#define uint unsigned int
#define uchar unsigned char
#define ZKB 6 //占空比初始值设定
#define max_time 100 //设置超出时间
sbit gd1=P1^0; //光电开关被挡住是高电平,没有被挡住是低电平
sbit gd2=P1^1; //光电开关被挡住是高电平,没有被挡住是低电平
sbit en=P1^2; //步进电机使能端,高电平工作,低电平不工作
sbit zx=P1^3; //高电平步进电机正转,低电平步进电机反转
sbit clock=P1^4; //步进电机频率端口
sbit lcdrs=P2^3; //LCD1602端口定义
sbit lcdrw=P2^4; //LCD1602端口定义
sbit lcden=P2^5; //LCD1602端口定义
uchar k=0;
uchar j=0;
uchar flag=0; //标志位
uint avr_time; //定义平均时间
uchar num; //定义液晶显示循环变量
uint zheng=0,fan=0; //正反转次数置零
uint shijian[51]; //定义时间数组
uchar code table2[]="forward: "; //LCD1602显示数组
uchar code table3[]="backward: "; //LCD1602显示数组
uchar code table4[]=" error! "; //LCD1602显示数组
void timer_init()
TMOD=0x11; //定时器模式设置
TH0=0xFF; //写入定时器0初始值
TL0=0x9C;
TH1=(65536-50000)/256; //写入定时器1初始值
TL1=(65536-50000)%6;
ET0=1; //允许定时器0中断
TR0=1; //启动定时器0
ET1=1; //允许定时器1中断
TR1=1; //启动定时器1
EA=1; //允许总中断
uint data_pro(void)
uchar i;
uint avr=0;
for(i=1;i<51;i++)
avr+=shijian[i];
avr=avr/50;
return avr;
void delay_50us(uint t)
uint y;
for(;t>0;t--)
for(y=19;y>0;y--);
void write_com(uchar com)
lcdrs=0;
lcdrw=0;
lcden=0;
P0=com;
delay_50us(10);
lcden=1;
delay_50us(20);
lcden=0;
void write_data(uchar date)
lcden=0;
lcdrs=1;
lcdrw=0;
P0=date;
delay_50us(10);
lcden=1;
delay_50us(20);
lcden=0;
void init()
write_com(0x38);
delay_50us(100);
write_com(0x01);
delay_50us(100);
write_com(0x06);
delay_50us(100);
write_com(0x0f);
delay_50us(100);
void write_zheng(uchar add,uchar date)
uchar qian,bai,shi,ge;
qian=date/1000;
bai=date00/100;
shi=date0/10;
ge=date;
write_com(0x80+add);
write_data(0x30+qian);
write_data(0x30+bai);
write_data(0x30+shi);
write_data(0x30+ge);
void write_fan(uchar add,uchar date)
qian=date/1000;
bai=date00/100;
shi=date0/10;
ge=date;
write_com(0x80+0x40+add);
void main()
timer_init(); //定时器初始化
delay_50us(300); //液晶初始化前延时一段时间
init(); //液晶初始化
write_com(0x80); //写地址
for(num=0;num<16;num++) //显示
write_data(table2[num]);
delay_50us(100);
write_com(0x80+0x40);
write_data(table3[num]);
delay_50us(100);
write_zheng(12,zheng); //初始显示零
write_fan(12,fan); //初始显示零
en=1; //上电后,电机马上启动
zx=1; //正转
zheng++; //正转次数加1
write_zheng(12,zheng); //显示修改后,正转次数
while(1)
if(gd2==1) //碰到光电开关2
zx=0; //反转
fan++; //反转次数加1
write_fan(12,fan); //显示修改后,反转次数
if(gd1==1) //碰到光电开关1
TR1=0; //关定时器1
en=0; //停止电机转动
shijian[j++]=k; //记录一次时间
if(j==51) //记录完50次,求平均值
avr_time=data_pro();
if(flag==0) //标志位
k=0; //中断数据清0
TH1=(65536-50000)/256; //重装定时器初值
TR1=1; //再次启动定时器1
zx=1; //正转
en=1; //电机启动
zheng++; //正转次数加1
if(j>51) //记录完50次后,每次都要比较是否超出规定的时间
if((k-avr_time)>max_time) //如果大于额定时间
en=0; //电机停止转动
write_com(0x80+0x40);//液晶显示错误
write_data(table4[num]);
delay_50us(100);
void timer0() interrupt 1
static uchar i=0;
TH0=0xFF;
TL0=0x9C;
++i;
if (i>10) i=0;
if (i<=ZKB)
clock=0;
else
clock=1;
void timer1() interrupt 3
k++;
关键字:51单片机 家具门屉 耐用性 自动检测装置
