属于msp430的ad采样的应用。由于项目需要,在中断中对AWM3300模拟输入做了阈值检测。一般使用ad采样时,不需要在中断中做此处理。
使用器件型号:msp430F169/msp430F149,AWM3300@honeywell
典型应用电路:具体看AWM3300使用手册
#include "msp430x16x.h"
#include"AWM.h"
//标注CO2的代码与AWM3300无关
double CO2_o,ADC_CO2;//CO2
double ADC_Vol_speed=0,sum,ADC_temp;
int i,gas_rate;
double gas_flow_rate(double voltage)
if(voltage > VOL_SP800)
return (800 + (voltage - VOL_SP800)*200/(VOL_SP1000 - VOL_SP800));
if(voltage > VOL_SP700)
return (700 + (voltage - VOL_SP700)*100/(VOL_SP800 - VOL_SP700));
if(voltage > VOL_SP500)
return (500 + (voltage - VOL_SP500)*200/(VOL_SP700 - VOL_SP500));
if(voltage > VOL_SP400)
return (400 + (voltage - VOL_SP400)*100/(VOL_SP500 - VOL_SP400));
if(voltage > VOL_SP300)
return (300 + (voltage - VOL_SP300)*100/(VOL_SP400 - VOL_SP300));
if(voltage > VOL_SP200)
return (200 + (voltage - VOL_SP200)*100/(VOL_SP300 - VOL_SP200));
if(voltage > VOL_SP100)
return (100 + (voltage - VOL_SP100)*100/(VOL_SP200 - VOL_SP100));
if (voltage > VOL_SP0)
return (voltage - VOL_SP0)*100/(VOL_SP100 - VOL_SP0);
else
return 0;
void AWM3300_init(void)
WDTCTL=WDTPW+WDTHOLD;
P6SEL|=BIT0;//P6.0模拟ADC输入(上电后默认0为输入)
ADC12CTL0 &=~ ENC;
ADC12CTL0=SHT0_2+ADC12ON;//采样转换时间,默认参电1.5V
ADC12CTL0|=REFON+REF2_5V;//参电选择2.5V
// for ( i=0; i<0x3600; i++);
ADC12CTL1=SHP;//选用采样定时器作为触发信号
ADC12IE=BIT0;//使能1中断
ADC12MCTL0=SREF_1;
ADC12CTL0 |=ENC;//AD转换使能
int main(void)
AWM3300_init();
for(;;)
ADC12CTL0|=ADC12SC;//开始转换
_BIS_SR(CPUOFF+GIE);
if(ADC_Vol_speed!=0){
gas_rate=(int)gas_flow_rate(ADC_Vol_speed*1000);
ADC_Vol_speed=0;
// if(gas_rate!=0)
// return 0;
#pragma vector=ADC_VECTOR
__interrupt void ADC12_ISR(void)
ADC_temp=(double)ADC12MEM0/(double)0xfff*2.5*2;
if((double)ADC12MEM0>=2818){ //ad:2818-->vol:3.44/2
i++;
sum+=(double)ADC12MEM0;
if(i>=19){
ADC_Vol_speed=(sum/(double)0xfff)/20*2.5*2;
sum=0;
i=0;
ADC_CO2=(double)ADC12MEM0/(double)0xfff*2.5;//CO2
CO2_o=ADC_CO2*5000.0/3.0;//CO2
// ADC_Vol_speed=((double)ADC12MEM0/(double)0xfff)*2.5*2;
//if(ADC12MEM0<0x7ff)//max:0xfff,half:0x7ff 小于1/2AVCC
_BIC_SR_IRQ(CPUOFF);
