以51单片机为平台,用TFT画出实心矩形!
以下程序关键在于自己的应用,有多余的经历则可以深入研究!
关键在于用!!!
希望能给大家带来帮助
#include
#define uint unsigned int
#define uchar unsigned char
#define TYPE_LCD_DATA 1
#define TYPE_LCD_COMMAND 0
#define LCD_SIZE_X 128
#define LCD_SIZE_Y 160
#define DATA P0
sbit LCD_RST = P2^7; //RST 引脚定义
sbit LCD_RD = P3^2; //RD 引脚定义
sbit LCD_WR = P3^3; //WR 引脚定义
sbit LCD_RS = P2^5; //RS 引脚定义
sbit LCD_CS = P2^6; //CS 引脚定义
/////以上是代码转移的关键,要修改相应的端口
uint colors[]=
0xf800,0x07e0,0x001f,0xffe0,0x0000,0x07ff,0xf81f,0xffff
void delay_ms(uint ms)
unsigned char k;
while (ms--)
for (k = 0; k < 228; k++)
void LCD_Write(uchar type, uint value)
LCD_CS = 0;
LCD_RS = type; // 0: command 1: data
LCD_WR = 0;
DATA = (uchar)value;;
LCD_WR = 1;
LCD_CS = 1;
void LCD_Wirte_Data16(uint value) // color data
LCD_CS = 0;
LCD_RS = 1;
LCD_WR = 0;
LCD_WR = 1;
LCD_WR = 0;
DATA = (uchar)(value>>8) ;
LCD_WR = 1;
LCD_CS = 1;
void Reg_Write(uint reg,uint value)
LCD_Write(TYPE_LCD_COMMAND,reg);
LCD_Write(TYPE_LCD_DATA,value);
void LCD_SetRamAddr(uint xStart, uint xEnd, uint yStart, uint yEnd)
Reg_Write(0x09, xStart);
Reg_Write(0x10, yStart);
Reg_Write(0x11, xEnd);
Reg_Write(0x12, yEnd);
Reg_Write(0x18, xStart);
Reg_Write(0x19, yStart);
LCD_Write(TYPE_LCD_COMMAND,0x22); // 0x22
void LCD_init(void)
uint num;
Reg_Write(0x0001,0x0002); //MODE_SEL1
Reg_Write(0x0002,0x0012); //MODE_SEL2
Reg_Write(0x0003,0x0000); //MODE_SEL3
Reg_Write(0x0004,0x0010); //MODE_SEL3
LCD_SetRamAddr(0,127, 0,159);
for(num=20480;num>0;num--)
LCD_Wirte_Data16(0xffff);
Reg_Write(0x0005,0x0008); //VCO_MODE
Reg_Write(0x0007,0x007f); //VCOMHT_CTRL
Reg_Write(0x0008,0x0017); //VCOMLT_CTRL
Reg_Write(0x0009,0x0000); //write SRAM window start X point
Reg_Write(0x0010,0x0000); //write SRAM window start y point
Reg_Write(0x0011,0x0083); //write SRAM window end x point
Reg_Write(0x0012,0x009f); //write SRAM window end y point
Reg_Write(0x0017,0x0000); //SRAM contrl
Reg_Write(0x0018,0x0000); //SRAM x position
Reg_Write(0x0019,0x0000); //SRAM y position
Reg_Write(0x0006,0x00c5); //DAC_OP_CTRL2
delay_ms(10); //延时
void LCD_clear(uchar n)
uint num;
for(num=20480;num>0;num--) //160*128=20480
LCD_Wirte_Data16(colors[n]);
void LCD_Juxing(uint xStart, uint xEnd, uint yStart, uint yEnd,uchar n)
uint num,count;
LCD_SetRamAddr(xStart,xEnd, yStart,yEnd);
count=(xEnd-xStart)*(yEnd- yStart);
for(num=count;num>0;num--) //160*128=20480
void main()
P2 = 0xff;
P0 = 0xff;
LCD_init();
while(1)
LCD_Juxing(10, 120,10,150,3);
关键字:TFT 画出矩形 51单片机
