最近因为项目成本需要,必须使用片内晶振作为系统的时钟源,所以对正点原子的项目模板时钟配置做了一些修改。使时钟倍频至64MHz供系统使用。
有需要的同学可以参考一下,代码如下:
#if defined (STM32F10X_LD_VL) || (defined STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
/* #define SYSCLK_FREQ_HSE HSE_VALUE */
#define SYSCLK_FREQ_24MHz 24000000
#else
/* #define SYSCLK_FREQ_24MHz 24000000 */
/* #define SYSCLK_FREQ_36MHz 36000000 */
/* #define SYSCLK_FREQ_48MHz 48000000 */
/* #define SYSCLK_FREQ_56MHz 56000000 */
/* #define SYSCLK_FREQ_72MHz 72000000 */
#endif
这里先将宏定义注释掉;
#ifdef SYSCLK_FREQ_HSE
uint32_t SystemCoreClock = SYSCLK_FREQ_HSE; /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_24MHz
uint32_t SystemCoreClock = SYSCLK_FREQ_24MHz; /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_36MHz
uint32_t SystemCoreClock = SYSCLK_FREQ_36MHz; /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_48MHz
uint32_t SystemCoreClock = SYSCLK_FREQ_48MHz; /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_56MHz
uint32_t SystemCoreClock = SYSCLK_FREQ_56MHz; /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_72MHz
uint32_t SystemCoreClock = SYSCLK_FREQ_72MHz; /*!< System Clock Frequency (Core Clock) */
#else /*!< HSI Selected as System Clock source */
//uint32_t SystemCoreClock = HSI_VALUE; /*!< System Clock Frequency (Core Clock) */
uint32_t SystemCoreClock = 64000000;
#endif
接着将SystemCoreClock替换为64MHz;
/*使用内部RC振荡器,设置系统时钟为64MHz*/
static void Intn_RC_Init(void)
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY)== RESET);
RCC_HCLKConfig(RCC_SYSCLK_Div1); //设置AHB时钟(HCLK) = 系统时钟
RCC_PCLK2Config(RCC_HCLK_Div1); //设置AHB2时钟 = HCLK
RCC_PCLK1Config(RCC_HCLK_Div1); //设置AHB1时钟 = HCLK
FLASH_SetLatency(FLASH_Latency_2); //设置FLASH存储器延时时钟周期数
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2, RCC_PLLMul_16); //设置PLL时钟源及倍频系数,频率为8/2*16=64MHz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
这样就完成了系统时钟的配置!
关键字:STM32F1 HSI配置 系统时钟『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
