#include #include #include #include #include #include #include #include #include #include #include #include
#include #include
/* For ts.dev.id.version */ #define S3C2410TSVERSION 0x0101
#define WAIT4INT(x) (((x)<<8) | \ S3C2410_ADCTSC_YM_SEN | S3C2410_ADCTSC_YP_SEN | S3C2410_ADCTSC_XP_SEN | \ S3C2410_ADCTSC_XY_PST(3))
#define AUTOPST (S3C2410_ADCTSC_YM_SEN | S3C2410_ADCTSC_YP_SEN | S3C2410_ADCTSC_XP_SEN | \ S3C2410_ADCTSC_AUTO_PST | S3C2410_ADCTSC_XY_PST(0))
static char *s3c2410ts_name = "s3c2410 TouchScreen";
static struct input_dev *dev; static long xp; static long yp; static int count;
extern struct semaphore ADC_LOCK; static int OwnADC = 0;
static void __iomem *base_addr;
static inline void s3c2410_ts_connect(void) { s3c2410_gpio_cfgpin(S3C2410_GPG12, S3C2410_GPG12_XMON); s3c2410_gpio_cfgpin(S3C2410_GPG13, S3C2410_GPG13_nXPON); s3c2410_gpio_cfgpin(S3C2410_GPG14, S3C2410_GPG14_YMON); s3c2410_gpio_cfgpin(S3C2410_GPG15, S3C2410_GPG15_nYPON); }
static void touch_timer_fire(unsigned long data) { unsigned long data0; unsigned long data1; int updown;
data0 = ioread32(base_addr+S3C2410_ADCDAT0); data1 = ioread32(base_addr+S3C2410_ADCDAT1);
updown = (!(data0 & S3C2410_ADCDAT0_UPDOWN)) && (!(data1 & S3C2410_ADCDAT0_UPDOWN));
if (updown) { if (count != 0) { long tmp; tmp = xp; xp = yp; yp = tmp; xp >>= 2; yp >>= 2;
#ifdef CONFIG_TOUCHSCREEN_MY2440_DEBUG struct timeval tv; do_gettimeofday(&tv); printk(KERN_DEBUG "T: %06d, X: %03ld, Y: %03ld\n", (int)tv.tv_usec, xp, yp); #endif
input_report_abs(dev, ABS_X, xp); input_report_abs(dev, ABS_Y, yp);
input_report_key(dev, BTN_TOUCH, 1); input_report_abs(dev, ABS_PRESSURE, 1); input_sync(dev); }
xp = 0; yp = 0; count = 0;
iowrite32(S3C2410_ADCTSC_PULL_UP_DISABLE | AUTOPST, base_addr+S3C2410_ADCTSC); iowrite32(ioread32(base_addr+S3C2410_ADCCON) | S3C2410_ADCCON_ENABLE_START,base_addr+S3C2410_ADCCON); } else { count = 0;
input_report_key(dev, BTN_TOUCH, 0); input_report_abs(dev, ABS_PRESSURE, 0); input_sync(dev);
iowrite32(WAIT4INT(0), base_addr+S3C2410_ADCTSC); if (OwnADC) { OwnADC = 0; up(&ADC_LOCK); } } }
static struct timer_list touch_timer = TIMER_INITIALIZER(touch_timer_fire, 0, 0);
static irqreturn_t stylus_updown(int irq, void *dev_id) { unsigned long data0; unsigned long data1; int updown;
if (down_trylock(&ADC_LOCK) == 0) { OwnADC = 1; data0 = ioread32(base_addr+S3C2410_ADCDAT0); data1 = ioread32(base_addr+S3C2410_ADCDAT1);
if (updown) { touch_timer_fire(0); } else { OwnADC = 0; up(&ADC_LOCK); } }
return IRQ_HANDLED; }
static irqreturn_t stylus_action(int irq, void *dev_id) { unsigned long data0; unsigned long data1;
if (OwnADC) { data0 = ioread32(base_addr+S3C2410_ADCDAT0); data1 = ioread32(base_addr+S3C2410_ADCDAT1);
xp += data0 & S3C2410_ADCDAT0_XPDATA_MASK; yp += data1 & S3C2410_ADCDAT1_YPDATA_MASK; count++;
if (count iowrite32(S3C2410_ADCTSC_PULL_UP_DISABLE | AUTOPST, base_addr+S3C2410_ADCTSC); iowrite32(ioread32(base_addr+S3C2410_ADCCON) | S3C2410_ADCCON_ENABLE_START,base_addr+S3C2410_ADCCON); } else { mod_timer(&touch_timer, jiffies+1); iowrite32(WAIT4INT(1), base_addr+S3C2410_ADCTSC); } }
static struct clk *adc_clock;
static int __init s3c2410ts_init(void) { struct input_dev *input_dev;
adc_clock = clk_get(NULL, "adc"); if (!adc_clock) { printk(KERN_ERR "failed to get adc clock source\n"); return -ENOENT; } clk_enable(adc_clock);
base_addr=ioremap(S3C2410_PA_ADC,0x20); if (base_addr == NULL) { printk(KERN_ERR "Failed to remap register block\n"); return -ENOMEM; }
/* Configure GPIOs */ s3c2410_ts_connect();
iowrite32(S3C2410_ADCCON_PRSCEN | S3C2410_ADCCON_PRSCVL(0xFF),\ base_addr+S3C2410_ADCCON); iowrite32(0xffff, base_addr+S3C2410_ADCDLY); iowrite32(WAIT4INT(0), base_addr+S3C2410_ADCTSC);
/* Initialise input stuff */ input_dev = input_allocate_device();
if (!input_dev) { printk(KERN_ERR "Unable to allocate the input device !!\n"); return -ENOMEM; }
dev = input_dev; dev->evbit[0] = BIT(EV_SYN) | BIT(EV_KEY) | BIT(EV_ABS); dev->keybit[BITS_TO_LONGS(BTN_TOUCH)] = BIT(BTN_TOUCH); input_set_abs_params(dev, ABS_X, 0, 0x3FF, 0, 0); input_set_abs_params(dev, ABS_Y, 0, 0x3FF, 0, 0); input_set_abs_params(dev, ABS_PRESSURE, 0, 1, 0, 0);
dev->name = s3c2410ts_name; dev->id.bustype = BUS_RS232; dev->id.vendor = 0xDEAD; dev->id.product = 0xBEEF; dev->id.version = S3C2410TSVERSION;
/* Get irqs */ if (request_irq(IRQ_ADC, stylus_action, IRQF_SHARED|IRQF_SAMPLE_RANDOM, "s3c2410_action", dev)) { printk(KERN_ERR "s3c2410_ts.c: Could not allocate ts IRQ_ADC !\n"); iounmap(base_addr); return -EIO; } if (request_irq(IRQ_TC, stylus_updown, IRQF_SAMPLE_RANDOM, "s3c2410_action", dev)) { printk(KERN_ERR "s3c2410_ts.c: Could not allocate ts IRQ_TC !\n"); iounmap(base_addr); return -EIO; }
printk(KERN_INFO "%s successfully loaded\n", s3c2410ts_name);
/* All went ok, so register to the input system */ input_register_device(dev);
return 0; }
static void __exit s3c2410ts_exit(void) { disable_irq(IRQ_ADC); disable_irq(IRQ_TC); free_irq(IRQ_TC,dev); free_irq(IRQ_ADC,dev);
if (adc_clock) { clk_disable(adc_clock); clk_put(adc_clock); adc_clock = NULL; }
input_unregister_device(dev); iounmap(base_addr); }
module_init(s3c2410ts_init); module_exit(s3c2410ts_exit); DE> |
