制作出来的篮球计数器实物图如下:
Altium Designer画的原理图和PCB图如下:
仿真原理图如下
单片机源程序如下:
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define out P0
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
void lcd_initial(void);
void check_busy(void);
void write_command(uchar com);
void write_data(uchar dat);
void string(uchar ad ,uchar *s);
void delay(uint);
uchar i;
void main(void)
lcd_initial();
while(1)
write_command(0x06);
string(0x82,"Name:HONG JIE");
write_command(0x04);
string(0xce,"987654321:QQ");
for(i=0;i<40;i++)
write_command(0x1c);
delay(50);
void delay(uint j)
uchar i=250;
for(;j>0;j--)
while(--i);
i=249;
while(--i);
i=250;
uchar dt;
do
dt=0xff;
E=0;
RS=0;
RW=1;
E=1;
dt=out;
}while(dt&0x80);
E=0;
check_busy();
E=0;
RS=0;
RW=0;
out=com;
E=1;
_nop_();
E=0;
delay(1);
check_busy();
E=0;
RS=1;
RW=0;
out=dat;
E=1;
_nop_();
E=0;
delay(1);
write_command(0x38);
write_command(0x0c);
write_command(0x01);
delay(1);
void string(uchar ad,uchar *s)
write_command(ad);
while(*s>0)
write_data(*s++);
delay(100);
