainder=crcTable[byte]^(remainder<<8);
- /*ThefinalremainderistheCRCresult.*/
- return(remainder^FINAL_XOR_VALUE);
- }/*crcCompute()*/
不过用这个程序直接计算得到的CRC值与STM32给出的并不相同。之所以会这样是因为字节序的原因。可以举个例子来说明这个问题。比如我们有一片内存区域要计算CRC值。这片内存区域的起始地址是0x1000,共有8个字节。用crcCompute()函数计算时是按照地址顺序依次传入各个字节。也就是先计算0x1000处的字节,再计算0x0001处的字节,以此类推最后计算0x1007地址处的字节。而STM32的硬件CRC单元是以32位的字为单位计算的。我们知道CRC实际上是个多项式的除法运算,而除法运算是从高位算起的。也就是相当于它是按照0x1003、0x1002、0x1001、0x1000这个顺序计算第一个字,然后按照0x1007、0x1006、0x1005、x1004的顺序计算第二个字。因此。我们要是预先将字节序调换一下得到结果就没有问题了。这就有了下面的改造。其中remainder传入0xffffffff。因为STM32中的CRC余数初始值为0xffffffff。
- uint32_tstm32crc32(uint32_t*message,unsignedintnWords,uint32_tremainder)
- unsignedcharbyte;
- unsignedchar*p=(unsignedchar*)message;
- byte=(remainder>>(WIDTH-8))^p[3];
- byte=(remainder>>(WIDTH-8))^p[2];
- byte=(remainder>>(WIDTH-8))^p[1];
- byte=(remainder>>(WIDTH-8))^p[0];
- p+=4;
- return(remainder);
- }/*crcCompute()*/
大家可以验证这个函数的计算结果与STM32上的结果完全一样。
写到这里本该就结束了,不过我要多说一句,之所以要这么麻烦的调换字节序,都是小端(littleendian)惹的祸。要是都采用大端格式就没这些麻烦的转换了。
