jmp cfg org 03h clr 00h reti cfg: ;setb ea ; setb ex0 ; setb it0 mov dptr,#tab MM00: CLR 00H mm: mov a,r2 movc a,@a+dptr cpl a call hbit mov r4,a deC r2 mov a,r2 movc a,@a+dptr dec r2 cpl a call hbit jb 01h,gr0 mov p1,a mov p3,r4 jmp gr00 gr0:mov p2,a mov p0,r4 gr00: djnz r6,$ djnz r6,$ ;djnz r6,$ cjne r2,#0ffh,mmm mov p0,#0ffh mov p1,#0ffh mov p2,#0ffh mov p3,#0ffh jb 0e8h.3,$ ;检测是否低电平 mmm: jb 0e8h.3,MM00 ;检测是否低电平 jb 00h,mm setb 00h mov r2,#0ffh inc dptr inc dptr inc dptr inc dptr mov a,dph cjne a,#tab2/256,e0d mov dptr,#tab cpl 01h e0d: jmp mm hbit: ;这是一个位交换子程序,用来实现字倒着显示或者正着显示,倒着显示时适合电动机在上面挂起来安装的情况。 mov c,acc.0 mov b.7,c mov c,acc.1 mov b.6,c mov c,acc.2 mov b.5,c mov c,acc.3 mov b.4,c mov c,acc.4 mov b.3,c mov c,acc.5 mov b.2,c mov c,acc.6 mov b.1,c mov c,acc.7 mov b.0,c mov a,b ret org 200h;org 300h,下面是显示的数据内容,是用本站软件自动生成的供码,请自行修改,其中的0000000000数据是加进去的空白代码,用来显示开头和结尾的空白;;………………数据内容省略,请用本站的自动数码代码程序自动生成 tab: db 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 db 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 db 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 db 00h,04h,40h,04h,41h,04h,41h,04h db 41h,04h,41h,0fch,7fh,04h,41h,04h db 41h,04h,41h,04h,43h,0fch,41h,04h db 40h,04h,00h,0ch,00h,04h,00h,00h db 00h,00h,01h,00h,01h,00h,01h,00h db 01h,00h,01h,00h,01h,00h,01h,00h db 01h,00h,01h,00h,01h,00h,01h,00h db 01h,00h,03h,00h,01h,00h,00h,00h db 00h,00h,00h,00h,1fh,0f0h,12h,20h db 12h,20h,12h,20h,12h,20h,0ffh,0fch db 12h,22h,12h,22h,12h,22h,12h,22h db 1fh,0f2h,00h,02h,00h,0eh,00h,00h db 00h,80h,00h,80h,40h,80h,40h,80h db 40h,80h,40h,82h,40h,81h,47h,0feh db 48h,80h,50h,80h,60h,80h,40h,80h db 00h,80h,01h,80h,00h,80h,00h,00h db 10h,04h,1fh,0fch,00h,84h,01h,00h db 01h,00h,01h,04h,00h,0fch,00h,04h db 00h,00h,01h,00h,01h,00h,07h,0f8h db 01h,04h,01h,04h,00h,00h,00h,00h db 00h,00h,01h,00h,01h,00h,07h,0f8h db 01h,04h,01h,04h,00h,00h,00h,00h db 01h,01h,01h,0ffh,00h,85h,01h,04h db 01h,04h,00h,88h,00h,70h,00h,00h db 00h,00h,00h,00h,00h,00h,03h,0ch db 03h,0ch,00h,00h,00h,00h,00h,00h db 00h,00h,00h,06h,00h,18h,00h,60h db 01h,80h,06h,00h,18h,00h,20h,00h db 00h,00h,00h,06h,00h,18h,00h,60h db 01h,80h,06h,00h,18h,00h,20h,00h tab1:db 01h,0f0h,01h,0ch,00h,30h,01h,0c0h db 00h,30h,01h,0ch,01h,0f0h,01h,00h db 01h,0f0h,01h,0ch,00h,30h,01h,0c0h db 00h,30h,01h,0ch,01h,0f0h,01h,00h db 01h,0f0h,01h,0ch,00h,30h,01h,0c0h db 00h,30h,01h,0ch,01h,0f0h,01h,00h db 00h,00h,00h,0ch,00h,0ch,00h,00h db 00h,00h,00h,00h,00h,00h,00h,00h db 00h,00h,1fh,98h,10h,84h,11h,04h db 11h,04h,10h,88h,10h,70h,00h,00h tab2:end关键字:立体旋转 LED 汇编程序
