#include
#include
#define setb(val,bitn) (val|=(1<
#define clrb(val,bitn) (val&=~(1<
int main( void )
init_devices();
while(1){
setb(PORTB,0);
delay(1000);
clrb(PORTB,0);
delay(1000);
return 0;
void delay(unsigned int n)
unsigned int i;
for(i=0;i
void port_init(void)
PORTA = 0x00;
DDRA = 0x00;
PORTB = 0x00;
DDRB = 0x01;
PORTC = 0x00; //m103 output only
DDRC = 0x00;
PORTD = 0x00;
DDRD = 0x00;
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
MCUCR = 0x00;
GICR = 0x00;
TIMSK = 0x00; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
winavr程序:1. 增加 #include
1) WinAVR中延时函数可使用“#include
void _delay_us (double __us); //微秒级
void _delay_ms (double __ms); //毫秒级
2) WinAVR中全局中断操作使用:
“cli(); //禁止所有中断”和“sei(); //开全局中断”,
它在“”中定义,需将其包含;而ICC中为大写:
“CLI(); //禁止所有中断”和“SEI(); //开全局中断”。
2. 修改 #include
3. 去掉 delay()函数。
#include
#include
#include
#define setb(val,bitn) (val|=(1< #define clrb(val,bitn) (val&=~(1<
void init_devices(void);
int main( void )
init_devices();
while(1){
setb(PORTB,0);
_delay_ms(1000);
clrb(PORTB,0);
_delay_ms(1000);
return 0;
PORTA = 0x00;
DDRA = 0x00;
PORTB = 0x00;
DDRB = 0x01;
DDRC = 0x00;
PORTD = 0x00;
DDRD = 0x00;
cli(); //disable all interrupts
port_init();
MCUCR = 0x00;
GICR = 0x00;
sei(); //re-enable interrupts
WinAVR和ICCAVR最大的不同在于它需要编写单独的Makefile文件,Makefile文件可用“MFile [WinAVR]”工具生成,稍作更改即可,而通常情况下只需更改以下几项:
①芯片类型,此例为“MCU = atmega16”
②芯片工具频率,此例为“F_CPU = 3686400”
③编译输入烧录文件格式,此例为“FORMAT = ihex”(默认)
④目标文件名,此例为“TARGET = main”(默认)
⑤C源程序清单,需以空格隔开,此例为“SRC = $(TARGET).c port_init.c led.c key_scan.c”,默认为“SRC = $(TARGET).c”,需依据程序结构进行添加。
