void I2Cstart()//开始标志 { SDA=1; SCL=1; SDA=0; delay1ms(4); SCL=0; delay1ms(4); } void I2Cstop()//结束标志 { SCL=0; delay1ms(4); SDA=0; delay1ms(4); SCL=1; delay1ms(4); SDA=1; delay1ms(4); } unsigned char I2Creadack() { unsigned char i,byte; byte=0; for(i=0;i<8;i++) { SCL=0; SDA=1; delay1ms(4); byte<<=1; if(SDA==1) { byte|=0x01; delay1ms(4); } } SCL=0; delay1ms(4); SDA=0; delay1ms(4); SCL=1; delay1ms(4); SCL=0; return byte; } void I2Csend(unsigned char byte)//I2C写数据的过程 { unsigned char mask,i; for(i=0;i<8;i++) { SCL=0; if((mask&byte)==0) { SDA=0; } else { SDA=1; } mask>>=1; delay1ms(4); SCL=1;//给足够时间让数据读取 delay1ms(4); } SCL=0; SDA=1; //因为总线上有一个信号为低则低 delay1ms(4); SCL=1; delay1ms(4);//等待应答位 SCL=0; } unsigned char I2Cread(void) { unsigned char i,byte; byte =0; for(i=0;i<8;i++) { SCL=0; SDA=1;//读数据必须拉高 delay1ms(4); SCL=1;//数据稳定 delay1ms(4); byte<<=1; if(SDA==1) { byte|=0x01; } delay1ms(4); } SCL=0; delay1ms(4); SDA=0;//发送的应答位 delay1ms(4); SCL=1; delay1ms(4); SCL=0; return byte; } unsigned char I2Cread_eeprom(unsigned char addr)//I2C读取数据 { unsigned char datebyte,datebyte2; I2Cstart(); I2Csend(0xa0);//写数据 I2Csend(addr); I2Cstart(); I2Csend(0xa1);//读数据 datebyte2=I2Creadack(); datebyte=I2Cread(); I2Cstop(); return datebyte; } void write_eeprom(unsigned char addr,unsigned char datebyte) { I2Cstart(); I2Csend(0xa0); I2Csend(addr); I2Csend(datebyte); I2Cstop(); }
