//AVR单片机课程设计程序 //名称:频率计 //硬件:ATMEGA16_FHz-QLD100623产品 8MHz 晶振 三位数码管显示 //程序说明:程序初调阶段,可测频率范围1Hz--65KHz 自动换档显示 //编写人:李春起 #include关键字:AVR 单片机 频率计#include //-------------位拉高-------------------------------------------- #define LED1_H PORTD|=BIT(PD4) #define LED2_H PORTD|=BIT(PD5) #define LED3_H PORTD|=BIT(PD6) #define AT1_H PORTA|=BIT(PA0) #define AT2_H PORTA|=BIT(PA1) #define AT3_H PORTA|=BIT(PA2) //-------------位拉低-------------------------------------------- #define LED1_L PORTD&=~BIT(PD4) #define LED2_L PORTD&=~BIT(PD5) #define LED3_L PORTD&=~BIT(PD6) #define AT1_L PORTA&=~BIT(PA0) #define AT2_L PORTA&=~BIT(PA1) #define AT3_L PORTA&=~BIT(PA2) #define NOP() asm("nop") #define uchar unsigned char #define uint unsigned int //==================声明全局变量==================================== uint data,F_data=0,F_data10K=0;F_data1M=0;//频率分段储存 uint decimal1,decimal2,decimal3; //===================数据表============================================== __flash uchar SEG[]={0X03,0x9f,0x25,0x0d,0x99,0x49,0x41,0x1f,0x01,0x09}; //==================mS延时子程序========================================= void delayms(uint m) { uint i,j; for(i=0;i =65535) { F_data10K=0; if(++F_data1M>=65535) { F_data1M=0; } } } //=====================定时器T1中断服务============================== #pragma interrupt_handler Timer1_Interrupt:7 void Timer1_Interrupt(void) { TCNT1 = 0X00;//计数数清0 F_data = TCNT0; F_data |= F_data10K<<8; TCNT0 = 0X00; F_data10K = 0; if(F_data<1000){decimal3=0;decimal2=0;decimal1=1; data=F_data;LED1_L;LED2_H;LED3_H;} if(F_data>=1000){decimal3=0;decimal2=1;decimal1=0; data=(F_data/10);LED1_H;LED2_L;LED3_H;} if(F_data>=10000){decimal3=1;decimal2=0;decimal1=0; data=(F_data/100);} //if(F_data>=65534){F_data = (F_data>>8);F_data |= F_data1M<<8; // F_data=(F_data/1000);} }
