#ifndef _STM32F103_DS1302_H_
#define _STM32F103_DS1302_H_
//*****************DS1302控制命令*******************
#define RdSec 0x81
#define RdMin 0x83
#define RdHour 0x85
#define RdDate 0x87
#define RdMonth 0x89
#define RdWeek 0x8b
#define RdYear 0x8d
#define RdControl 0x8f
#define RdTrickleCharge 0x91
#define RdClockBurst 0xbf
#define WrSec 0x80
#define WrMin 0x82
#define WrHour 0x84
#define WrDate 0x86
#define WrMonth 0x88
#define WrWeek 0x8a
#define WrYear 0x8c
#define WrControl 0x8e
#define WrTrickleCharge 0x90
#define WrClockBurst 0xbe
//添加的信息
#define RdRamBurst 0xbf
//相对应的IO口配置
#define DS1302_PORT GPIOE
#define DS1302_SCK_PIN GPIO_Pin_9 //对应的IO口
#define DS1302_IO_PIN GPIO_Pin_10
#define DS1302_CE_PIN GPIO_Pin_11
#define DS1302_CLRSCK() (GPIO_ResetBits(GPIOE, GPIO_Pin_9)) //寄存器IO口操作状态
#define DS1302_SETSCK() (GPIO_SetBits(GPIOE, GPIO_Pin_9))
#define DS1302_CLRIO() (GPIO_ResetBits(GPIOE, GPIO_Pin_10) )
#define DS1302_SETIO() (GPIO_SetBits(GPIOE, GPIO_Pin_10) )
#define DS1302_CLRCE() (GPIO_ResetBits(GPIOE, GPIO_Pin_11))
#define DS1302_SETCE() (GPIO_SetBits(GPIOE, GPIO_Pin_11))
void DS1302_IO_OUT(void );
void DS1302_IO_IN( void);
//#define DS1302_IO_IN() DS1302_IO_IN() //操作输入输出状态
//#define DS1302_IO_OUT() DS1302_IO_OUT()
#define DS1302_READ_SDA() (GPIO_ReadInputDataBit(DS1302_PORT, DS1302_IO_PIN))
//定义时间结构体
//typedef struct
// unsigned char year;
// unsigned char month;
// unsigned char date;
// unsigned char week;
// unsigned char hour;
// unsigned char min;
// unsigned char sec;
//}TIME_TypeDef;
typedef struct
unsigned char sec;
unsigned char min;
unsigned char hour;
unsigned char week;
unsigned char date;
unsigned char year;
}TIME_TypeDef;
//内部函数
void DS1302_Write8bit(unsigned char code);
unsigned char DS1302_Read8bit(void);
//外部函数
extern void ds1302_init (void);
extern unsigned char DS1302_ReadByte(unsigned char con);
extern void DS1302_WriteByte(unsigned char con,unsigned char code);
extern void DS1302_WriteTime(TIME_TypeDef* time);
extern void DS1302_ReadTime(TIME_TypeDef* time);
void time_convert(TIME_TypeDef *time_get);
#endif
在ds1302.c文件中:
/********************************copyright ythuitong by wit_yuan**************************/
#include "bsp.h"
// 函数名 : ds1302_init
// 功能 : ds1302初始化部分
// 参数 : void
// 作者 : wit_yuan
// 时间 : 2014-08-08
void ds1302_init(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE );
GPIO_InitStructure.GPIO_Pin = (DS1302_SCK_PIN | DS1302_IO_PIN | DS1302_CE_PIN);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP ;
GPIO_Init(DS1302_PORT, &GPIO_InitStructure);
DS1302_WriteByte(WrControl,0x00); //关闭写保护,可以写入数据了
Delay_10us(10);
// if(DS1302_ReadByte(RdTrickleCharge) != 0xA6)
// Delay_10us(10);
// DS1302_WriteByte(WrTrickleCharge,0xA6);
// printf("进入\r\n");
Delay_10us(10);
DS1302_WriteByte(WrControl,0x80); //开启写保护,禁止写入数据
void DS1302_IO_OUT()
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOE, &GPIO_InitStructure);
void DS1302_IO_IN()
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
//DS1302写入8bit
unsigned char i;
DS1302_IO_OUT(); //输出模式
DS1302_CLRSCK(); //SCK = 0
for(i=0;i<8;i++)
Delay_10us(5);
if(code&0x01)
(DS1302_SETIO()); //I/0 = 1
else
(DS1302_CLRIO()); //I/0 = 0
Delay_10us(5);
DS1302_SETSCK(); //SCLK = 1
Delay_10us(5);
DS1302_CLRSCK(); //SCLK = 0
code = code >> 1;
//DS1302读取8bit的数据
unsigned char i,code;
unsigned char temp;
DS1302_IO_IN();
code = 0;
Delay_10us(5);
for(i=0;i<8;i++)
code = code >>1;
if(DS1302_READ_SDA())
code = code | 0x80;
Delay_10us(5);
Delay_10us(5);
temp = code /16;
code = code % 16;
code = code + temp * 10; //数据的相关转换
return code;
//读取DS1302指定的1Byte
unsigned char code;
DS1302_CLRCE(); //关闭DS1302 //CE = 0
Delay_10us(5);
Delay_10us(5);
DS1302_SETCE(); //使能DS1302 //CE = 1;
Delay_10us(5);
DS1302_Write8bit(con); //读取代码 //发送地址
code = DS1302_Read8bit(); //返回读取数字
//printf("code = %d\r\n" ,code );
Delay_10us(5);
Delay_10us(5);
return code;
//u8 DS1302_ReadRam(u8 addr)
// u8 tmp,res;
// tmp = addr;
// res = DS1302_ReadByte(tmp);
// return(res);
////连续读取DS1302所有数据
//void DS1302_ReadBurst(unsigned char *rstr)
// int i = 0;
// unsigned char code;
// DS1302_CLRCE(); //关闭DS1302 //CE = 0
// Delay_10us(5);
// DS1302_CLRSCK(); //SCLK = 0
// Delay_10us(5);
// DS1302_SETCE(); //使能DS1302 //CE = 1;
// Delay_10us(5);
// DS1302_Write8bit(RdRamBurst); //读取代码 //发送地址
// for(i = 0 ;i < 31 ; i++)
// rstr[i] = DS1302_ReadRam(2 * i + 1 + 0xc0); //返回读取数字
// //printf("code = %d\r\n" ,code );
// Delay_10us(5);
// DS1302_SETSCK(); //SCLK = 1
// Delay_10us(5);
// for(i = 0 ;i < 31 ; i ++)
// printf("rstr[%d] = %d\r\n",i,rstr[i]);
//写DS1302指定的1Byte
Delay_10us(5);
Delay_10us(5);
Delay_10us(5);
DS1302_Write8bit(con); //写控制命令 //发送地址
DS1302_Write8bit(code); //写入数据 //发送数据
Delay_10us(5);
DS1302_SETSCK();
Delay_10us(5);
//写入时间
DS1302_WriteByte(WrYear,time->year);
DS1302_WriteByte(WrMonth,time->month);
DS1302_WriteByte(WrDate,time->date);
DS1302_WriteByte(WrWeek,time->week);
DS1302_WriteByte(WrHour,time->hour);
DS1302_WriteByte(WrMin,time->min);
DS1302_WriteByte(WrSec,time->sec);
u8 tmp,res;
tmp = addr;
return(res);
typedef struct
unsigned char sec;
unsigned char min;
unsigned char hour;
unsigned char date;
unsigned char week;
unsigned char year;
}Time;
//连续读取DS1302所有数据
int i = 0;
unsigned char code;
Delay_10us(5);
Delay_10us(5);
Delay_10us(5);
for(i = 0 ;i < 7 ; i++)
rstr[i] = DS1302_Read8bit();
Delay_10us(5);
Delay_10us(5);
// for(i = 0 ;i < 7 ; i ++)
//printf("rstr[%d] = %d\r\n",i,rstr[i]);
//////////////测试而已/////////////////////////////////////////////////////
void readTimeTest()
Time myTime;
DS1302_ReadBurst((u8 *)&myTime);
//printf("time:%d-%d-%d %d:%d:%d\r\n",myTime.year, myTime.month, myTime.date,
// myTime.hour,myTime.min,myTime.sec);
Time myTime;
time->year = myTime.year;
time->month = myTime.month;
time->date = myTime.date;
time->hour = myTime.hour;
time->min = myTime.min;
time->sec = myTime.sec;
// printf("time:%d-%d-%d %d:%d:%d\r\n",myTime.year, myTime.month, myTime.date,
////读出时间
//void DS1302_ReadTime(TIME_TypeDef* time)
// u8 i = 0;
// u8 year_temp[3];
// u8 month_temp[3];
// u8 date_temp[3];
// u8 hour_temp[3];
// u8 min_temp[3];
// u8 sec_temp[3];
// u8 max;
// u8 min;
// for(i = 0 ; i < 3 ; i ++)
// year_temp[i] = DS1302_ReadByte(RdYear);
// month_temp[i] = DS1302_ReadByte(RdMonth);
// date_temp[i] = DS1302_ReadByte(RdDate);
// hour_temp[i] = DS1302_ReadByte(RdHour);
// min_temp[i] = DS1302_ReadByte(RdMin);
// sec_temp[i] = DS1302_ReadByte(RdSec);
// //年
// max = year_temp[0];
// min = year_temp[0];
// for(i = 1 ; i < 3 ; i ++)
// if(year_temp[i] > max)
// max = year_temp[i];
// if(year_temp[i] < min)
// min = year_temp[i];
// time->year = year_temp[0] + year_temp[1] + year_temp[2] - max - min;
// //月
// max = month_temp[0];
// min = month_temp[0];
// if(month_temp[i] > max)
// max = month_temp[i];
// if(month_temp[i] < min)
// min = month_temp[i];
// time->month = month_temp[0] + month_temp[1] + month_temp[2] - max - min;
// //日
// max = date_temp[0];
// min = date_temp[0];
// if(date_temp[i] > max)
// max = date_temp[i];
// if(date_temp[i] < min)
// min = date_temp[i];
// time->date = date_temp[0] + date_temp[1] + date_temp[2] - max - min;
// //时
// max = hour_temp[0];
// min = hour_temp[0];
// if(hour_temp[i] > max)
// max = hour_temp[i];
// if(hour_temp[i] < min)
// min = hour_temp[i];
// time->hour = hour_temp[0] + hour_temp[1] + hour_temp[2] - max - min;
// //分
// max = min_temp[0];
// min = min_temp[0];
// if(min_temp[i] > max)
// max = min_temp[i];
// if(min_temp[i] < min)
// min = min_temp[i];
// time->min = min_temp[0] + min_temp[1] + min_temp[2] - max - min;
// //秒
// max = sec_temp[0];
// min = sec_temp[0];
// if(sec_temp[i] > max)
// max = sec_temp[i];
// if(sec_temp[i] < min)
// min = sec_temp[i];
// time->sec = sec_temp[0] + sec_temp[1] + sec_temp[2] - max - min;
//// time->year = DS1302_ReadByte(RdYear);
//// time->month = DS1302_ReadByte(RdMonth);
//// time->date = DS1302_ReadByte(RdDate);
//// time->week = DS1302_ReadByte(RdWeek);
//// time->hour = DS1302_ReadByte(RdHour);
//// time->min = DS1302_ReadByte(RdMin);
//// time->sec = DS1302_ReadByte(RdSec);
//// year_temp = DS1302_ReadByte(RdYear);
//// year_month = DS1302_ReadByte(RdMonth);
//// year_date = DS1302_ReadByte(RdDate);
//// year_hour = DS1302_ReadByte(RdHour);
//// year_min = DS1302_ReadByte(RdMin);
//// year_sec = DS1302_ReadByte(RdSec);
//// printf("year = %d\r\n",time->year);
//// printf("month = %d\r\n",time->month);
//// printf("year = %d\r\n",time->date);
//// printf("year = %d\r\n",time->hour);
//// printf("year = %d\r\n",time->min);
//// printf("year = %d\r\n",time->sec);
//// printf("year_temp = %d\r\n",year_temp);
//// printf("year_month = %d\r\n",year_month);
//// printf("year_date = %d\r\n",year_date);
//// printf("year_hour = %d\r\n",year_hour);
//// printf("year_min = %d\r\n",year_min);
//// printf("year_sec = %d\r\n",year_sec);
//// if( (year_temp + year_month + year_date + year_hour + year_min + year_sec)
//// < ( time->year + time->month + ))
unsigned char time[20]="\0";
time[0] = 2; //2
time[1] = 0; //0
time[2] = time_get->year / 10 + 0; //1
time[3] = time_get->year % 10 + 0; //4
time[4] = -; //-
time[5] = time_get->month / 10 + 0; //0
time[6] = time_get->month % 10 + 0; //4
time[7] = -; //-
time[8] = time_get->date / 10 + 0; //1
time[9] = time_get->date % 10 + 0; //0
time[10] = ; //
time[11] = time_get->hour / 10 + 0; //1
time[12] = time_get->hour % 10 + 0; //4
time[13] = :; //:
time[14] = time_get->min / 10 + 0; //2
time[15] = time_get->min % 10 + 0; //1
time[16] = :; //:
time[17] = time_get->sec / 10 + 0; //3
time[18] = time_get->sec % 10 + 0; //0
time[19] = \0; //
// printf("time = %s\r\n",time);
/************************************end of file 2014-08-08*********************************/
