// PIC18 MCC PIC18F6622 CONFIG BITS 1=OFF
//CONFIG1H 禁止振荡器切换,禁止故障保护时钟,HS振荡器
//CONFIG2L 欠压复位电压最大值,禁止欠压复位,禁止上电延时
//CONFIG2H 关看门狗及喂狗时间
//CONFIG3H 使能MCLR,高功耗TIMER1,CCP2与RC1复用
//CONFIG4L 后台调试关,扩展指令开,BOOT引导区2K,使能单电源,堆栈溢出复位
//CONFIG5L BLOCK0-3代码不保护
//CONFIG5H EEPROM&引导区 代码不受保护
//CONFIG6L BLOCK0-3 不受写保护
//CONFIG6H 数据EEPROM 引导区 配置寄存器不保护
//CONFIG7L 禁止其它块对BLOCK0-3执行表读操作
//CONFIG7H 禁止其它块对引导区(000000-0007FFh)执行表读操作
#pragma config IESO = OFF, FCMEN = OFF , OSC = HS
#pragma config BORV = 0 , BOREN = OFF , PWRT = OFF
#pragma config WDT = OFF, WDTPS = 128
#pragma config MCLRE = ON , LPT1OSC = ON , CCP2MX = PORTC
#pragma config DEBUG = OFF, BBSIZ = BB2K, XINST = ON , LVP = ON , STVREN = ON
#pragma config CP0 = OFF, CP1 = OFF , CP2 = OFF, CP3 = OFF
#pragma config CPD = OFF, CPB = OFF
#pragma config WRT0 = OFF, WRT1 = OFF , WRT2 = OFF, WRT3 = OFF
#pragma config WRTD = OFF, WRTB = OFF , WRTC = OFF
#pragma config EBTR0 = ON , EBTR1 = ON , EBTR2 = ON
#pragma config EBTRB = OFF
