怎么老是出现idenfier "FILE is Undefined",问题出在哪啊?望指教,谢谢!
我程序代码配置如下:
#include "stm32f10x.h"
#include "stm32_eval.h"
#include
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
set to Yes) calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
int main(void)
SystemInit();
/* Enable GPIOA and USART1 clocks */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_USART1, ENABLE);
USART1_GPIO_Configuration();
USART1_Configuration();
printf("The is a example!" );
/*********************************配置USART1的GPIO口*************************************/
void USART1_GPIO_Configuration(void)
// Configure USART1_Tx as alternate function push-pull
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
// Configure USART1_Rx as input floating
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/************************************配置串口1参数***********************************/
void USART1_Configuration(void)
USART_InitTypeDef USART_InitStructure;
USART_InitStructure.USART_BaudRate =115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
USART_Cmd(USART1, ENABLE);
PUTCHAR_PROTOTYPE
/* Place your implementation of fputc here */
/* e.g. write a character to the USART */
USART_SendData(USART1, (uint8_t) ch);
/* Loop until the end of transmission */
while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
return ch;
因printf()之类的函数,使用了半主机模式。使用标准库会导致程序无法运行,以下是解决方法:
方法1.使用微库,因为使用微库的话,不会使用半主机模式.
方法2.仍然使用标准库,在主程序添加下面代码:
#pragma import(__use_no_semihosting)
_sys_exit(int x)
x = x;
struct __FILE
int handle;
/* Whatever you require here. If the only file you are using is */
/* standard output using printf() for debugging, no file handling */
/* is required. */
/* FILE is typedef’ d in stdio.h. */
FILE __stdout;
这个方法确实解决问题。
首先要加上这句:#include
然后加入以下代码:
///////使用标准printf的串口字节发送重定义///////////
//第一步:
#ifdef __GNUC__
#else
//第二步:
_sys_exit(int x)
x = x;
struct __FILE
int handle;
/* is required. */
FILE __stdout;
//第三步:
//默认使用COM1
* @briefRetargets the C library printf function to the USART.
* @paramNone
* @retval None
PUTCHAR_PROTOTYPE
while (USART_GetFlagStatus(USART_COM1, USART_FLAG_TC) == RESET)
USART_SendData(USART_COM1, (uint8_t) ch);
return ch;
