//////////////////包含头文件及宏定义//////////////////////////////////////
#include
#include
#define uchar unsigned char
#define uint unsigned int
////////////////继电器响应动作指示灯//////////////////////////////////////
sbit light=P1^0;
sbit int0_ok=P3^2;
sbit int1_ok=P3^3;
/////////////////数码管的段位锁存////////////////////////////////////////
sbit duan=P0^0;
sbit wei=P0^1;
uchar bit1,bit2,bit3,bit4,bit5,bit6;///////////////小时 分钟 秒钟显示码
uchar fen=0;// 分钟缓存
uchar miao=0;//秒缓存
uchar shi=0;//小时缓存
uchar key_temp;/////按键暂存
//uchar key_old;
uchar key_count;//按键计数
uchar key_back;/////按键备份
uchar key_data;//////按键数值
uchar key_con;////
uchar key_ok;
uchar int0_function=0;///功能0,做调节始终
uchar int1_function=0;///功能1,做运行停止用
uchar time;////定时常数
uchar t2time;
#define KEYDELAY 25 /*首键延迟次数*/
#define KEYLOOP 10 /*连续键间隔次数,需小于KEYDELAY*/
void shanshuo(uchar aa,uchar ii);
void init();
void sign(uchar i);
////////////////毫秒级的延时////////////////////////////////////////////////
void delayms(uint i) //误差 0us
uint c;
unsigned char a,b;
for(c=i;c>0;c--)
for(b=142;b>0;b--)
for(a=2;a>0;a--);
/////////////////////////////数码管的段位码///////////////////////////////
uchar code tableduan[]={ //共阳极数码管段码
0xc0,0xf9,0xa4,0xb0,
0x99,0x92,0x82,0xf8, 0x80,0x90,//0-9
//0x88,0x83,0xc6,0xa1,0x86,0x8E//A-F
0xbf//-
uchar code tablewei[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//位码
uchar code welcom[]={0xbf,0xbf,0xc0,0x8c,0x86,0xc8,0xbf,0xbf};//--OPEN-- 1
uchar code on[]={0xbf,0xbf,0xbf,0xc0,0xc8,0xbf,0xbf,0xbf};//---on--- 2
uchar code off[]={0xbf,0xbf,0xc0,0x8e,0x8e,0xbf,0xbf,0xbf};//--off--- 3
uchar code closed[]={0xbf,0xc6,0xc7,0xc0,0x92,0x86,0xf8,0xbf};//-closed- 4
/////////////////////////////////数码管显示程序///////////////////////////////////////
void display(uchar duan1,uchar wei1)
P2=0xff;
duan=0;
wei=0;
P2=tableduan[duan1];
duan=1;
duan=0;
P2=tablewei[wei1];
wei=1;
wei=0;
delayms(1);
//////////////////////////////////////数码管显示位计算/////////////////////////////////
void jisuan()
bit1=shi/10;
bit2=shi%10;
bit3=fen/10;
bit4=fen%10;
bit5=miao/10;
bit6=miao%10;
display(bit1,0);
display(bit2,1);
display(10,2);
display(bit3,3);
display(bit4,4);
display(10,5);
display(bit5,6);
display(bit6,7);*/
//////////////////////////////////////数码管显示位计算/////////////////////////////////////////////////
//////////////////////////////////////单击按键键值表////////////////////////////////////////////////////////
uchar key_data_jisuan(uchar dat)
uchar key;
switch(dat)
case 0xfb:key=1;break;
case 0xf7:key=2;break;
case 0xef:key=3;break;
case 0xdf:key=4;break;
case 0xbf:key=5;break;
case 0x7f:key=6;break;
default:key=0;break;
return key;
//////////////////////////////////////长按按键键值表////////////////////////////////////////////////////////
/*uchar key_data_con_jisuan(uchar dat)
uchar key;
switch(dat)
case 0xef:key=5;break;
case 0xdf:key=6;break;
return key;
/////////////////////////////////////////键盘扫描//////////////////////////////////////////////////////
void key_scan()
P3=0xff;
if((P3&0xff)!=0xff)
delayms(10);
key_temp=P3;
if(key_temp==key_back)
delayms(10);
key_count++;
if (key_count==KEYDELAY) //连续键,不要则把此if屏蔽
key_ok=0;
key_data=key_data_jisuan(key_temp); //键*
key_count=KEYDELAY-KEYLOOP;
else
key_count=0;
key_back=key_temp;
//key_ok=1;
else
if(key_count)
key_count=0;
key_temp=0;
key_ok=1;
}[page]
/////////////////定时器0的初始化///////////////////////////
void InitTimer0(void)
TMOD = 0x01;
TH0 = 0x3C;
TL0 = 0x0B0;
ET0 = 1;
//TR0 = 1;
//EA = 1;
void InitTimer1(void)
TMOD = 0x10;
TH1 = 0x3C;
TL1 = 0x0B0;
EA = 1;
// ET1 = 1;
// TR1 = 1;
////////////////////////////主函数开始///////////////////////////
void main()
uchar ss;
InitTimer0();
// InitTimer1();
while(1)
key_scan();
if(key_data==1)
key_data=0;
int0_function++;
if(int0_function==5)
int1_function=0;
ss=0;
int0_function=1;
if(key_data==2)
key_data=0;
int1_function++;
if(int1_function>=3)int1_function=1;
if(int0_function==0)
sign(1);
////////////////////小时设定///////////////////////////
if(int0_function==1)
TR0 = 0;
EA = 0;
// ET1 = 1;
// TR1 = 1;
light=1;
// shanshuo(0,1);
if(key_data==3)
key_data=0;
shi++;if(shi==24)shi=0;
if(key_data==4)
key_data=0;
shi--;if(shi==0)shi=23;
jisuan();
shanshuo(0,1);
for(ss=10;ss>0;ss--)
display(bit1,0);
display(bit2,1);
display(10,2);
display(bit3,3);
display(bit4,4);
display(10,5);
display(bit5,6);
display(bit6,7);
// display(bit1,0);
// display(bit2,1);
display(10,2);
display(bit3,3);
display(bit4,4);
display(10,5);
display(bit5,6);
display(bit6,7);
/////////////////分钟设定/////////////////////////
if(int0_function==2)
TR0 = 0;
EA = 0;
// ET1 = 1;
// TR1 = 1;
light=1;
if(key_data==3)
key_data=0;
fen++;if(fen==60)fen=0;
if(key_data==4)
key_data=0;
fen--;if(fen==0)fen=59;
jisuan();
// shanshuo(0,2);
display(bit1,0);
display(bit2,1);
display(10,2);
display(bit3,3);
display(bit4,4);
display(10,5);
display(bit5,6);
display(bit6,7);
display(bit1,0);
display(bit2,1);
display(10,2);
// display(bit3,3);
// display(bit4,4);
display(10,5);
display(bit5,6);
display(bit6,7);
//////////////////////秒数设定////////////////////////////
if(int0_function==3)
TR0 = 0;
EA = 0;
// ET1 = 1;
// TR1 = 1;
light=1;
if(key_data==3)
key_data=0;
miao++;if(miao==60)miao=0;
if(key_data==4)
key_data=0;
miao--;if(miao==0)miao=59;
jisuan();
// shanshuo(0,3);
display(bit1,0);
display(bit2,1);
display(10,2);
display(bit3,3);
display(bit4,4);
display(10,5);
display(bit5,6);
display(bit6,7);
display(bit1,0);
display(bit2,1);
display(10,2);
display(bit3,3);
display(bit4,4);
display(10,5);
// display(bit5,6);
// display(bit6,7);
if(int0_function==4)
display(bit1,0);
display(bit2,1);
display(10,2);
display(bit3,3);
display(bit4,4);
display(10,5);
display(bit5,6);
display(bit6,7);
//if(int0_function==6)
// sign(6);
///////////////////////////计时开始/////////////////////
if(int1_function==1)
TR0 = 1;
EA = 1;
int0_function=4;
// ET1 = 0;
// TR1 = 0;
if((shi==0)&&(fen==0)&&(miao==0))
light=0;
jisuan();
shanshuo(0,0);
////////////////计时结束,关掉定时器和继电器/////////////////
if(int1_function==2)
TR0 = 0;
EA = 0;
// ET1 = 1;
// TR1 = 1;
light=1;
int0_function=0;
int1_function=0;
jisuan();
sign(4);
// jisuan();
//shanshuo(0,0);
/////////////////定时器0的中断服务///////////////////////////
void Timer0Interrupt(void) interrupt 1
TH0 = 0x3C;
TL0 = 0x0B0;
//add your code here!
time++;
if(time==20)
time=0;
if(miao>0)miao--;
if((miao==0)&&(fen>0)){miao=59;fen--;}
if((fen==0)&&(shi>0)){fen=59;shi--;}
}[page]
void Timer1Interrupt(void) interrupt 3
TH1 = 0x3C;
TL1 = 0x0B0;
t2time++;
if(t2time==20)t2time=0;
void shanshuo(uchar aa,uchar i)///如果i=1 是小时闪烁 ,如果i=2 是 分钟闪烁,如果i=3 是秒钟闪烁
//uchar i;//闪烁频率
if(aa==4|aa==0)
for(i;i>0;i--)
display(bit1,0);
display(bit2,1);
display(10,2);
display(bit3,3);
display(bit4,4);
display(10,5);
display(bit5,6);
display(bit6,7);
if(aa==1)
for(i;i>0;i--)
// display(bit1,0);
// display(bit2,1);
display(10,2);
display(bit3,3);
display(bit4,4);
display(10,5);
display(bit5,6);
display(bit6,7);
if(aa==2)
for(i;i>0;i--)
display(bit1,0);
display(bit2,1);
display(10,2);
// display(bit3,3);
// display(bit4,4);
display(10,5);
display(bit5,6);
display(bit6,7);
if(aa==3)
for(i;i>0;i--)
display(bit1,0);
display(bit2,1);
display(10,2);
display(bit3,3);
display(bit4,4);
display(10,5);
// display(bit5,6);
// display(bit6,7);
for(i;i>0;i--)
display(bit1,0);
display(bit2,1);
display(10,2);
display(bit3,3);
display(bit4,4);
display(10,5);
display(bit5,6);
display(bit6,7);
/////////////////闪烁程序/////////////////////////////////////////////////////////////
void sign(uchar i )// 1, 显示open,显示on 3,显示off 4,显示 closed
uchar bb;
if(i==0)
P2=0x00;
P0=0x03;
if(i==1)
for(bb=0;bb<8;bb++)
P2=0xff;
duan=0;
wei=0;
P2=welcom[bb];
duan=1;
//delayms(1);
duan=0;
P2=tablewei[bb];
wei=1;
//delayms(1);
wei=0;
delayms(1);
if(i==2)
for(bb=0;bb<8;bb++)
P2=0xff;
duan=0;
wei=0;
P2=on[bb];
duan=1;
//delayms(1);
duan=0;
P2=tablewei[bb];
wei=1;
//delayms(1);
wei=0;
delayms(1);
if(i==3)
for(bb=0;bb<8;bb++)
P2=0xff;
duan=0;
wei=0;
P2=off[bb];
duan=1;
//delayms(1);
duan=0;
P2=tablewei[bb];
wei=1;
//delayms(1);
wei=0;
delayms(1);
if(i==4|i==0)
for(bb=0;bb<8;bb++)
P2=0xff;
duan=0;
wei=0;
P2=closed[bb];
duan=1;
//delayms(1);
duan=0;
P2=tablewei[bb];
wei=1;
//delayms(1);
wei=0;
delayms(1);
