#include
#define uchar unsigned char
unsigned char rtemp,sflag;
unsigned char code Buffer[] = "Welcome To The MCU World.";//所要发送的数据
unsigned char *p;
unsigned char TestBuff[3];
unsigned char mode=0;
unsigned char ArrayIndex=0;
void SerialInit() //11.0592M晶振,波特率19200
TMOD=0x20; //设置定时器1工作方式为方式2
TH1=0xfd;
TL1=0xfd;
TR1=1; //启动定时器1
SM0=0; //串口方式1
SM1=1;
REN=1; //允许接收
PCON=0x80; //关倍频
ES=1; //开串口中断
EA=1; //开总中断
void SerialSend(unsigned char temp)
ES=0; //发送期间关闭串口中断
SBUF=temp;
while(!TI);
TI=0;
ES=1; //发送完成开串口中断
void SerialService() interrupt 4
if(RI==1)
RI=0;
if(mode==0)
{//如果处于通的测试模式
TestBuff[ArrayIndex]=SBUF; //读缓冲区
ArrayIndex++;
if(ArrayIndex==3)
sflag=1;
void main(void)
SerialInit();
p = Buffer;
while(*p != '\0')
SerialSend(*p);
p++;
ArrayIndex=0;
while(sflag)
p = TestBuff;
while(*p != '\0')
SerialSend(*p);
p++;
sflag=0;
