TX-1C板
操作并行模式的1602液晶
液晶第1,2脚是gnd和vcc
第3脚是对比度调节
第4脚是数据/指令选择端RS
第5脚是读写选择端R/W,我们这次只写不读,故直接接地
第6脚是读写使能EN
第7到14脚是数据口,我们接STC89C52RC的P0口
第15,16脚是背光源
最终液晶显示
Tom is playing the TNT game!
C代码
#include
#include "MY51.H"
void write_data(uchar dataValue); //写数据
void write_cmd(uchar cmdValue); //写指令
uchar code tableLCD1[] ={"Tom is playing"};
uchar code tableLCD2[] ={" the TNT game!"};
void lcdInit() //初始化函数
dula=0; //
wela=0; //防止数码管误显,浪费电流
lcdEN=low; //给高脉冲之前的状态
lcdRS=high; //初始给高电平,其实上电默认也是高电平
write_cmd(0x38); //液晶显示模式初始化
write_cmd(0x0c); //打开液晶,不显示光标,光标不闪烁
write_cmd(0x06); //地址指针加加,且光标加加
write_cmd(0x01); //液晶数据指针和显示清零
void write_cmd(uchar cmdValue) //写入指令
lcdRS=low; //刚上电时是高电平,低电平时是指令模式
P0=cmdValue;
delayms(1);
lcdEN=high; //一个高脉冲把数据读走
delayms(1);
lcdEN=low;
void write_data(uchar dataValue) //写入数据
lcdRS=high; //高电平是数据模式
P0=dataValue;
delayms(1);
lcdEN=high; //给一个高脉冲
delayms(1);
lcdEN=low;
void lcdShow(uchar* pValue) //液晶显示函数
while(*pValue!='\0')
write_data(*pValue);
pValue++;
void main()
lcdInit(); //初始化
lcdShow(tableLCD1); //显示第一行
write_cmd(0x80+0x40); //重新设置数据显示指针
lcdShow(tableLCD2); //显示第二行
while(1);
C代码
#ifndef _MY51_H_
#define _MY51_H_
#include
#include
typedef int int16 ;
typedef int INT16 ;
typedef unsigned int uint16 ;
typedef unsigned int UINT16 ;
typedef unsigned short uint ;
typedef unsigned short UINT ;
typedef unsigned short word ;
typedef unsigned short WORD ;
typedef unsigned long uint32 ;
typedef unsigned long UINT32 ;
typedef unsigned long DWORD ;
typedef unsigned long dword ;
typedef signed long int32 ;
typedef signed long INT32 ;
typedef float float32 ;
typedef double double64 ;
typedef signed char int8 ;
typedef signed char INT8 ;
typedef unsigned char byte ;
typedef unsigned char BYTE ; //WINDOWS的windef.h里面是这么定义的
typedef unsigned char uchar ;
typedef unsigned char UCHAR ;
typedef unsigned char UINT8 ;
typedef unsigned char uint8 ;
typedef unsigned char BOOL ; //windows中定义BOOL为int
typedef unsigned char bool ; //bool是c++的内置类型
#define TRUE 1
#define true 1
#define FALSE 0
#define false 0
#define open 1 //open和close用于 标志打开和关闭状态
#define OPEN 1
#define close 0
#define CLOSE 0
#define lock 0
#define start 1
#define START 1
#define stop 0
#define STOP 0
#define keyDown 0
#define keyUp 1
#define gnd 0 //接地
#define GND 0 //接地
#define high 1 //高电平
#define low 0 //低电平
#define yes 1
#define YES 1
#define no 0
#define NO 0
sbit dula =P2^6; //段选锁存器控制 控制笔段
sbit wela =P2^7; //位选锁存器控制 控制位置
#define led P1 //灯总线控制
sbit led0=P1^0; //8个led灯,阴极送低电平点亮
sbit led1=P1^1;
sbit led2=P1^2;
sbit led3=P1^3;
sbit led4=P1^4;
sbit led5=P1^5;
sbit led6=P1^6;
sbit led7=P1^7;
sbit keyS2=P3^4; //4个独立按键
sbit keyS3=P3^5;
sbit keyS4=P3^6;
sbit keyS5=P3^7;
sbit lcdEN=P3^4; //液晶通讯使能端en,高脉冲有效
sbit lcdRS=P3^5; //液晶第4脚,RS,低电平是指令模式,高电平是数据模式
//sbit lcdR/W //液晶第5脚,低电平是写入模式,因为我们只写不读,所以接地
sbit csda=P3^2; //DAC0832模数转换cs口
sbit adwr=P3^6; //ADC0804这个同DAC0832
sbit dawr=P3^6;
sbit adrd=P3^7; //ADC0804
sbit beep=P2^3; //蜂鸣器
void displaySMG(uint8 one,uint8 two,uint8 three,uint8 four,uint8 five,uint8 six,uint8 dot);
void delayms(uint16 ms);
void T0_Work();
void delayms(uint16 ms) //软延时函数
uint16 i,j;
for(i=ms;i>0;i--)
for(j=113;j>0;j--)
#define dark 0x11 //在段中,0x11是第17号元素,为0是低电平,数码管不亮
#define dotDark 0xff //小数点全暗时
uint8 code table[]= { //0~F外加小数点和空输出的数码管编码
0x3f , 0x06 , 0x5b , 0x4f , // 0 1 2 3
0x66 , 0x6d , 0x7d , 0x07 , // 4 5 6 7
0x7f , 0x6f , 0x77 , 0x7c , // 8 9 A B
0x39 , 0x5e , 0x79 , 0x71 , // C D E F
0x80 , 0x00 ,0x40 // . 空 负号 空时是第0x11号也就是第17号元素
uint8 dotTable[]={ //小数点位置
0xff , //全暗
0xfe , 0xfd , 0xfb , //1 2 3
0xf7 , 0xef , 0xdf //4 5 6
uint8 TH0Cout=0 ; //初值
uint8 TL0Cout=0 ;
uint16 T0IntCout=0; //中断计数
uint16 T0IntCountAll=0; //(N-1)/65536+1; //总中断次数
bool bT0Delay=false; //使用延时函数标志,初始未用
bool bT0Over=false; //中断处理函数执行结果之一
void startT0(uint32 ms) //开启定时器
float32 t=ms/1000.0; //定时时间
double64 fox =11.0592*(pow(10,6)); //晶振频率
uint32 N=(t*fox)/12 ; //定时器总计数值
TH0Cout =(65536-N%65536)/256; //装入计时值零头计数初值
TL0Cout =(65536-N%65536)%256;
T0IntCountAll=(N-1)/65536+1; //总中断次数
TMOD=TMOD | 0x01; //设置定时器0的工作方式为1
EA =open; //打开总中断
ET0=open; //打开定时器中断
TH0=TH0Cout; //定时器装入初值
TL0=TL0Cout;
TR0=start; //启动定时器
void delayT0(uint32 ms) //硬延时函数,自己乱写的不好用,求指点
startT0(ms); //启动定时器
bT0Delay=true; //告诉T0定时器,起用延时模式
while(bT0Over==false); //时间没到的话继续检测
bT0Over=false; //时间到了,让标志复位
void T0_times() interrupt 1 //T0定时器中断函数
T0IntCout++;
if(T0IntCout==T0IntCountAll) //达到总中断次数值
T0IntCout=0; //中断次数清零,重新计时
bT0Over=true; //时间真的到了
if(bT0Delay) //本次中断是用来延时的吗
TR0=stop; //如果是由延时函数开启T0的话,关闭T0
return;
TH0=TH0Cout; //循环定时的话要重装初值,每次定时1秒,重装一次
TL0=TL0Cout;
T0_Work(); //工作函数
void displaySMG(uint8 oneWela,uint8 twoWela,uint8 threeWela,uint8 fourWela,uint8 fiveWela,uint8 sixWela,uint8 dot)
//控制6位数码管显示函数,不显示的位用参数dark,保留ADC0804的片选信号
uint8 csadState=0x80&P0; //提取最高位,即ADC0804的片选信号
uint8 tempP0=((csadState==0)?0x7f:0xff); //数码管位选初始信号,阴极全置高电平
P0=tempP0; //0x7f表示数码管不亮,同时ADC0804片选有效
wela=1; //注:wela和dula上电默认为1
P0=tempP0;
wela=0;
P0=0; //由于数码管是共阴极的,阳极送低电平,灯不亮,防止灯误亮
dula=1;
P0=0;
dula=0; //段选数据清空并锁定
//////////////////////////oneWela
{ //消除叠影,数码管阴极置高电平,并锁存
P0=tempP0;
wela=1;
P0=tempP0;
wela=0;
P0=0; //低电平送到数码管阳极,避免数码管误亮
dula=1;
P0=table[oneWela]|((0x01&dot)?0x00:0x80); //送段数据,叠加小数点的显示
dula=0;
P0=tempP0; //送位数据前关闭所有显示,并保持csad信号
wela=1;
P0=tempP0 & 0xfe; //0111 1110最高位是AD片选,低6位是数码管位选,低电平有效
wela=0;
delayms(2);
/////////////////////////twoWela
{ //消除叠影
P0=tempP0;
wela=1;
P0=tempP0;
wela=0;
P0=0;
dula=1;
P0=table[twoWela]|((0x02&dot)?0x00:0x80);
dula=0;
P0=tempP0;
wela=1;
P0=tempP0 & 0xfd; //0111 1101
wela=0;
delayms(2);
/////////////////////////threeWela
{ //消除叠影
P0=tempP0;
wela=1;
P0=tempP0;
wela=0;
P0=0;
dula=1;
P0=table[threeWela]|((0x04&dot)?0x00:0x80);
dula=0;
P0=tempP0;
wela=1;
P0=tempP0 & 0xfb; //0111 1011
wela=0;
delayms(2);
/////////////////////////fourWela
{ //消除叠影
P0=tempP0;
wela=1;
P0=tempP0;
wela=0;
P0=0;
dula=1;
P0=table[fourWela]|((0x08&dot)?0x00:0x80);
dula=0;
P0=tempP0;
wela=1;
P0=tempP0 & 0xf7; //0111 0111
wela=0;
delayms(2);
/////////////////////////fiveWela
{ //消除叠影
P0=tempP0;
wela=1;
P0=tempP0;
wela=0;
P0=0;
dula=1;
P0=table[fiveWela]|((0x10&dot)?0x00:0x80);
dula=0;
P0=tempP0;
wela=1;
P0=tempP0 & 0xef; //0110 1111
wela=0;
delayms(2);
/////////////////////////sixWela
{ //消除叠影
P0=tempP0;
wela=1;
P0=tempP0;
wela=0;
P0=0;
dula=1;
P0=table[sixWela]|((0x20&dot)?0x00:0x80);
dula=0;
P0=tempP0;
wela=1;
P0=tempP0 & 0xdf; //0101 1111
wela=0;
delayms(2);
#endif
