// main.c
[cpp] view plaincopyprint?
- #include
- #include "ControlRobot.h"
- #include
- #define DEBUG_PROTOCOL
- typedef unsigned char UCHAR8;
- typedef unsigned int UINT16;
- #undef TRUE
- #undef FALSE
- #define TRUE 1
- #define FALSE 0
- #define MEMORY_MODEL
- UINT16 MEMORY_MODEL delayVar1;
- UCHAR8 MEMORY_MODEL delayVar2;
- #define BAUD_RATE 0xF3
- #define USED_PIN 2
- #define PIN_GROUP_1 0
- #define PIN_GROUP_2 1
- #define GROUP_1_CONTROL_PIN P0
- #define GROUP_2_CONTROL_PIN P2
- #define STEERING_ENGINE_CYCLE 2000
- #define STEERING_ENGINE_INIT_DELAY 50
- #define STEERING_ENGINE_FULL_CYCLE ((STEERING_ENGINE_CYCLE) - (STEERING_ENGINE_INIT_DELAY))
- volatile UCHAR8 MEMORY_MODEL g_angle[2][ROBOT_JOINT_AMOUNT];
- volatile bit MEMORY_MODEL g_fillingBufferIndex = 0;
- volatile bit MEMORY_MODEL g_readyBufferIndex = 1;
- volatile bit MEMORY_MODEL g_swapBuffer = FALSE;
- volatile UINT16 MEMORY_MODEL g_diffAngle[USED_PIN][8];
- volatile UCHAR8 MEMORY_MODEL g_diffAngleMask[USED_PIN][8] =
- ROBOT_PIN_MASK_LEFT_SHOULDER_VERTICAL,
- ROBOT_PIN_MASK_LEFT_SHOULDER_HORIZEN,
- ROBOT_PIN_MASK_LEFT_ELBOW,
- ROBOT_PIN_MASK_RIGHT_SHOULDER_VERTICAL,
- ROBOT_PIN_MASK_RIGHT_SHOULDER_HORIZEN,
- ROBOT_PIN_MASK_RIGHT_ELBOW,
- ROBOT_PIN_MASK_LEFT_HIP_VERTICAL,
- ROBOT_PIN_MASK_RIGHT_HIP_VERTICAL
- ROBOT_PIN_MASK_LEFT_HIP_HORIZEN,
- ROBOT_PIN_MASK_LEFT_KNEE,
- ROBOT_PIN_MASK_LEFT_ANKLE,
- ROBOT_PIN_MASK_LEFT_FOOT,
- ROBOT_PIN_MASK_RIGHT_HIP_HORIZEN,
- ROBOT_PIN_MASK_RIGHT_KNEE,
- ROBOT_PIN_MASK_RIGHT_ANKLE,
- ROBOT_PIN_MASK_RIGHT_FOOT
- #ifdef DEBUG_PROTOCOL
- sbit P10 = P1 ^ 0; // 正在填充交换区1
- sbit P11 = P1 ^ 1; // 正在填充交换区2
- sbit P12 = P1 ^ 2; // 交换区变换
- sbit P13 = P1 ^ 3; // 协议是否正确
- #endif
- void Delay10us(UINT16 ntimes)
- for (delayVar1 = 0; delayVar1
- for (delayVar2 = 0; delayVar2
- _nop_();
- void InitPwmPollint()
- UCHAR8 i;
- UCHAR8 j;
- UCHAR8 k;
- UINT16 temp;
- for (i = 0; i
- for (j = 0; j
- for (k = j; k
- if (g_diffAngle[i][j] > g_diffAngle[i][k])
- temp = g_diffAngle[i][j];
- g_diffAngle[i][j] = g_diffAngle[i][k];
- g_diffAngle[i][k] = temp;
- temp = g_diffAngleMask[i][j];
- g_diffAngleMask[i][j] = g_diffAngleMask[i][k];
- g_diffAngleMask[i][k] = temp;
- for (i = 0; i
- for (j = 0; j
- if (INVALID_JOINT_VALUE == g_diffAngle[i][j])
- g_diffAngle[i][j] = STEERING_ENGINE_FULL_CYCLE;
- for (i = 0; i
- for (j = 7; j >= 1; --j)
- g_diffAngle[i][j] = g_diffAngle[i][j] - g_diffAngle[i][j - 1];
- void InitSerialPort()
- AUXR = 0x00;
- ES = 0;
- TMOD = 0x20;
- SCON = 0x50;
- TH1 = BAUD_RATE;
- TL1 = TH1;
- PCON = 0x80;
- EA = 1;
- ES = 1;
- TR1 = 1;
- void OnSerialPort() interrupt 4
- static UCHAR8 previousChar = 0;
- static UCHAR8 currentChar = 0;
- static UCHAR8 counter = 0;
- if (RI)
- RI = 0;
- currentChar = SBUF;
- if (PROTOCOL_HEADER[0] == currentChar) // 协议标志
- previousChar = currentChar;
- else
- if (PROTOCOL_HEADER[0] == previousChar && PROTOCOL_HEADER[1] == currentChar) // 协议开始
- counter = 0;
- g_swapBuffer = FALSE;
- else if (PROTOCOL_END[0] == previousChar && PROTOCOL_END[1] == currentChar) // 协议结束
- if (ROBOT_JOINT_AMOUNT == counter) // 协议接受正确
- if (0 == g_fillingBufferIndex)
- g_readyBufferIndex = 0;
- g_fillingBufferIndex = 1;
- else
- g_readyBufferIndex = 1;
- g_fillingBufferIndex = 0;
- g_swapBuffer = TRUE;
- P13 = 0;
- #endif
- else
- P13 = 1;
- #endif
- counter = 0;
- else // 接受协议正文
- if (counter
- g_angle[g_fillingBufferIndex][counter] = currentChar;
- ++counter;
- } // if (PROTOCOL_HEADER[0] == currentChar)
- SBUF = currentChar;
- while (!TI)
- TI = 0;
- } // (RI)
- void FillDiffAngle()
- // 设置舵机要调整的角度
- g_diffAngle[PIN_GROUP_1][ROBOT_PIN_INDEX_LEFT_SHOULDER_VERTICAL] = g_angle[g_readyBufferIndex][ROBOT_LEFT_SHOULDER_VERTICAL];
- g_diffAngle[PIN_GROUP_1][ROBOT_PIN_INDEX_LEFT_SHOULDER_HORIZEN] = g_angle[g_readyBufferIndex][ROBOT_LEFT_SHOULDER_HORIZEN];
- g_diffAngle[PIN_GROUP_1][ROBOT_PIN_INDEX_LEFT_ELBOW] = g_angle[g_readyBufferIndex][ROBOT_LEFT_ELBOW];
- g_diffAngle[PIN_GROUP_1][ROBOT_PIN_INDEX_RIGHT_SHOULDER_VERTICAL] = g_angle[g_readyBufferIndex][ROBOT_RIGHT_SHOULDER_VERTICAL];
- g_diffAngle[PIN_GROUP_1][ROBOT_PIN_INDEX_RIGHT_SHOULDER_HORIZEN] = g_angle[g_readyBufferIndex][ROBOT_RIGHT_SHOULDER_HORIZEN];
- g_diffAngle[PIN_GROUP_1][ROBOT_PIN_INDEX_RIGHT_ELBOW] = g_angle[g_readyBufferIndex][ROBOT_RIGHT_ELBOW];
- g_diffAngle[PIN_GROUP_1][ROBOT_PIN_INDEX_LEFT_HIP_VERTICAL] = g_angle[g_readyBufferIndex][ROBOT_LEFT_HIP_VERTICAL];
- g_diffAngle[PIN_GROUP_1][ROBOT_PIN_INDEX_RIGHT_HIP_VERTICAL] = g_angle[g_readyBufferIndex][ROBOT_RIGHT_HIP_VERTICAL];
- g_diffAngle[PIN_GROUP_2][ROBOT_PIN_INDEX_LEFT_HIP_HORIZEN] = g_angle[g_readyBufferIndex][ROBOT_LEFT_HIP_HORIZEN];
- g_diffAngle[PIN_GROUP_2][ROBOT_PIN_INDEX_LEFT_KNEE] = g_angle[g_readyBufferIndex][ROBOT_LEFT_KNEE];
- g_diffAngle[PIN_GROUP_2][ROBOT_PIN_INDEX_LEFT_ANKLE] = g_angle[g_readyBufferIndex][ROBOT_LEFT_ANKLE];
- g_diffAngle[PIN_GROUP_2][ROBOT_PIN_INDEX_LEFT_FOOT] = g_angle[g_readyBufferIndex][ROBOT_LEFT_FOOT];
- g_diffAngle[PIN_GROUP_2][ROBOT_PIN_INDEX_RIGHT_HIP_HORIZEN] = g_angle[g_readyBufferIndex][ROBOT_RIGHT_HIP_HORIZEN];
- g_diffAngle[PIN_GROUP_2][ROBOT_PIN_INDEX_RIGHT_KNEE] = g_angle[g_readyBufferIndex][ROBOT_RIGHT_KNEE];
- g_diffAngle[PIN_GROUP_2][ROBOT_PIN_INDEX_RIGHT_ANKLE] = g_angle[g_readyBufferIndex][ROBOT_RIGHT_ANKLE];
- g_diffAngle[PIN_GROUP_2][ROBOT_PIN_INDEX_RIGHT_FOOT] = g_angle[g_readyBufferIndex][ROBOT_RIGHT_FOOT];
- // 复位舵机管脚索引
- g_diffAngleMask[PIN_GROUP_1][ROBOT_PIN_INDEX_LEFT_SHOULDER_VERTICAL] = ROBOT_PIN_MASK_LEFT_SHOULDER_VERTICAL;
- g_diffAngleMask[PIN_GROUP_1][ROBOT_PIN_INDEX_LEFT_SHOULDER_HORIZEN] = ROBOT_PIN_MASK_LEFT_SHOULDER_HORIZEN;
- g_diffAngleMask[PIN_GROUP_1][ROBOT_PIN_INDEX_LEFT_ELBOW] = ROBOT_PIN_MASK_LEFT_ELBOW;
- g_diffAngleMask[PIN_GROUP_1][ROBOT_PIN_INDEX_RIGHT_SHOULDER_VERTICAL] = ROBOT_PIN_MASK_RIGHT_SHOULDER_VERTICAL;
- g_diffAngleMask[PIN_GROUP_1][ROBOT_PIN_INDEX_RIGHT_SHOULDER_HORIZEN] = ROBOT_PIN_MASK_RIGHT_SHOULDER_HORIZEN;
- g_diffAngleMask[PIN_GROUP_1][ROBOT_PIN_INDEX_RIGHT_ELBOW] = ROBOT_PIN_MASK_RIGHT_ELBOW;
- g_diffAngleMask[PIN_GROUP_1][ROBOT_PIN_INDEX_LEFT_HIP_VERTICAL] = ROBOT_PIN_MASK_LEFT_HIP_VERTICAL;
- g_diffAngleMask[PIN_GROUP_1][ROBOT_PIN_INDEX_RIGHT_HIP_VERTICAL] = ROBOT_PIN_MASK_RIGHT_HIP_VERTICAL;
- g_diffAngleMask[PIN_GROUP_2][ROBOT_PIN_INDEX_LEFT_HIP_HORIZEN] = ROBOT_PIN_MASK_LEFT_HIP_HORIZEN;
- g_diffAngleMask[PIN_GROUP_2][ROBOT_PIN_INDEX_LEFT_KNEE] = ROBOT_PIN_MASK_LEFT_KNEE;
- g_diffAngleMask[PIN_GROUP_2][ROBOT_PIN_INDEX_LEFT_ANKLE] = ROBOT_PIN_MASK_LEFT_ANKLE;
- g_diffAngleMask[PIN_GROUP_2][ROBOT_PIN_INDEX_LEFT_FOOT] = ROBOT_PIN_MASK_LEFT_FOOT;
- g_diffAngleMask[PIN_GROUP_2][ROBOT_PIN_INDEX_RIGHT_HIP_HORIZEN] = ROBOT_PIN_MASK_RIGHT_HIP_HORIZEN;
- g_diffAngleMask[PIN_GROUP_2][ROBOT_PIN_INDEX_RIGHT_KNEE] = ROBOT_PIN_MASK_RIGHT_KNEE;
- g_diffAngleMask[PIN_GROUP_2][ROBOT_PIN_INDEX_RIGHT_ANKLE] = ROBOT_PIN_MASK_RIGHT_ANKLE;
- g_diffAngleMask[PIN_GROUP_2][ROBOT_PIN_INDEX_RIGHT_FOOT] = ROBOT_PIN_MASK_RIGHT_FOOT;
- #define PWM_STEERING_ENGINE(group)
- counter = STEERING_ENGINE_INIT_DELAY;
- for (i = 0; i
- counter += g_diffAngle[PIN_GROUP_##group][i];
- for (i = 0; i
- GROUP_##group##_CONTROL_PIN = 0xFF;
- Delay10us(STEERING_ENGINE_INIT_DELAY);
- for (j = 0; j
- Delay10us(g_diffAngle[PIN_GROUP_##group][j]);
- GROUP_##group##_CONTROL_PIN &= ~(g_diffAngleMask[PIN_GROUP_##group][j]);
- Delay10us(STEERING_ENGINE_CYCLE - counter);
- void main()
- UCHAR8 i;
- UCHAR8 j;
- UINT16 counter;
- InitSerialPort();
- P1 = 0xFF;
- // 初始化舵机角度
- for (i = 0; i
- g_angle[0][i] = 45;
- g_angle[1][i] = 45;
- for (i = 0; i
- for (j = 0; j
- g_diffAngle[i][j] = 0;
- FillDiffAngle();
- InitPwmPollint();
- while (1)
- if (g_fillingBufferIndex)
- P11 = 0;
- P10 = 1;
- else
- P11 = 1;
- P10 = 0;
- if (g_swapBuffer)
- P12 = 0;
- else
- P12 = 1;
- #endif
- if (g_swapBuffer)
- FillDiffAngle();
- InitPwmPollint();
- PWM_STEERING_ENGINE(1)
- PWM_STEERING_ENGINE(2)
关键字:单片机 1 舵机调速 『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
