用到GPIO口 PA0~PA11共12个引脚
先上原理图
因为是共阳所以12,9,8,6为电源输入,其他引脚均为接地,所以对于芯片来说12,9,8,6高位输出,其他设定为低位即可。
//设定下GPIO口
voidGPIO_Num_Init(void)
GPIO_InitTypeDefGPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable,ENABLE);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_All;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure);
这里有个要注意的,根据原理图可以看出数码管一次只能输出一位数组,所以如果是多位的必须使用扫描的方式输出,缩短切换的间隔,就可以达到不闪烁的效果。
//输出封装
voidDisPlayNum(intn)
if(n《9999)
{inti;
ints;
s=n;
i=0;
for(i=0;i《4;i++)
GPIO_ResetBits(GPIOA,GPIO_Pin_All);
switch(i)
case0:
GPIO_SetBits(GPIOA,GPIO_Pin_5);
break;
case1:
GPIO_SetBits(GPIOA,GPIO_Pin_7);
break;
case2:
GPIO_SetBits(GPIOA,GPIO_Pin_8);
break;
case3:
GPIO_SetBits(GPIOA,GPIO_Pin_11);
break;
switch(s%10)
case0:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_4);
break;
case1:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_9|GPIO_Pin_10);
break;
case2:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_9);
break;
case3:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0|GPIO_Pin_9);
break;
case4:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_10);
break;
case5:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0|GPIO_Pin_6);
break;
case6:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_6);
break;
case7:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_9);
break;
case8:
GPIO_SetBits(GPIOA,GPIO_Pin_2);
break;
case9:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0);
break;
s=s/10;
delay_ms(1);
if(s==0)
break;
最后main的测试代码
intcount;
intTimeCheck;
intmain(void)
GPIO_Num_Init();
count=0;
TimeCheck=0;
while(1)
DisPlayNum(count);
TimeCheck++;
delay_ms(5);
if (TimeCheck 》 100){ //每500毫秒+1
