* Originates from Samsung's u-boot 1.1.6 port to S5PC1xx
* Copyright (C) 2009 Samsung Electrnoics
* Inki Dae
* Heungjun Kim
* Minkyu Kang
* Kyungmin Park
* See file CREDITS for list of people who contributed to this
* project.
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston,
* MA 02111-1307 USA
#include
.globl mem_ctrl_asm_init
mem_ctrl_asm_init:
ldr r0, =0xe6000000 /*APB_DMC_BASE*/
ldr r1, =0xe0000000 /*PRO_ID_BASE*/
ldr r2, [r1] /*PRO_ID regiser*/
bic r2, #0xfffffdff
/******************** DLL initialization **************************/
@ldr r1, =0x6a101000
ldr r1, =0x50101000
str r1, [r0, #0x18] /*PHY control 0 register*/
@ldr r1, =0x000084f4
ldr r1, =0x000000f6
str r1, [r0, #0x1c] /*PHY control 1 register*/
ldr r1, =0x00000000
str r1, [r0, #0x20] /*PHY control 2 register*/
@ldr r1, =0x6A101002 @DLL on
ldr r1, =0x50101002
@ldr r1, =0x6A101003 @Dll start
ldr r1, =0x50101003
ldr r1, =0x50101003
ldr r1, =0x50101001
/************************** DLL initialization - END ************************/
@ldr r1, =0x0FF01010 @auto refresh off
ldr r1, =0xFF001010
str r1, [r0, #0x0] /*e6000000 = controller control register*/
@ldr r1, =0x00212400 @ BL=4 , 2 chip , DDR2
ldr r1, =0xff202400
str r1, [r0, #0x4] /*e6000004 = memory control register*/
@ 128MB config , 8banks , linear, Row=13bit,COL=10bit
@ldr r1, =0x20F01313
ldr r1, =0x20e00313
str r1, [r0, #0x8]
@ldr r1, =0x40F01313
ldr r1, =0x30e00323
str r1, [r0, #0xc]
ldr r1, =0x20000000
str r1, [r0, #0x14] /*precharge policy configuration register*/
@ldr r1, =0x00100004
@str r1, [r0, #0x28] /*precharge policy configuration register*/
@ldr r1, =0x0000050e
ldr r1, =0x00000400
str r1, [r0, #0x30] /*AC timing register for auto refresh of memory*/
@ldr r1, =0x16233297 @TimingRow @166MHz
ldr r1, =0x16233287
str r1, [r0, #0x34] /*AC timing register for the row of memory*/
@; ldr r1, =0x24250304 @CL=5
@ldr r1, =0x23230000 @CL=3
ldr r1, =0x23240304
str r1, [r0, #0x38] /*AC timing register for the data of memory*/
@ldr r1, =0x07c80232 @Timing Power
ldr r1, =0x09c80232
str r1, [r0, #0x3c] /*AC timing register for the power mode of memory*/
/************************ direct command for DDR2 ***********************/
ldr r1, =0x07000000 @chip0 Deselect
str r1, [r0, #0x10] /*memory direct command register*/
ldr r1, =0x01000000 @chip0 PALL
str r1, [r0, #0x10]
ldr r1, =0x00020000 @chip0 EMRS2
str r1, [r0, #0x10]
ldr r1, =0x00030000 @chip0 EMRS3
str r1, [r0, #0x10]
ldr r1, =0x00010400 @chip0 EMRS1 (MEM DLL on = DQS# disable)
str r1, [r0, #0x10]
@; ldr r1, =0x00000552 @chip0 MRS (MEM DLL reset) CL=5, Burst Length=4
ldr r1, =0x00000542 @chip0 MRS (MEM DLL reset) CL=3, Burst Length=4
str r1, [r0, #0x10]
str r1, [r0, #0x10]
ldr r1, =0x05000000 @chip0 REFA
str r1, [r0, #0x10]
str r1, [r0, #0x10]
@; ldr r1, =0x00000452 @chip0 MRS (MEM DLL unreset) , BL=4 , CL=5
ldr r1, =0x00000442 @chip0 MRS (MEM DLL unreset) , BL=4 , CL=3
str r1, [r0, #0x10]
ldr r1, =0x00010780 @chip0 EMRS1 (OCD default)
str r1, [r0, #0x10]
ldr r1, =0x00010400 @chip0 EMRS1 (OCD exit) Reduced Strength
str r1, [r0, #0x10]
/************************ direct command for DDR2 - END*******************/
@ldr r1, =0x00FF20B0 @ConControl auto refresh on
ldr r1, =0xff01030
ldr r1, =0x00100004
str r1, [r0, #0x28]
@ldr r1, =0x00212413 @ MemControl
ldr r1, =0x00202400
str r1, [r0, #0x4] /*e6000000 = controller control register*/
b exit_cpu_init
exit_cpu_init:
mov pc, lr
