#define I2C_Speed 100000
#define I2C_EE I2C1
#define uStatus0x80
#definedTime 5
#define I2C_EE_GPIO GPIOB
#define I2C_EE_SCL GPIO_Pin_5
#define I2C_EE_SDA GPIO_Pin_4
#define I2C_EE_CLK RCC_APB1Periph_I2C1
#define SCL_H GPIOB->BSRR = GPIO_Pin_5
#define SCL_L GPIOB->BRR = GPIO_Pin_5
#define SDA_H GPIOB->BSRR = GPIO_Pin_4
#define SDA_L GPIOB->BRR = GPIO_Pin_4
#define SCL_read GPIOB->IDR & GPIO_Pin_5
#define SDA_read GPIOB->IDR & GPIO_Pin_4
static unsigned int cntForInitial = 0;
static unsigned char fSigStatus = 0;
//static bool LedStatus = true;
void I2C_Init()
//* Configure I2C_EE pins: SCL and SDA
GPIO_InitStructure.GPIO_Pin = I2C_EE_SCL | I2C_EE_SDA;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
GPIO_Init(I2C_EE_GPIO, &GPIO_InitStructure);
static void i2c_start()
SDA_H;
SCL_H;
DelayUs(dTime);
SDA_L;
DelayUs(dTime);
SCL_L;
DelayUs(dTime);
//LedStatus = !LedStatus;
//f_LCT1(LedStatus);
Fuction:
Stop i2c
static void i2c_stop()
SDA_L;
SCL_H;
DelayUs(dTime);
SDA_H;
DelayUs(dTime);
SCL_H;
DelayUs(dTime);
Fuction:
i2c Master wait for ack
Only ack
static unsigned char i2c_rd_ack()
unsigned char flag = 0;
SDA_H;
SCL_H;
DelayUs(dTime/2);
flag = SDA_read;
DelayUs(dTime/2);
SCL_L;
DelayUs(dTime/2);
if(flag == 1)
return 0;
return 1;
Fuction:
i2c Byte transmission
Only Send,no ack,no stop
static unsigned char i2c_sb(unsigned char Byte)
unsigned char cnt;
SCL_L;
for(cnt=0;cnt<8;cnt++)
if(Byte&0x80)
SDA_H;
else
SDA_L;
DelayUs(dTime);
SCL_H;
DelayUs(dTime);
SCL_L;
Byte <<= 1;
DelayUs(dTime);
return i2c_rd_ack();
Fuction:
i2c Byte receive
Return Byte
static unsigned char i2c_rb()
unsigned char cnt;
unsigned char Byte=0;
SDA_H;
for(cnt=0;cnt<8;++cnt)
Byte <<= 1;
DelayUs(dTime);
SCL_H;
DelayUs(dTime);
if(SDA_read)
Byte |= 0x01;
SCL_L;
DelayUs(dTime);
return Byte;
Fuction:
i2c ACK Master send
static void i2c_wr_ack(unsigned char ACK)
if(ACK)
SDA_H;
else
SDA_L;
SCL_H;
DelayUs(dTime);
SCL_L;
DelayUs(dTime);
Fuction:
i2c Byte receive
Return Byte
uint8_t ReadReg(unsigned int addr)
uint8_t temp;
i2c_start();
if(!i2c_sb(BRG_DEV_ADDR))
i2c_stop();
return 0;
if(!i2c_sb((uint8_t)(addr >> 8)))
i2c_stop();
return 0;
if(!i2c_sb((uint8_t)(addr & 0xFF)))
i2c_stop();
return 0;
i2c_start();
if(!i2c_sb(BRG_DEV_ADDR |0x01))
i2c_stop();
return 0;
temp = i2c_rb();
i2c_wr_ack(1);
i2c_stop();
return temp;
unsigned char WriteReg8(unsigned int addr,unsigned char wData)
i2c_start();
i2c_stop();
return 0;
if(!i2c_sb((unsigned char)(addr >> 8)))
i2c_stop();
return 0;
if(!i2c_sb((unsigned char)(addr & 0xFF)))
i2c_stop();
return 0;
if(!i2c_sb((unsigned char)(wData)))
i2c_stop();
return 0;
i2c_stop();
//DelayUs(1);
return 1;
unsigned char WriteReg16(unsigned int addr,unsigned char wData1,unsigned char wData2)
i2c_start();
i2c_stop();
return 0;
i2c_stop();
return 0;
i2c_stop();
return 0;
if(!i2c_sb((unsigned char)(wData2)))
i2c_stop();
return 0;
if(!i2c_sb((unsigned char)(wData1)))
i2c_stop();
return 0;
i2c_stop();
DelayUs(1);
return 1;
unsigned char WriteReg32(unsigned int addr,unsigned char wData1,unsigned char wData2,unsigned char wData3,unsigned char wData4)
i2c_start();
i2c_stop();
return 0;
i2c_stop();
return 0;
i2c_stop();
return 0;
if(!i2c_sb((unsigned char)(wData4)))
i2c_stop();
return 0;
if(!i2c_sb((unsigned char)(wData3)))
i2c_stop();
return 0;
i2c_stop();
return 0;
i2c_stop();
return 0;
i2c_stop();
DelayUs(1);
return 1;
