;*******************无符号 BCD 减法***************
; This routine performs a 2 Digit Unsigned BCD Subtraction.
; It is assumed that the two BCD numbers to be subtracted are in
; locations Num_1 & Num_2. The result is the difference of Num_1 & Num_2
; ( Num_2 - Num_1) and is stored in location Num_2 and the overflow carry
; is returned in location Num_1.
; Performance :
; Program Memory : 31
; Clock Cycles : 21 ( worst case )
Num_1 equ 8 ; Overflow flow carry overwrites Num_1
result equ 8
Num_2 equ 9 ; Num_2 - Num_1 overwrites Num_2
O_flow equ 9
;其它寄存器自己定义
BCDSub
movf Num_1,w
subwf Num_2
clrf Num_1
rlf Num_1
btfss STATUS,DC
goto adjst1
btfss Num_2,3 ; Adjust LSD of Result
goto Over_1
btfsc Num_2,2
goto adjst1 ; Adjust LSD of Result
btfss Num_2,1
goto Over_1 ; No : Go for MSD
adjst1
movlw 6
subwf Num_2
Over_1
btfss Num_1,0 ; CY = 0 ?
goto adjst2 ; Yes, adjust MSD of result
clrf Num_1
btfss Num_2,7 ; No, test for MSD >9
RETLW 0
btfsc Num_2,6
goto adjst2
btfss Num_2,5
RETLW 0
adjst2
movlw 60 ; add 6 to MSD
subwf Num_2
clrf Num_1
btfss STATUS,CARRY ; test if underflow
RETLW 0
movlw 1
movwf Num_1
Over
RETLW 0
; 测试程序(注意用法,Num_2-Num_1=Num_2)
main
movlw 23
movwf Num_1 ; Set Num_1 = 23
movlw 99
movwf Num_2 ; Set Num_2 = 99
call BCDSub ; After subtraction, Num_2 = 76 ( 99-23 )
; ; and Num_1 = 0 ( indicates positive result )
self goto self ; 如不是测试程序,本句无用
org 1FF
goto main
END
