1、先设置软件仿真 ,可参看STM32不完全手册的2.4的软件仿真这一章
Example functionality:
- Clock Settings:
- XTAL = 8.00 MHz
- SYSCLK = 72.00 MHz
- HCLK = SYSCLK = 72.00 MHz
- PCLK1 = HCLK/2 = 36.00 MHz
- PCLK2 = HCLK = 72.00 MHz
- ADCLK = PCLK2/6 = 12.00 MHz
- SYSTICK = HCLK/8 = 9.00 MHz
- TIM4 is running at 100Hz.
LEDs PB8, PB9 are dimmed using the PWM function of TIM4 channel3, channel4
The Timer program is available in different targets:
Simulator: - configured for software Simulator
MCBSTM32: - runs from Internal Flash located on chip
(used for production or target debugging)
第二、选择软件仿真
第三、编译程序,如果程序没有错的话,将出现以下线框编译信息,然后进入调试,点出红色的“D"按,如下图所示
第四步、把软件逻辑分析仪把,并把要观察的波形信号拉到逻辑分析仪里,如果进入调试状态下没有"sysbols"标签话,点击“View”菜单弹出来,从“Peripheral Register”里把要观察的(GPIOB_IDR输出的PWM信号会从这个寄存器反映出来)信号拖到逻辑析分析里, 或者直接添加PORTX.x引脚查看。
第五步、把不用的bit屏蔽掉,并按bit形式显示,配置如图
第六步,点“GO”按钮进入全速运行,OK,PWM波形出来了,用IN和OUT可以调扫描时间,如下图
关键字:MDK4中 逻辑分析仪 PWM波
