#include
#include
#include
#include
#define uchar unsigned char
#define uint unsigned int
/* CONFIG1 */
#pragma config FOSC = XT /* Oscillator Selection bits (XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN) */
#pragma config WDTE = OFF /* Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register) */
#pragma config PWRTE = OFF /* Power-up Timer Enable bit (PWRT disabled) */
#pragma config MCLRE =ON /* RE3/MCLR pin function select bit (RE3/MCLR pin function is digital input, MCLR internally tied to VDD) */
#pragma config CP = OFF /* Code Protection bit (Program memory code protection is disabled) */
#pragma config CPD = OFF /* Data Code Protection bit (Data memory code protection is disabled) */
#pragma config BOREN = OFF /* Brown Out Reset Selection bits (BOR disabled) */
#pragma config IESO = OFF /* Internal External Switchover bit (Internal/External Switchover mode is disabled) */
#pragma config FCMEN = OFF /* Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is disabled) */
#pragma config LVP = OFF /* Low Voltage Programming Enable bit (RB3 pin has digital I/O, HV on MCLR must be used for programming) */
/* CONFIG2 */
#pragma config BOR4V = BOR40V /* Brown-out Reset Selection bit (Brown-out Reset set to 4.0V) */
#pragma config WRT = OFF /* Flash Program Memory Self Write Enable bits (Write protection off) */
void delaya_US( unsigned char n );
void LCD_CSH( void );
void LCD_WRITE_4( unsigned char R1, unsigned char FLAG );
void LCD_WRITE( unsigned char R1, unsigned char FLAG );
unsigned char LCD_READ( void );
void LCD_BUSY( void );
void delaya( unsigned int n );
/* LCD显示相关 */
#define DATA 1 /* LCD写数据时为1 */
#define COM 0 /* LCD写命令时为0 */
#define LINE1 0b10000000
#define LINE2 0b11000000
#define LCD_E RD6
#define LCD_RW RD5
#define LCD_RS RD4
/* ======延时(n×10)us */
unsigned char j;
for ( j = 0; j < n; j++ )
NOP(); NOP();
/* LCD初始化 */
TRISD = 0x00; /* RD方向输出 */
delaya( 20 );
LCD_WRITE_4( 0b0011, COM );
delaya( 5 );
delaya_US( 10 );
delaya_US( 10 );
LCD_WRITE_4( 0b0010, COM );
LCD_BUSY();
LCD_WRITE( 0b00101000, COM );
LCD_WRITE( 0b00001100, COM );
LCD_WRITE( 0b00000001, COM );
delaya( 2 );
LCD_WRITE( 0b00000110, COM );
/* LCD写4位命令 */
LCD_RW = 0; NOP();
LCD_RS = FLAG;
PORTD &= 0xF0;
LCD_E = 1; NOP();
PORTD |= R1;
NOP(); NOP();
LCD_E = 0; NOP();
LCD_RS = 0; NOP();
PORTD &= 0xF0;
/* LCD写命令 */
unsigned char R2;
LCD_BUSY();
LCD_RW = 0; NOP();
LCD_RS = FLAG;
R2 = (R1 >> 4) & 0x0F;
PORTD &= 0xF0; NOP();
LCD_E = 1;
PORTD |= R2;
NOP(); NOP();
LCD_E = 0;
R2 = R1 & 0x0F;
LCD_E = 1; NOP();
PORTD |= R2;
NOP(); NOP();
LCD_E = 0; NOP();
LCD_RS = 0; NOP();
PORTD &= 0xF0;
/* 读LCD状态 */
unsigned char R1;
TRISD = 0x0F;
LCD_RS = 0; NOP();
LCD_RW = 1;
NOP(); NOP();
LCD_E = 1;
NOP(); NOP();
NOP(); NOP();
R1 = 0;
R1 = (PORTD << 4) & 0xF0;
LCD_E = 0;
NOP(); NOP();
NOP(); NOP();
LCD_E = 1;
NOP(); NOP();
R1 |= (PORTD & 0x0F);
LCD_E = 0; NOP();
LCD_RW = 0;
TRISD = 0x00;
return(R1);
/* 检测LCD是否忙 */
unsigned char R1;
do
R1 = LCD_READ();
while ( (R1 & 0x80) == 0x80 );
/* ======延时(n)ms */
unsigned int j;
unsigned char k;
for ( k = 246; k > 0; k-- )
NOP();
* 显示屏字符串写入函数
void LCD_write_str( unsigned char x, unsigned char y, char *s )
if ( y == 0 )
LCD_WRITE( 0x80 + x, COM );
}else {
LCD_WRITE( 0xC0 + x, COM );
while ( *s )
LCD_WRITE( *s, DATA );
s++;
#define K1 RC0
#define K2 RC1
int Keyscan( void )
TRISC |= 0x03; /*按键是输入 */
if ( K1 == 0 )
delaya( 5 );
if ( K1 == 0 )
while ( K1 == 0 )
; /* 等待按键松开 */
return(1);
if ( K2 == 0 )
delaya( 5 );
if ( K2 == 0 )
while ( K2 == 0 )
; /* 等待按键松开 */
return(2);
return(0);
* 【函 数 名】: void send_cmd(unsigned char dat)
* 【功 能】: 串口发送数据命令
void send( unsigned char dat )
TXREG = dat;
while ( TRMT != 1 )
; /* 等待发送完成 */
* 【函 数 名】: Print_Str(unsigned char *s)
* 【功 能】: 串口发送 一个字符串
void Print_Str( unsigned char *s )
while ( *s != '
