// Macros for hardware access, both direct and via the bit-band region.
#define HWREG(x) (*((volatile unsigned long *)(x))) // 使用位段方式访问寄存器
使用方法:在main.c中包含hw_types.h文件
HWREG(ETH_BASE + MAC_O_TR) = 0; // 访问方式是:寄存器的基址+偏移地址
// GPIO registers (PORTA)
#define GPIO_PORTA_DATA_BITS_R ((volatile unsigned long *)0x40004000)
#define GPIO_PORTA_DATA_R (*((volatile unsigned long *)0x400043FC))
#define GPIO_PORTA_DIR_R (*((volatile unsigned long *)0x40004400))
#define GPIO_PORTA_IS_R (*((volatile unsigned long *)0x40004404))
#define GPIO_PORTA_IBE_R (*((volatile unsigned long *)0x40004408))
#define GPIO_PORTA_IEV_R (*((volatile unsigned long *)0x4000440C))
#define GPIO_PORTA_IM_R (*((volatile unsigned long *)0x40004410))
#define GPIO_PORTA_RIS_R (*((volatile unsigned long *)0x40004414))
#define GPIO_PORTA_MIS_R (*((volatile unsigned long *)0x40004418))
#define GPIO_PORTA_ICR_R (*((volatile unsigned long *)0x4000441C))
#define GPIO_PORTA_AFSEL_R (*((volatile unsigned long *)0x40004420))
#define GPIO_PORTA_DR2R_R (*((volatile unsigned long *)0x40004500))
#define GPIO_PORTA_DR4R_R (*((volatile unsigned long *)0x40004504))
#define GPIO_PORTA_DR8R_R (*((volatile unsigned long *)0x40004508))
#define GPIO_PORTA_ODR_R (*((volatile unsigned long *)0x4000450C))
#define GPIO_PORTA_PUR_R (*((volatile unsigned long *)0x40004510))
#define GPIO_PORTA_PDR_R (*((volatile unsigned long *)0x40004514))
#define GPIO_PORTA_SLR_R (*((volatile unsigned long *)0x40004518))
#define GPIO_PORTA_DEN_R (*((volatile unsigned long *)0x4000451C))
#define GPIO_PORTA_LOCK_R (*((volatile unsigned long *)0x40004520))
#define GPIO_PORTA_CR_R (*((volatile unsigned long *)0x40004524))
#define GPIO_PORTA_AMSEL_R (*((volatile unsigned long *)0x40004528))
#define GPIO_PORTA_PCTL_R (*((volatile unsigned long *)0x4000452C))
使用方法:在main.c中包含lm3s9b96.h文件
HWREG(GPIO_PORTA_DATA_R) = 0; // 访问方式是:直接写寄存器的物理地址
