单片机 > 单片机程序设计 > 详情
STC15F104W编码器两路可调PWM输出源程序
发布时间:2023-08-23 发布时间:
//没有用IAPIDLE功能,有没有高手指点一下利弊
#include
#include
typedef unsigned char BYTE;
typedef unsigned int WORD;
//#define uint unsigned int
//#define MAIN_Fosc 22118400L //定义主时钟
//#define MAIN_Fosc 12000000L //定义主时钟
#define MAIN_Fosc 11059200L //定义主时钟
//#define MAIN_Fosc 5529600L //定义主时钟
//#define MAIN_Fosc 24000000L //定义主时钟
//#define MAIN_Fosc 40000000L //定义主时钟
//#define ENABLE_IAP 0x80 //if SYSCLK<30MHz
//#define ENABLE_IAP 0x81 //if SYSCLK<24MHz
//#define ENABLE_IAP 0x82 //if SYSCLK<20MHz
#define ENABLE_IAP 0x83 //if SYSCLK<12MHz
//#define ENABLE_IAP 0x84 //if SYSCLK<6MHz
//#define ENABLE_IAP 0x85 //if SYSCLK<3MHz
//#define ENABLE_IAP 0x86 //if SYSCLK<2MHz
//#define ENABLE_IAP 0x87 //if SYSCLK<1MHz
#define CMD_IDLE 0 //空闲模式
#define CMD_READ 1 //IAP字节读命令
#define CMD_PROGRAM 2 //IAP字节编程命令
#define CMD_ERASE 3 //IAP扇区擦除命令
//测试地址
#define IAP_ADDRESS1 0X0000 //内部EEPROM地址
#define IAP_ADDRESS2 0X0200
/*初始定义*/
bit write = 0;
sbit VD=P3^3; //红色LED 0.50v=10v ;1.00=27v ;3.85=73v;
sbit CD=P3^4; //绿色LED
sbit ZS=P3^5; //指示LED转换 0 - 红色LED调整;1 - 绿色LED调整
sbit BA=P3^0; //编码器的a脚接P3.0
sbit BB=P3^1; //编码器的b脚接P3.1
sbit QH=P3^2; //编码器的按键接P3.2 电压调整或电流调整299=5.00V
BYTE v_temp,c_temp,XZ = 0,flag,a0,b0,c0;// 128 109 48 29 //48=0.96V;29=0.58V;
void InitTimer0() interrupt 1 // 0.5毫秒@11.0592MHz 频率 1000HZ
IE2 = 0x00; //关闭定时器2中断
AUXR = 0XE4; //关闭定时器2计数
TL0 = 0xCD; //设置定时初值 0.5毫秒@11.0592MHz
TH0 = 0xD4; //设置定时初值 0.5毫秒@11.0592MHz
VD = 1;
CD = 1;
flag = 1;
AUXR = 0xF4; //开启定时器2计数
IE2 = 0x04; //开启定时器2中断允许
void InitTimer2() interrupt 12 //2微秒@11.0592MHz 控制灯亮时间
flag++;
T2L = 0xD4; //设置定时初值 2微秒@11.0592MHz
T2H = 0xFF; //设置定时初值 2微秒@11.0592MHz
if(v_temp == flag) VD=0;
if(c_temp == flag) CD=0;
/*//关闭IAP
void IapIdle()
IAP_CONTR = 0; //关闭IAP功能
IAP_CMD = 0; //清除命令寄存器
IAP_TRIG = 0; //清除触发寄存器
IAP_ADDRH = 0x80; //将地址设置到非IAP区域
IAP_ADDRL = 0;
//从ISP/IAP/EEPROM区域读取一字节
BYTE IapReadByte(WORD addr)
BYTE dat; //数据缓冲区
IAP_CONTR = ENABLE_IAP; //使能IAP
IAP_CMD = CMD_READ; //设置IAP命令
IAP_ADDRL = addr; //设置IAP低地址
IAP_ADDRH = addr >> 8; //设置IAP高地址
IAP_TRIG = 0x5a; //写触发命令(0x5a)
IAP_TRIG = 0xa5; //写触发命令(0xa5)
_nop_(); //等待ISP/IAP/EEPROM操作完成
dat = IAP_DATA; //读ISP/IAP/EEPROM数据
//IapIdle(); //关闭IAP功能
return dat; //返回
//写一字节数据到ISP/IAP/EEPROM区域
void IapProgramByte(WORD addr, BYTE dat)
IAP_CMD = CMD_PROGRAM; //设置IAP命令
IAP_DATA = dat; //写ISP/IAP/EEPROM数据
//IapIdle();
//扇区擦除
void IapEraseSector(WORD addr)
IAP_CMD = CMD_ERASE; //设置IAP命令
//IapIdle();
/*void Timer0Init(void) //100微秒@24.000MHz 10KHZPWM
AUXR |= 0x80; //定时器时钟1T模式
TMOD &= 0xF0; //设置定时器模式
TL0 = 0xA0; //设置定时初值--100微秒@24.000MHz
TH0 = 0xF6; //设置定时初值--100微秒@24.000MHz
TF0 = 0; //清除TF0标志
TR0 = 1; //定时器0开始计时
void Timer2Init(void)//0.4微秒@24.000MHz
AUXR |= 0x04; //定时器时钟1T模式
T2L = 0xF6; //设置定时初值--0.4微秒@24.000MHz
T2H = 0xFF; //设置定时初值--0.4微秒@24.000MHz
AUXR |= 0x10; //定时器2开始计时
void bianmaqi(void)//捕捉EC11按下和旋转信息
unsigned char a, b, c;
a = BA; b = BB; c = QH;
if (a != a0) // BA changed
a0 = a;
if (b != b0) // BB changed
b0 = b;write = 1;
if ((a == b) && (XZ == 0) && (v_temp < 153)) {v_temp++;}//225 153
if ((a == b) && (XZ == 1) && (c_temp < 73)) {c_temp++;}//208 65
if ((a != b) && (XZ == 0) && (v_temp > 23)) {v_temp--;}//85 23
if ((a != b) && (XZ == 1) && (c_temp > 5)) {c_temp--;}//29 5
if (!c && c0)
if (XZ == 0 )
XZ = 1;
ZS = 1;
else if(XZ == 1)//切换
XZ = 0;
ZS = 0;
c0 = c;
void init()
AUXR = 0XE4; //设置定时器0和2为1T模式
TMOD = 0x00;
TL0 = 0xCD; //设置定时初值 0.5毫秒@11.0592MHz 0xA0;--100微秒@24.000MHz
TH0 = 0xD4; //设置定时初值 0.5毫秒@11.0592MHz 0xFF;--0.4微秒@24.000MHz
T2L = 0xD4; //设置定时初值 2微秒@11.0592MHz 0xF6;--0.4
stm32f4 - 时钟树分析配置
