随着学习的深入,渐渐发现,编程时更多的工作是不断的配置寄存器,做着许多重复的工作。所以就感觉很有必要把经常使用的寄存器、配置结构罗列出来,以方便使用!!这是其中的一部分,其他的慢慢来
本页所包含的配置函数有:
void SysTick_Configuration(void);
void GPIO_Configuration(void);
void EXTI_Configuration(void);
void NVIC_Configuration(void);
void RCC_Configuration(void);
void IWDG_Configuration(void);
//同时需要配置的结构体变量
EXTI_InitTypeDef EXTI_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
*******//Cortex系统定时器(SysTick)*********************
//选择系统定时器(SysTick)的时钟源
SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);
SysTick_SetReload(72000);
SysTick_ITConfig(ENABLE);
*********///GPIO的配置程序***************************************
void GPIO_Configuration(void) void RCC_Configuration(void)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOB, &GPIO_InitStructure);
//中断线路初始化
EXTI_InitStructure.EXTI_Line = EXTI_Line9;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
EXTI_InitStructure.EXTI_Line = EXTI_Line13;
///嵌套中断向量NVIC**********************************
GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource9);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel=EXTI0_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;
NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
NVIC_Init(&NVIC_InitStructure);
//为EXTI_Line9使能并配置中断向量
//为EXTI_Line0使能并配置中断向量
NVIC_InitStructure.NVIC_IRQChannel=EXTI9_5_IRQChannel;
//为EXTI_Line13使能并配置中断向量
NVIC_InitStructure.NVIC_IRQChannel=EXTI15_10_IRQChannel;
