#include
#define uchar unsigned char
#define uint unsigned int
uchar Table[12]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x79};
uchar Data1[4]={10,0,5,0};
uchar Data2[4]={3,9,1,0};
uchar Key1,Key2;
void DelayMs(uchar i)
uchar j;
for(;i!=0;i--)
for(j=150;j!=0;j--);
void Display(uchar *p)
uchar i,sel=0x01;
for(i=0;i<4;i++)
PORTC=sel;
PORTA=0xff-Table[p[i]];
DelayMs(2);
sel=sel<<1;
void Sub_Process(uchar *p)
uchar temp;
temp=p[1]*10+p[2];
if(temp!=0)
temp=temp-1;
p[1]=temp/10;
p[2]=temp%10;
void Key_Process()
if(Key1==1)
Add_Process(Data1);
Key1=0;
if(Key2==1)
Sub_Process(Data1);
Key2=0;
void Init_IO(void)
DDRA=0xff;
PORTA=0xff;
DDRC=0xff;
PORTC=0xff;
DDRB=0x00;
PORTB=0x00;
DDRD=0xff;
PORTD=0xff;
void main(void)
Init_IO();
TCCR1A=0xc3;
TCCR1B=0x02;
DelayMs(50);
while(1)
Key_Process();
Set_Process(Data1);
Display(Data1);
