Warning[Pa082]: undefined behavior: the order of volatile accesses is undefined in this statement
运算符两边都是volatile变量的警告
这警告有意义.
用volatile修饰的变量一般不直接参与运算,volatile就以为着这个变量在运算过程中有可能已经改变了
例如:想计算a * b 要这样:
volatile unsigned char a; volatile unsigned char b; unsigned char x,y; x = a; y = b; return (x * y);
建议使用另外一个变量参与计算:
volatile char VVV = 9; char fun() { char xxx; char yyy = 9; xxx = VVV; return xxx * yyy }
