PIC12F508单片机是没有中断的,定时器只能是查询方式。
编译器用的XC8,编译环境IDE用的是MPLAB X IDE。
// __________________
// VDD-| 1 8 |-VSS
// GP5-| 2 27 |-GP0/DAT
// GP4-| 3 26 |-GP1/CLK
//GP3/RMCLR--| 4 25 |-GP2
// |________________|
// 12F508
//定时器模式试用
#include
#include
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG
#pragma config OSC = IntRC // Oscillator Selection bits (internal RC oscillator)
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled)
#pragma config CP = OFF // Code Protection bit (Code protection off)
#pragma config MCLRE = OFF // GP3/MCLR Pin Function Select bit (GP3/MCLR pin function is digital input, MCLR internally tied to VDD)
#define uchar unsigned char
#define uint unsigned int
uchar count;
//uchar GP3_F;
void Init()
TRIS=~0x3F; //GP3输入,其它输出
//GPWU = 0;//引脚中断唤醒使能;引脚中断要引起复位的,可以查询复位原因,这样就可以知道是谁的中断了
//GPPU=0;/弱上拉使能
OPTION=0xF5;//分频器给定时器 64 4MHz x=257-tJ/4F
TMR0=0x63; //10ms x=257-tJ/4F
void main()
Init();
while(1)
if(TMR0==0xFF)
TMR0=0x63; //
if(++count==50)//1s
count=0;
GP2=~GP2;//LED闪烁
