最近闲着没时的时候又写了个基于AT89C51单片机的电子时钟,采用6位12小时制显示,运用了6个共阳数码管。具体功能如下:上午第一个数码管显示A,下午显示P,第四个数码管显示分隔符“-”,并且一秒闪烁一次。按键SW0调节分钟,SW1调节小时。下面是C程序和硬件电路图:
#include
#include
#define uchar unsigned char
#define uint unsigned int
sbit MG=P1^0;
sbit MS=P1^1;
sbit MM=P1^2;
sbit HG=P1^3;
sbit HS=P1^4;
sbit SD=P1^5;
bit shan;
code uchar NUM[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar sec,min,hour;
uchar hour1;
void delay(uint a)
while(a--);
void init0 ()
TMOD=0x01;
TL0=0xb0;
TH0=0x3c;
TR0=1;
EA=1;
ET0=1;
void display_time()
P0=NUM[min%10];
MG=1;
delay(300);
P1=0x00;
P0=NUM[min/10];
MS=1;
delay(300);
P1=0x00;
P0=0xbf;
MM=shan;
delay(300);
P1=0x00;
if(hour>12)
hour1=hour-12;
else
hour1=hour;
P0=NUM[hour1%10];
HG=1;
delay(300);
P1=0x00;
P0=NUM[hour1/10];
HS=1;
delay(300);
P1=0x00;
if(hour>=12)
P0=0x8c;
SD=1;
delay(300) ;
P1=0x00;
else
P0=0x88;
SD=1;
delay(300);
P1=0x00;
void FT()
while(P3==0xfe)
display_time();
sec=0;
min++;
if(min==60)
min=0;
void ST()
while(P3==0xfd)
display_time();
hour++;
if(hour==24)
hour=0;
main()
init0();
hour=1;
while(1)
display_time();
if(P3==0xfe) FT();
if(P3==0xfd) ST();
}[page]
void zhongduan() interrupt 1
uchar a;
TL0=0xb0;
TH0=0x3c;
a++;
if(a==20)
a=0;
shan=!shan;
sec++;
if(sec==60)
sec=0;
min++;
if(min==60)
min=0;
hour++;
if(hour==24)
hour=0;
关键字:AT89C51 电子时钟
