单片机 > 单片机程序设计 > 详情
51单片机简易加法计算器
发布时间:2024-11-04 发布时间:
  1. #include
  2.
  3. typedef unsigned char uchar;
  4. typedef unsigned int uint;
  5. typedef unsigned long ulong;
  6.
  7. sbit ADDR0 = P1^0;
  8. sbit ADDR1 = P1^1;
  9. sbit ADDR2 = P1^2;
  10. sbit ADDR3 = P1^3;
  11. sbit ENLED = P1^4;
  12. sbit KEY_IN_0 = P2^4;
  13. sbit KEY_IN_1 = P2^5;
  14. sbit KEY_IN_2 = P2^6;
  15. sbit KEY_IN_3 = P2^7;
  16. sbit KEY_OUT_0 = P2^3;
  17. sbit KEY_OUT_1 = P2^2;
  18. sbit KEY_OUT_2 = P2^1;
  19. sbit KEY_OUT_3 = P2^0;
  20.
  21. uchar code LEDChar[] = {  //数码管显示字符转换表
  22.     0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
  23.     0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
  24. };
  25. uchar LEDBuff[6] = {  //数码管显示缓冲区
  26.     0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
  27. };
  28. uchar code keyCodeMap[4][4] = { //矩阵按键编号到标准键盘键码的映射表
  29.     {0x31, 0x32, 0x33, 0x26}, //数字键1、数字键2、数字键3、向上键
  30.     {0x34, 0x35, 0x36, 0x25}, //数字键4、数字键5、数字键6、向左键
  31.     {0x37, 0x38, 0x39, 0x28}, //数字键7、数字键8、数字键9、向下键
  32.     {0x30, 0x1B, 0x0D, 0x27}  //数字键0、ESC键、  回车键、 向右键
  33. };
  34. uchar keyState[4][4] = {  //全部矩阵按键的当前状态
  35.     {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1}
  36. };
  37. uchar T0RH = 0;
  38. uchar T0RL = 0;
  39.
  40. void ShowNumber(ulong num)
  41. {
  42.     char i;
  43.     uchar buf[6];
  44.     for (i=0; i<6; i++)
  45.     {
  46.         buf[i] = num % 10;
  47.         num /= 10;
  48.     }
  49.     for (i=5; i>=0; i--)
  50.     {
  51.         if (buf[i] == 0)
  52.             LEDBuff[i] = 0xFF;
  53.         else
  54.             break;
  55.     }
  56.     for (; i>=0; i--)
  57.         LEDBuff[i] = LEDChar[buf[i]];
  58. }
  59.
  60. void KeyAction(uchar keyCode)
  61. {
  62.     static ulong result = 0;
  63.     static ulong number = 0;
  64.     if (keyCode >= 0x30 && keyCode <= 0x39)
  65.     {
  66.         number = number * 10 + keyCode - 0x30;
  67.         ShowNumber(number);
  68.     }
  69.     else if (keyCode == 0x26 || keyCode == 0x0D)
  70.     {
  71.         result += number;
  72.         number = 0;
  73.         ShowNumber(result);
  74.     }
  75.     else if (keyCode == 0x1B)
  76.     {
  77.         number = 0;
  78.         result = 0;
  79.         ShowNumber(number);
  80.     }
  81. }
  82.
  83. void KeyDriver()
  84. {
  85.     uchar i, j;
  86.     static uchar backup[4][4] = {
  87.         {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}
  88.     };
  89.     for (i=0; i<4; i++)
  90.         for (j=0; j<4; j++)
  91.             if (keyState[i][j] != backup[i][j])
  92.             {
  93.                 if (keyState[i][j] == 0)
  94.                     KeyAction(keyCodeMap[i][j]);
  95.                 backup[i][j] = keyState[i][j];
  96.             }
  97. }
  98.
  99. void KeyScan()
  100. {
  101.     static uchar i = 0;
  102.     static uchar keyBuf[4][4] = {
  103.         {0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF},
  104.         {0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF}
  105.     };
  106.     uchar j;
  107.     keyBuf[i][0] = (keyBuf[i][0] <
  108.     keyBuf[i][1] = (keyBuf[i][1] <
  109.     keyBuf[i][2] = (keyBuf[i][2] <
  110.     keyBuf[i][3] = (keyBuf[i][3] <
  111.     for (j=0; j<4; j++)
  112.     {
  113.         if (keyBuf[i][j] == 0x00)
  114.             keyState[i][j] = 0;
  115.         else if (keyBuf[i][j] == 0xFF)
  116.             keyState[i][j] = 1;
  117.     }
  118.     switch (i)
  119.     {
  120.         case 0: KEY_OUT_0 = 1; KEY_OUT_1 = 0; break;
  121.         case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
  122.         case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
  123.         case 3: KEY_OUT_3 = 1; KEY_OUT_0 = 0; break;
  124.         default : break;
  125.     }
  126.     i = ++i & 0x03;
  127. }
  128.
  129. void LEDScan()
  130. {
  131.     static uchar i = 0;
  132.     P0 = 0xFF;
  133.     P1 = (P1 & 0xF8) | i;
  134.     P0 = LEDBuff[i];
  135.     if (i
  136.         i++;
  137.     else
  138.         i = 0;
  139. }
  140.
  141. void SetTimer0(uint ms)
  142. {
  143.     ulong tmp;
  144.     tmp = 11059326 / 12;
  145.     tmp = tmp * ms / 1000;
  146.     tmp = 65536 - tmp;
  147.     tmp += 28;
  148.     T0RL = tmp;
  149.     T0RH = tmp>>8;
  150. }
  151.
  152. void InterruptTimer0() interrupt 1
  153. {
  154.     TH0 = T0RH;
  155.     TL0 = T0RL;
  156.     LEDScan();
  157.     KeyScan();
  158. }
  159.
  160. void main()
  161. {
  162.     EA = 1;
  163.     ENLED = 0;
  164.     ADDR3 = 1;
  165.     TMOD = 0x01;
  166.     SetTimer0(1);
  167.     TH0 = T0RH;
  168.     TL0 = T0RL;
  169.     ET0 = 1;
  170.     TR0 = 1;
  171.     LEDBuff[0] = LEDChar[0];
  172.     while (1)
  173.     {
  174.         KeyDriver();
  175.     }
  176. }
我想加一个效果,在按加号的时候同时显示数字和加号,我使用了第二个定时器定时,可是实验结果是中断服务函数执行得太慢了,扫描很慢,看不到连续的画面,效果不好,而且影响下一个按键的判断。。
[cpp] view plain copy
  1. #include
  2.
  6.
  20.
  21. uchar code LedChar[] = {  //数码管显示字符转换表
  24. };
  25. uchar LedBuff[6] = {  //数码管显示缓冲区
  27. };
  28. uchar code KeyCodeMap[4][4] = { //矩阵按键编号到标准键盘键码的映射表
  29.     { 0x31, 0x32, 0x33, 0x26 }, //数字键1、数字键2、数字键3、向上键
  30.     { 0x34, 0x35, 0x36, 0x25 }, //数字键4、数字键5、数字键6、向左键
  31.     { 0x37, 0x38, 0x39, 0x28 }, //数字键7、数字键8、数字键9、向下键
  32.     { 0x30, 0x1B, 0x0D, 0x27 }  //数字键0、ESC键、  回车键、 向右键
  33. };
  36. };
  37. uchar code image[] = {
  38.     0xFF,0xE7,0xE7,0x81,0x81,0xE7,0xE7,0xFF
  39. };
  40.
  41. uchar T0RH = 0;
  42. uchar T0RL = 0;
  43.
  44. void showNumber(ulong num){
  45.     char i;
  46.     uchar buf[6];
  47.     for(i=0; i<6; i++){
  48.         buf[i] = num % 10;
  49.         num /= 10;
  50.     }
  51.     for(i=5; i>=0; i--){
  52.         if(buf[i] == 0) LedBuff[i] = 0xFF;
  53.         else break;
  54.     }
  55.     for(; i>=0; i--){
  56.         LedBuff[i] = LedChar[buf[i]];
  57.     }
  58. }
  59.
  60. void showPicture(){
  61.     TR0 = 0;
  62.     ET0 = 0;
  63.     ADDR3 = 0;
  64.     TMOD &= 0x0F;
  65.     TMOD |= 0x10;
  66.     TH1 = 0xFF;
  67.     TL1 = 0xFE;
  68.     ET1 = 1;
  69.     TR1 = 1;
  70. }
  71.
  72. void closePicture(){
  73.     TR1 = 0;
  74.     ET1 = 0;
  75.     ADDR3 = 1;
  76.     ET0 = 1;
  77.     TR0 = 1;
  78. }
  79.
  80. void keyAction(uchar keyCode){
  81.     static ulong result = 0;
  82.     static ulong number = 0;
  83.     static bit flag = 0;
  84.     if(keyCode >= 0x30 && keyCode <= 0x39){
  85.         if(flag == 1){
  86.             closePicture();
  87.             flag = 0;
  88.         }
  89.         number = number * 10 + keyCode - 0x30;
  90.         showNumber(number);
  91.     }
  92.     else if(keyCode == 0x26 || keyCode == 0x0D){
  93.         result += number;
  94.         number = 0;
  95.         showNumber(result);
  96.         showPicture();
  97.         flag = 1;
  98.     }
  99.     else if(keyCode == 0x1B){
  100.         if(flag == 1){
  101.             closePicture();
  102.             flag = 0;
  103.         }
  104.         number = 0;
  105.         result = 0;
  106.         showNumber(number);
  107.     }
  108. }
  109.
  110. void keyDriver(){
  111.     uchar i, j;
  112.     static uchar backup[4][4] = {
  113.         {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}
  114.     };
  115.     for(i=0; i<4; i++){
  116.         for(j=0; j<4; j++){
  117.             if(keyState[i][j] != backup[i][j]){
  118.                 if(keyState[i][j] == 0){
  119.                     keyAction(KeyCodeMap[i][j]);
  120.                 }
  121.                 backup[i][j] = keyState[i][j];
  122.             }
  123.         }
  124.     }
  125. }
  126.
  127. void keyScan(){
  128.     static uchar i = 0;
  129.     static uchar keyBuf[4][4] = {
  130.         {0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF},
  131.         {0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF}
  132.     };
  133.     uchar j;
  134.     keyBuf[i][0] = (keyBuf[i][0] <
  135.     keyBuf[i][1] = (keyBuf[i][1] <
  136.     keyBuf[i][2] = (keyBuf[i][2] <
  137.     keyBuf[i][3] = (keyBuf[i][3] <
  138.     for(j=0; j<4; j++) {
  139.         if(keyBuf[i][j] == 0x00){
  140.             keyState[i][j] = 0;
  141.         }
  142.         else if(keyBuf[i][j] == 0xFF){
  143.             keyState[i][j] = 1;
  144.         }
  145.     }
  146.     switch(i){
  147.         case 0: KEY_OUT_0 = 1; KEY_OUT_1 = 0; break;
  148.         case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
  149.         case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
  150.         case 3: KEY_OUT_3 = 1; KEY_OUT_0 = 0; break;
  151.         default: break;
  152.     }
  153.     i = ++i & 0x03;
  154. }
  155.
  156. void LEDScan(){
  157.     static uchar i = 0;
  158.     P0 = 0xFF;
  159.     P1 = (P1 & 0xF8) | i;
  160.     P0 = LedBuff[i];
  161.     if(i
  162.     else i = 0;
  163. }
  164.
  165. void setTimer0(uint ms){
  166.     ulong tmp;
  167.     tmp = 11059326 / 12;
  168.     tmp = tmp * ms / 1000;
  169.     tmp = 65536 - tmp;
  170.     tmp += 28;
  171.     T0RL = tmp;
  172.     T0RH = tmp>>8;
  173. }
  174.
  175. void interruptTimer0() interrupt 1{
  176.     TH0 = T0RH;
  177.     TL0 = T0RL;
  178.     LEDScan();
  179.     keyScan();
  180. }
  181.
  182. void interruptTimer1() interrupt 3{
  183.     static uchar i = 0, j = 0;
  184.     static bit flag = 1;
  185.     if(flag){
  186.         ADDR3 = 0;
  187.         P0 = 0xFF;
  188.         P1 = (P1 & 0xF8) | i;
  189.         P0 = image[i];
  190.         if(i
  191.         else{
  192.             i = 0;
  193.             flag = 0;
  194.         }
  195.     }
  196.     else{
  197.         ADDR3 = 1;
  198.         P0 = 0xFF;
  199.         P1 = (P1 & 0xF8) | j;
  200.         P0 = LedBuff[j];
  201.         if(j
  202.         else{
  203.             j = 0;
  204.             flag = 1;
  205.         }
  206.     }
  207.     keyScan();
  208. }
  209.
  210. void main(){
  211.     EA = 1;
  212.     ENLED = 0;
  213.     ADDR3 = 1;
  214.     TMOD = 0x01;
  215.     setTimer0(1);
  216.     TH0 = T0RH;
  217.     TL0 = T0RL;
  218.     ET0 = 1;
  219.     TR0 = 1;
  220.     LedBuff[0] = LedChar[0];
  221.     while(1){
  222.         keyDriver();
  223.     }
  224. }
stm32f4 - 时钟树分析配置
