#include "main.h"
modbus RTU 的C51程序
单片机89S52
通信波特率 9600 8位数据 1位停止位 偶校验 485通位接口
单片机控制板地址 localAddr(变量)
通信可设置数据的地址:
字地址 0 - 255 (只取16位的低8位)
位地址 0 - 255 (只取16位的低8位)
uint32 dwTickCount,dwIntTick; //时钟
uint8 idata sendBuf[16],receBuf[16]; //发送接收缓冲区
uint8 idata checkoutError; // ==2 偶校验错
uint8 idata receTimeOut; //接收超时
uint8 idata c10ms; //10ms 计时
bit b1ms,bt1ms,b10ms,bt10ms,b100ms,bt100ms; //定时标志位
// 串行中断程序
void commIntProc() interrupt 4
if(TI)
TI = 0;
if(sendPosi < sendCount)
sendPosi++;
ACC = sendBuf[sendPosi];
TB8 = P; //加上校验位
SBUF = sendBuf[sendPosi];
else
b485Send = 0; //发送完后将485置于接收状态
receCount = 0; //清接收地址偏移寄存器
checkoutError = 0;
else if(RI)
RI = 0;
receTimeOut = 10; //通讯超时值
receBuf[receCount] = SBUF;
ACC = receBuf[receCount];
if(P != RB8)
checkoutError = 2; //偶校验出错
receCount++; //接收地址偏移寄存器加1
receCount &= 0x0f; //最多一次只能接收16个字节
} // void CommIntProc()
//定时器0 1ms 中断
void timer0IntProc() interrupt 1
TL0 = TIMER_LOW;
TH0 = TIMER_HIGHT;
dwIntTick++;
bt1ms = 1;
c10ms++;
if(c10ms >= 10)
c10ms = 0; //10ms计时器清零
bt10ms = 1;
} // void Timer0IntProc()
//外部中断0
void intEx0Proc(void) interrupt 0
//计数器1中断
void counter1IntProc(void) interrupt 3 using 1
//定时处理
void timeProc(void)
static uint8 c200ms;
bWatchDog = ~ bWatchDog; //看门狗取反
b1ms = 0;
b10ms = 0;
b100ms = 0;
ET0 = 0;
dwTickCount = dwIntTick;
ET0 = 1;
if(bt1ms)
bt1ms = 0;
b1ms = 1;
if(receTimeOut>0)
receTimeOut--;
if(receTimeOut==0 && receCount>0) //判断通讯接收是否超时
b485Send = 0; //将485置为接收状态
receCount = 0; //将接收地址偏移寄存器清零
checkoutError = 0;
if(bt100ms)
bt100ms = 0;
b100ms = 1;
if(bt10ms) //判断中断10ms标志位是否1
bt10ms = 0; //清中断10ms标志位
b10ms = 1;
c200ms++; //200ms计时器加1
if(c200ms >= 20) //判断是否计时到200ms
c200ms = 0; //清200ms计时器
bRunLED = ~bRunLED; //取反运行指示灯
} // void TimerProc(void)
//初始化串口
void initUart(void)
T2CON = 0x30; //T2 用于波特率 9600
RCAP2H = 0xff;
RCAP2L = 0xdc;
TR2 = 1;
//偶校验
SCON = 0xd0;
PCON = 0;
ES = 1;
}//void initUart(void)
//初始化中断
void initInt(void)
TMOD = 0x51;
TH0 = TIMER_HIGHT;
TL0 = TIMER_LOW;
TR0 = 1;
ET0 = 1;
TH1 = 0; //9600
TL1 = 0;
TR1 = 0; //定时器1用于计数定时器2用于波特
ET1 = 1;
//PT1 = 1;
IT0 = 1;
IT1 = 1;
EX0 = 0;
PX0 = 1;
EX1 = 0;
initUart();
EA = 1;
} // void initInt(void)
//初始化
void initProg(void)
initInt();
b485Send = 0;
void main(void)
initProg();
while(1)
timeProc();
checkComm0Modbus();
display();
