以前学习51的时候为了调试机械臂角度编写的程序,用在开发板上也比较方便,但是由于是普通的舵机,不是总线的,所以需要自己洞洞板焊一个供电带电路。
单片机源程序如下:
#include
#include
#define uchar unsigned char
#define uint unsigned int
sbit duoji0=P2^0; //PWM输出
sbit duoji1=P2^1;
sbit duoji2=P2^2;
sbit duoji3=P2^3;
sbit duoji4=P3^1;
sbit duoji5=P3^0;
#define GPIO_KEY P1
unsigned int k0;
unsigned int k1;
unsigned int k2;
unsigned int k4;
unsigned int k3;
unsigned int k5; //定义下降沿节点
uint dsip[8]={0};
uint j=0;
unsigned char code ASCII[15] = {'0','1','2','3','4','5','6','7','8','9','.','D',' '};
void delayms(uint xms)
uchar j;
uint i;
for(i=xms;i>0;i--)
for(j=112;j>0;j--);
void time0() interrupt 1
static uint ii0=0;
TH0=(65536-100)/256; //以20ms为一个周期,以0.1ms为一个脉冲宽度
TL0=(65536-100)%256;
ii0++;
if(ii0<=k0)
duoji0=1; //0号舵机pwm输出
else
duoji0=0;
if(ii0<=k1) //1号舵机pwm输出
duoji1=1;
else
duoji1=0;
if(ii0<=k2) //2号舵机pwm输出
duoji2=1;
else
duoji2=0;
if(ii0<=k3) //3号舵机pwm输出
duoji3=1;
else
duoji3=0;
if(ii0<=k4) //4号舵机pwm输出
duoji4=1;
else
duoji4=0;
if(ii0<=k5) //5号舵机pwm输出
duoji5=1;
else
duoji5=0;
if(ii0==200)
ii0=0;
void time0init()
TMOD=0x01;
TR0=1;
ET0=1;
EA=1;
char KeyDown()
uchar KeyValue=20;
uchar a=0;
GPIO_KEY=0x0f;
if(GPIO_KEY!=0x0f)//读取按键是否按下
delayms(10);//延时10ms进行消抖
if(GPIO_KEY!=0x0f)//再次检测键盘是否按下
//测试列
GPIO_KEY=0X0F;
switch(GPIO_KEY)
case(0X07): KeyValue=0;break;
case(0X0b): KeyValue=1;break;
case(0X0d): KeyValue=2;break;
case(0X0e): KeyValue=3;break;
//测试行
GPIO_KEY=0XF0;
switch(GPIO_KEY)
case(0X70): KeyValue=KeyValue;break;
case(0Xb0): KeyValue=KeyValue+4;break;
case(0Xd0): KeyValue=KeyValue+8;break;
case(0Xe0): KeyValue=KeyValue+12;break;
while((a<50)&&(GPIO_KEY!=0xf0)) //检测按键松手检测,当按键等于0xf时候跳出循环
delayms(100);
a++;
return KeyValue;
void count()
LcdWriteData(ASCII[0]);
LcdWriteData(ASCII[11]);
LcdWriteData(ASCII[k0/10]);
LcdWriteData(ASCII[k0%10]);
LcdWriteData(ASCII[12]);
LcdWriteData(ASCII[1]);
LcdWriteData(ASCII[k1/10]);
LcdWriteData(ASCII[k1%10]);
LcdWriteCom(0x80+0x40);
LcdWriteData(ASCII[2]);
LcdWriteData(ASCII[k2/10]);
LcdWriteData(ASCII[k2%10]);
LcdWriteData(ASCII[3]);
LcdWriteData(ASCII[k3/10]);
LcdWriteData(ASCII[k3%10]);
void main()
time0init();
k0=15;
k1=9;
k2=16;
k3=14;
k4=8;
k5=8;
LcdInit();
count();
while(1)
uchar KeyValue1=20;
KeyValue1=KeyDown();
if(KeyValue1==0&&k0<=20&&k0>=8) //0号舵机高电平时间增加
k0++;
if(k0==21)
k0=20;
KeyValue1=20;LcdWriteCom(0x01); count();
if(Ke
