单片机 > 单片机程序设计 > 详情
STM32 外部中断的使用
发布时间:2020-05-18 发布时间:
例程名称:外部中断实验
作    者:tkzsld(sky)
实验硬件:火牛开发板
硬件连接:指示灯连接  PD9
          按钮连接    PA8
功能描述:本例程实现外部中断的输入试验,
按键次数 1:PD8 PD9  ON       2:PD8 PD9  OFF
         3:PD10 PD11  ON   4:PD10 PD11  OFF
   5:PD8-11  ON     6:PD8-11  OFF
   7: PB5 BEEP ON    8 :BEEP  OFF
#include     // STM32F10x Library Definitions
#include "STM32_Init.h"       // STM32 Initialization
u8 flag=0;
void beep(void);
void ledblink(void);
void Delay(vu16 cnt) {
uint16 i,j;
for (i=0;i { for (j=0;j<1000;j++)
void RCC_Configuration(void)
    ErrorStatus HSEStartUpStatus;
    //使能外部晶振
    RCC_HSEConfig(RCC_HSE_ON);
    //等待外部晶振稳定
    HSEStartUpStatus = RCC_WaitForHSEStartUp();
    //如果外部晶振启动成功,则进行下一步操作
    if(HSEStartUpStatus==SUCCESS)
        //设置HCLK(AHB时钟)=SYSCLK
        RCC_HCLKConfig(RCC_SYSCLK_Div1);
        //PCLK1(APB1) = HCLK/2
        RCC_PCLK1Config(RCC_HCLK_Div2);
        //PCLK2(APB2) = HCLK
        RCC_PCLK2Config(RCC_HCLK_Div1);
        RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_4);
        //启动PLL
        RCC_PLLCmd(ENABLE);
        //等待PLL稳定
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
        //系统时钟SYSCLK来自PLL输出
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
        //切换时钟后等待系统时钟稳定
        while(RCC_GetSYSCLKSource()!=0x08);
  //给GPIOA和重映射提供时钟,注意:一定要设置RCC_APB2Periph_AFIO
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO , ENABLE);
 void GPIO_Configuration(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOA,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_9|GPIO_Pin_8|GPIO_Pin_10|GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_5;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
void EXTI_Configuration(void)
  EXTI_InitTypeDef  EXTI_InitStructure;
 GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource8);
 EXTI_ClearITPendingBit(EXTI_Line8);
 EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
 EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
 EXTI_InitStructure.EXTI_Line =EXTI_Line8;
 EXTI_InitStructure.EXTI_LineCmd = ENABLE;
 EXTI_Init(&EXTI_InitStructure);
 void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);           //抢占式优先级别设置为无抢占优先级
  NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQChannel;    //指定中断源
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;        //指定响应优先级别1
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;         //使能外部中断通道8
  NVIC_Init(&NVIC_InitStructure);
  // EXTI_GenerateSWInterrupt(EXTI_Line8);
int main (void)
 RCC_Configuration();  //配置时钟
 GPIO_Configuration(); //配置IO口
 NVIC_Configuration(); //中断配置
 EXTI_Configuration(); //外部中断配置
 while(1)
  switch(flag)
   case 0: GPIO_WriteBit(GPIOD, GPIO_Pin_8|GPIO_Pin_9,(BitAction)1);break;
  //Delay(1000);
   case 1: GPIO_WriteBit(GPIOD, GPIO_Pin_9|GPIO_Pin_8,(BitAction)0);break;
  //Delay(1000);
   case 2: GPIO_WriteBit(GPIOD, GPIO_Pin_10|GPIO_Pin_11,(BitAction)1); break;
   case 3: GPIO_WriteBit(GPIOD, GPIO_Pin_10|GPIO_Pin_11,(BitAction)0);  break;
   case 4: GPIO_WriteBit(GPIOD, GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11,(BitAction)1);  break;
   case 5: GPIO_WriteBit(GPIOD, GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11,(BitAction)0);  break;
   case 6: beep();break;
   case 7: ledblink();break;
   case 8: GPIO_WriteBit(GPIOB, GPIO_Pin_5,(BitAction)0);break;
   default: flag=0;break;
void EXTI9_5_IRQHandler(void)
   if(EXTI_GetITStatus(EXTI_Line8) != RESET)
    Delay(100);
     //添加中断处理程序
  flag++;
     EXTI_ClearFlag(EXTI_Line8);          //清除中断标志(必须)
//     EXTI_ClearITPendingBit(EXTI_Line8);
void ledblink()
  u16 k;
  for(k=0;k<100;k=k+5)
   Delay(1000);
   Delay(1000);
void beep(void)
    GPIO_WriteBit(GPIOB, GPIO_Pin_5,(BitAction)1);
 Delay(1000);
可升级和可配置的PSoC62系列MCU平台架构
