Title:PIC16F877A TIMER1计数操作
Author:hnrain
Date:2010-12-28
使用前置分频器
T1CKPS1 T1CKPS1
0 0 1 分频 TMR1时钟为晶振时钟/(4*1)
0 1 2 分频 TMR1时钟为晶振时钟/(4*2)
1 0 4 分频 TMR1时钟为晶振时钟/(4*4)
1 1 8 分频 TMR1时钟为晶振时钟/(4*8)
TMR1是16位宽度的TMR1由2个8位的可读写的寄存器TMR1H和TMR1L组成。
TMR1有专门的启停控制位TMR1ON,通过软件可以任意启动或暂停TMR1计数功能。
T1CON:TIMER1 CONTROL REGISTER
bit7-6 unimplemented :Read as ‘0’
bit5-4 T1CKPS1:T1CKPS0:Timer1 input Clock Prescale Select bits
11=1:8 prescale value
10=1:4 prescale value
01=1:2 prescale value
00=1:1 prescale value
bit3 T1OSCEN:Timer1 Oscillator Enable Control bit
1 = Oscillator is enable
0 = Oscillator is shut-off
bit2 T1SYNC:Timer1 External Clock Input Synchronization Control bit
when TMR1CS = 1
1= Do not synchronize external clock input
0= Synchronize external clock input
when TMR1CS = 0
This bit is ignored .Timer1 uses the internal clock when TMR1CS = 0.
bit1 TMR1CS:Timer1 Clock Source Select bit
1 = External clock from pin RC0/T1OSO/T1CKI
0 = Internal clock
bit0 TMR1ON:Timer1 on bit
1 = enables timer1
0 = stops timer1
说明:作用在TMR1的计数状态,计数信号从RC0/T1CKI输入,
当来一个上升沿时,采集到一个有效的信号,计数到TMR1L,TMR1H中。
当计满时就会产生中断信号。
#include
#include "../head/config.h"
__CONFIG(HS&WDTDIS&LVPDIS&PWRTEN);
void main(void)
T1CKPS0 = 0;
T1CKPS1 = 0;//不分频
TMR1L = (65536 - 1)%256;//TMR1L,TMR1H赋初值
TMR1H = (65536 - 1)/256;
T1SYNC = 1;//TMR1异步计数器
TMR1CS = 1;
GIE = 1;//打开全局中断
PEIE = 1;//打开外部中断
TMR1IE = 1;//TMR1中断打开
TMR1ON = 1;
PORTD = 0x00;
TRISD = 0x00;
while(1){}
void interrupt ISR(void)
TMR1L = (65536 - 1)%256;//重新赋值
if(TMR1IE && TMR1IF)
TMR1IF = 0;
PORTD = ~PORTD;
