0xff
#define Read_Data 0x03 //读取存储器数据
#define HighSpeedReadData 0x0B //快速读取存储器数据
#define SectorErace_4KB 0x20 //扇区擦除
#define BlockErace_32KB 0x52 //32KB块擦除
#define BlockErace_64KB 0xD8 //64KB块擦除
#define ChipErace 0x60 //片擦除
#define Byte_Program 0x02 //页面编程--写数据
#define AAI_WordProgram 0xAD
#define ReadStatusRegister 0x05 //读状态寄存器
#define EnableWriteStatusRegister 0x50
#define WriteStatusRegister 0x01 //写状态寄存器
#define WriteEnable 0x06 //写使能,设置状态寄存器
#define WriteDisable 0x04 //写禁止
#define ReadDeviceID 0xAB //获取设备ID信息
#define ReadJedec_ID 0x9F //JEDEC的ID信息
#define EBSY 0X70
#define DBSY 0X80
//初始化SPI口
void SPI2init(void)
SPI_InitTypeDef SPI_InitStructure;
GPIO_InitStructure.GPIO_Pin = GPIO_SCK | GPIO_MISO | GPIO_MOSI;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_CS;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIO_PORT_CS, &GPIO_InitStructure);
SST25V_CS_HIGH();
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI2, &SPI_InitStructure);
SPI_Cmd(SPI2, ENABLE);
//flash初始化
void SST25V_Init(void)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
GPIO_Init(GPIOD, &GPIO_InitStructure);
// GPIO_ResetBits(GPIOD, GPIO_Pin_15); //关闭Flash电源
// Delay(10); //延时10mS
GPIO_SetBits(GPIOD, GPIO_Pin_15); //打开Flash电源
//GPIO_ResetBits(GPIOC, GPIO_Pin_8);
SPI2init();
SST25V_CS_HIGH();
SST25V_EnableWriteStatusRegister(); //使能写状态寄存器
SST25V_WriteStatusRegister(0); //写状态寄存器 设置 BPL BP3 BP2 BP1 BP0 0 0 0 0 0
SST25V_DBSY();
//读字节,参数:地址
u8 SST25V_ByteRead(u32 ReadAddr)
u8 Temp = 0;
SST25V_CS_LOW();
SPI_Flash_SendByte(Read_Data);
SPI_Flash_SendByte((ReadAddr & 0xFF0000) >> 16);
SPI_Flash_SendByte((ReadAddr& 0xFF00) >> 8);
SPI_Flash_SendByte(ReadAddr & 0xFF);
Temp = SPI_Flash_ReceiveByte();
SST25V_CS_HIGH();
return Temp;
//读字节串,参数:起始地址、读入缓冲、读取长度
void SST25V_BufferRead(u32 ReadAddr, u8* pBuffer, u16 NumByteToRead)
SST25V_CS_LOW();
while(NumByteToRead--)
*pBuffer = SPI_Flash_ReceiveByte();
pBuffer++;
SST25V_CS_HIGH();
//高速读字节串,参数:起始地址、读入缓冲、读取长度
void SST25V_HighSpeedBufferRead( u32 ReadAddr,u8* pBuffer, u16 NumByteToRead)
SST25V_CS_LOW();
SPI_Flash_SendByte(HighSpeedReadData);
SPI_Flash_SendByte(Dummy_Byte);
pBuffer++;
SST25V_CS_HIGH();
//读字节,参数:地址
u8 SST25V_HighSpeedRead(u32 ReadAddr)
u32 Temp = 0;
SST25V_CS_LOW();
SST25V_CS_HIGH();
return Temp;
u8 SPI_Flash_SendByte(u8 byte)
while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
SPI_I2S_SendData(SPI2, byte);
while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET);
return SPI_I2S_ReceiveData(SPI2);
u8 SPI_Flash_ReceiveByte(void)
return (SPI_Flash_SendByte(Dummy_Byte));
//写字节,参数:待写字节、写入地址
void SST25V_ByteWrite(u8 Byte, u32 WriteAddr)
SST25V_WriteEnable();
SST25V_CS_LOW();
SPI_Flash_SendByte(Byte_Program);
SPI_Flash_SendByte((WriteAddr & 0xFF0000) >> 16);
SPI_Flash_SendByte((WriteAddr & 0xFF00) >> 8);
SPI_Flash_SendByte(WriteAddr & 0xFF);
SPI_Flash_SendByte(Byte);
SST25V_CS_HIGH();
SST25V_WaitForWriteEnd();
SST25V_WriteDisable();
////写字节串,参数:起始地址、待写数据、写入长度
void SST25V_BufferWrite(u32 WriteAddr,u8* pBuffer, u16 NumByteToWrite)
u16 i,length;
length=NumByteToWrite;
if(length%2!=0)length++; //不足双数补1
SST25V_Init();//
SST25V_CS_LOW();
SPI_Flash_SendByte(AAI_WordProgram);
SPI_Flash_SendByte(pBuffer[0]);
SPI_Flash_SendByte(pBuffer[1]);
SST25V_CS_HIGH();
SST25V_Wait_Busy_AAI();
for(i=2;i
SST25V_CS_LOW();
SPI_Flash_SendByte(pBuffer[i]);
SPI_Flash_SendByte(pBuffer[i+1]);
SST25V_CS_HIGH();
void SST25V_Wait_Busy_AAI(void)
while (SST25V_ReadStatusRegister() == 0x43)
SST25V_ReadStatusRegister();
// 扇区擦除4Kbit,参数:地址
void SST25V_SectorErase_4KByte(u32 Addr)
SST25V_Init();//
SST25V_CS_LOW();
SPI_Flash_SendByte(SectorErace_4KB);
SPI_Flash_SendByte((Addr & 0xFF0000) >> 16);
SPI_Flash_SendByte((Addr & 0xFF00) >> 8);
SPI_Flash_SendByte(Addr & 0xFF);
SST25V_CS_HIGH();
void SST25V_BlockErase_32KByte(u32 Addr)
SST25V_CS_LOW();
SPI_Flash_SendByte(BlockErace_32KB);
SST25V_CS_HIGH();
void SST25V_BlockErase_64KByte(u32 Addr)
SST25V_CS_LOW();
SPI_Flash_SendByte(BlockErace_64KB);
SST25V_CS_HIGH();
void SST25V_ChipErase(void)
SST25V_Init();
SST25V_CS_LOW();
SPI_Flash_SendByte(ChipErace);
SST25V_CS_HIGH();
u8 SST25V_ReadStatusRegister(void)
u8 StatusRegister = 0;
SST25V_CS_LOW();
SPI_Flash_SendByte(ReadStatusRegister);
StatusRegister = SPI_Flash_ReceiveByte();
SST25V_CS_HIGH();
return StatusRegister;
void SST25V_WriteEnable(void)
SST25V_CS_LOW();
SPI_Flash_SendByte(WriteEnable);
SST25V_CS_HIGH();
void SST25V_WriteDisable(void)
SST25V_CS_LOW();
SPI_Flash_SendByte(WriteDisable);
SST25V_CS_HIGH();
void SST25V_EnableWriteStatusRegister(void)
SST25V_CS_LOW();
SPI_Flash_SendByte(EnableWriteStatusRegister);
SST25V_CS_HIGH();
void SST25V_WriteStatusRegister(u8 Byte)
SST25V_CS_LOW();
SPI_Flash_SendByte(WriteStatusRegister);
SST25V_CS_HIGH();
void SST25V_WaitForWriteEnd(void)
u8 FLASH_Status = 0;
SST25V_CS_LOW();
do
FLASH_Status = SPI_Flash_SendByte(Dummy_Byte);
} while((FLASH_Status & WriteStatusRegister)!=0);
SST25V_CS_HIGH();
void SST25V_EBSY(void)
SST25V_CS_LOW();
SPI_Flash_SendByte(EBSY);
SST25V_CS_HIGH();
void SST25V_DBSY(void)
SST25V_CS_LOW();
SPI_Flash_SendByte(DBSY);
SST25V_CS_HIGH();
