最近有个项目需要用到STM32F407ZET6这款芯片,其中有一个串口收发数据的应用。因为之前有用过STMF32F103ZET6通过DMA收发数据的方案,所以我打算移植之前的代码实现这个功能,STM32F103的DMA相关介绍参见STM32F103 DMA介绍
之前项目使用的代码如下:
* BSP_USART1_Init()
* Description : USART1初始化 RS232通信。
* Argument(s) : baud 波特率。
* Return(s) : none.
* Caller(s) : BSP_USART_Init().
* Note(s) : none.
static void BSP_USART1_Init(u32 baud)
USART_InitTypeDef bsp_usart_init;
GPIO_InitTypeDef bsp_usartpin_init;
//使能USART1时钟、使能USART1引脚时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
//初始化USART1引脚PA9 TX
bsp_usartpin_init.GPIO_Pin = GPIO_Pin_9;
bsp_usartpin_init.GPIO_Speed = GPIO_Speed_50MHz;
bsp_usartpin_init.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &bsp_usartpin_init);
//初始化USART1引脚PA10 RX
bsp_usartpin_init.GPIO_Pin = GPIO_Pin_10;
bsp_usartpin_init.GPIO_Mode = GPIO_Mode_IN_FLOATING;
//初始化USART1参数
bsp_usart_init.USART_BaudRate = baud;
bsp_usart_init.USART_WordLength = USART_WordLength_8b;
bsp_usart_init.USART_StopBits = USART_StopBits_1;
bsp_usart_init.USART_Parity = USART_Parity_No;
bsp_usart_init.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
bsp_usart_init.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_Init(USART1, &bsp_usart_init);
//初始化中断
BSP_NVIC_Init(USART1_IRQn, 1, 1);
//开启USART1总线空闲中断
USART_ITConfig(USART1,USART_IT_TC,DISABLE);
USART_ITConfig(USART1,USART_IT_RXNE,DISABLE);
USART_ITConfig(USART1,USART_IT_IDLE,ENABLE);
//串口接收DMA配置
BSP_DMAUsar1Rx_Init();
//串口发送DMA配置
BSP_DMAUsar1Tx_Init();
USART_DMACmd(USART1,USART_DMAReq_Rx,ENABLE); //采用DMA方式接收
//开启USART1
USART_Cmd(USART1, ENABLE);
//USART1接收DMA配置
static void BSP_DMAUsar1Rx_Init(void)
DMA_InitTypeDef DMA_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //启动DMA时钟
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)(&USART1->DR); //外设地址
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)Uart1_Rx; //内存地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //dma传输方向单向
DMA_InitStructure.DMA_BufferSize = UART1_RX_LEN; //设置DMA在传输时缓冲区的长度
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //设置DMA的外设递增模式,一个外设
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //设置DMA的内存递增模式
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; //外设数据字长
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //内存数据字长
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; //设置DMA的传输模式
DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh; //设置DMA的优先级别
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //设置DMA的2个memory中的变量互相访问
DMA_Init(DMA1_Channel5,&DMA_InitStructure);
DMA_Cmd(DMA1_Channel5,ENABLE); //使能通道5
//USART1发送DMA配置
static void BSP_DMAUsar1Tx_Init(void)
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)(&USART1->DR); //DMA外设基地址
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)Uart1_Tx; //DMA内存基地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; //数据传输方向,从内存读取发送到外设
DMA_InitStructure.DMA_BufferSize = UART1_TX_LEN; //DMA通道的DMA缓存的大小
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不变
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; //数据宽度为8位
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //数据宽度为8位
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; //工作在正常模式
DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA通道 x拥有中优先级
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x没有设置为内存到内存传输
DMA_Init(DMA1_Channel4, &DMA_InitStructure); //根据DMA_InitStruct中指定的参数初始化DMA的通道USART1_Tx_DMA_Channel所标识的寄存器
//USART1 DMA发送指定长度的数据
//str:要发送的数据首地址
//cndtr:数据传输量
void BSP_DMAUsart1Puts(unsigned char *str,u8 cndtr)
memcpy(Uart1_Tx, str, cndtr);
USART_DMACmd(USART1,USART_DMAReq_Tx,ENABLE); //使能串口1的DMA发送
DMA_Cmd(DMA1_Channel4, DISABLE ); //关闭USART1 TX DMA1 所指示的通道
DMA_SetCurrDataCounter(DMA1_Channel4,cndtr); //DMA通道的DMA缓存的大小
DMA_Cmd(DMA1_Channel4, ENABLE); //使能USART1 TX DMA1 所指示的通道
//USART1中断函数。
void USART1_IRQHandler(void)
uint16_t i = 0;
OSIntEnter();
if(USART_GetITStatus(USART1, USART_IT_IDLE) != RESET)
//1.清除USART1接收完成中断
//USART_ClearFlag(USART1,USART_IT_IDLE);
USART1->SR;
USART1->DR; //清USART_IT_IDLE标志
//2.存储收到的数据内容、长度、标志位
DMA_Cmd(DMA1_Channel5,DISABLE); //关闭DMA
if(!Uart1_RxBuffer.RxFlag) //判断是否有数据包在处理
Uart1_RxBuffer.RxLen = UART1_RX_LEN -
DMA_GetCurrDataCounter(DMA1_Channel5); //计算接收数据包长度
for (i = 0;i < Uart1_RxBuffer.RxLen;i++) //将接收到的数据包缓存
Uart1_RxBuffer.buffer[i] = Uart1_Rx[i];
Uart1_RxBuffer.RxFlag = 1; //置位接收状态标志位
DMA_SetCurrDataCounter(DMA1_Channel5,UART1_RX_LEN); //设置传输数据长度
DMA_Cmd(DMA1_Channel5,ENABLE); //打开DMA
// 3. Send message to task_command_process
OSMboxPost(MboxCmdSet, &Uart1_RxBuffer.buffer[0]); // Inform App_TaskCommandProcess() that one command has arrived.
OSIntExit();
本以为F407按照上述这样设置应该就可以,可是移植过程中还是发现了两者之间很多的异同点。其中出现了两个问题:
1.接收数据出现了问题,只能接收一次;
2.只能发送一次数据。
最初代码如下:
uint8_t Uart6_Tx[UART6_TX_LEN] = {0}; //串口6发送DMA缓存
uint8_t Uart6_Rx[UART6_RX_LEN] = {0}; //串口6接收DMA缓存
//串口6接收缓存
COMx_RXBUFFER Uart6_RxBuffer;
static void BSP_Usart6_Init(u32 bound)
//GPIO端口设置
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE); //使能GPIOC时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART6,ENABLE); //使能USART6时钟
//串口6对应引脚复用映射
GPIO_PinAFConfig(GPIOC,GPIO_PinSource6,GPIO_AF_USART6); //GPIOC6 复用为USART6
GPIO_PinAFConfig(GPIOC,GPIO_PinSource7,GPIO_AF_USART6); //GPIOC7 复用为USART6
//USART6端口配置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; //GPIOC6
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //复用功能
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //速度50MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
GPIO_Init(GPIOC,&GPIO_InitStructure); //初始化PC6
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //GPIOC7
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; //浮空
GPIO_Init(GPIOC,&GPIO_InitStructure); //初始化PC7
//USART1 初始化设置
USART_InitStructure.USART_BaudRate = bound;//波特率设置
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式
USART_Init(USART6, &USART_InitStructure); //初始化串口1
// USART_Cmd(USART6, ENABLE); //使能串口1
// USART_ITConfig(USART6, USART_IT_RXNE, ENABLE);//开启相关中断
//Usart1 NVIC 配置
NVIC_InitStructure.NVIC_IRQChannel = USART6_IRQn;//串口1中断通道
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1;//抢占优先级3
NVIC_InitStructure.NVIC_IRQChannelSubPriority =2; //子优先级3
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器、
//开启USART6总线空闲中断
USART_ITConfig(USART6,USART_IT_TC,DISABLE);
USART_ITConfig(USART6,USART_IT_RXNE,DISABLE);
USART_ITConfig(USART6,USART_IT_TXE,DISABLE);
USART_ITConfig(USART6,USART_IT_IDLE,ENABLE);
//串口接收DMA配置
BSP_DMAUsar6Rx_Init();
//串口发送DMA配置
BSP_DMAUsar6Tx_Init();
USART_DMACmd(USART6,USART_DMAReq_Rx,ENABLE); //采用DMA方式接收
//开启USART6
//USART1接收DMA配置
static void BSP_DMAUsar6Rx_Init(void)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE); //启动DMA时钟
DMA_DeInit(DMA2_Stream1);
DMA_InitStructure.DMA_Channel = DMA_Channel_5;
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&USART6->DR); //外设地址
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)Uart6_Rx; //内存地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory; //dma传输方向单向
DMA_InitStructure.DMA_BufferSize = UART6_RX_LEN; //设置DMA在传输时缓冲区的长度
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
// DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //设置DMA的2个memory中的变量互相访问
DMA_Init(DMA2_Stream1,&DMA_InitStructure);
DMA_Cmd(DMA2_Stream1,ENABLE); //使能数据流1 通道5
//USART6发送DMA配置
static void BSP_DMAUsar6Tx_Init(void)
DMA_DeInit(DMA2_Stream6);
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&USART6->DR); //DMA外设基地址
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)Uart6_Tx; //DMA内存基地址
DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral; //数据传输方向,从内存读取发送到外设
DMA_InitStructure.DMA_BufferSize = UART6_TX_LEN; //DMA通道的DMA缓存的大小
// DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x没有设置为内存到内存传输
DMA_Init(DMA2_Stream6, &DMA_InitStructure); //根据DMA_InitStruct中指定的参数初始化DMA的通道USART6_Tx_DMA_Channel所标识的寄存器
DMA_Cmd(DMA2_Stream6,DISABLE);
//USART6 DMA发送指定长度的数据
//str:要发送的数据首地址
//cndtr:数据传输量
void BSP_DMAUsart6Puts(unsigned char *str,u8 cndtr)
memcpy(Uart6_Tx, str, cndtr);
USART_DMACmd(USART6,USART_DMAReq_Tx,ENABLE); //使能串口6的DMA发送
DMA_Cmd(DMA2_Stream6, DISABLE ); //关闭USART6 TX DMA2 所指示的通道
DMA_SetCurrDataCounter(DMA2_Stream6,cndtr); //DMA通道的DMA缓存的大小
DMA_Cmd(DMA2_Stream6, ENABLE); //使能USART6 TX DMA2 所指示的通道
//USART6中断函数。
void USART6_IRQHandler(void)
int i = 0;
if(USART_GetITStatus(USART6, USART_IT_IDLE) != RESET)
//1.清除USART6接收完成中断
USART6->SR;
USART6->DR; //清USART_IT_IDLE标志
DMA_Cmd(DMA2_Stream1,DISABLE); //使能数据流1 通道5
if(!Uart6_RxBuffer.RxFlag) //判断是否有数据包在处理
Uart6_RxBuffer.RxLen = UART6_RX_LEN -
DMA_GetCurrDataCounter(DMA2_Stream1); //计算接收数据包长度
for (i = 0;i < Uart6_RxBuffer.RxLen;i++) //将接收到的数据包缓存
Uart6_RxBuffer.buffer[i] = Uart6_Rx[i];
Uart6_RxBuffer.RxFlag = 1; //置位接收状态标志位
DMA_SetCurrDataCounter(DMA2_Stream1,UART6_RX_LEN); //设置传输数据长度
DMA_Cmd(DMA2_Stream1,ENABLE); //打开DMA
从上述代码可以发现,F407和F103之前还是有很大的差别的,首先是引脚的初始化,F407需要复用映射,如下:
F407的DMA的配置,分为通道和数据流,需要这两个配合设置,详见代码,而F103只有通道的概念。如下:
使用如上的代码初始化后,不能正常使用串口收发数据,通过多方查找资料,阅读参考手册后发现,F407 DMA每次接收到数据后需要清一下传输完成标志位,所以在中断串口函数里添加清DMA标志位即可,修改后串口中断函数如下:
//USART6中断函数。
int i = 0;
//1.清除USART6接收完成中断
USART6->SR;
//清除标志位
DMA_ClearFlag(DMA2_Stream1,DMA_FLAG_TCIF1);
这样就解决了接收数据的问题了,可是发送问题还没有解决,需要进一步设置。
其实发送和接收一样,也是没有清除标志位导致的,所以需要开启DMA发送中断使能,在中断中清传输完成标志位。要是只在DMA发送中断中清传输完成标志,还会有个问题出现,那就是串口不一定发送完成了。因为DMA传输完成了不能代表串口发送完成了,所以在清传输完成标志同时还需要开启串口发送中断,确保串口将数据发送完成。整体代码如下:
* BSP_UART_Init()
* Description : This function should be called by your application code before you make use of any of the
* functions found in this module.
* Argument(s) : bound:波特率
* Return(s) : none.
* Caller(s) : BSP_Init.
* Note(s) : none.
//串口6接收缓存
//GPIO端口设置
//串口6对应引脚复用映射
//USART6端口配置
//USART1 初始化设置
//Usart1 NVIC 配置
//开启USART6总线空闲中断
//串口接收DMA配置
//串口发送DMA配置
//开启USART6
//USART1接收DMA配置
//USART6发送DMA配置
//DMA发送中断设置
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream6_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
//使能中断
DMA_ITConfig(DMA2_Stream6,DMA_IT_TC,ENABLE);
//str:要发送的数据首地址
//cndtr:数据传输量
/*******************************USART 中断函数*******************************/
//USART6中断函数。
int i = 0;
//1.清除USART6接收完成中断
USART6->SR;
//清除标志位
/ DMA_ClearFlag(DMA2_Stream1,DMA_FLAG_TCIF1);
if(USART_GetITStatus(USART6, USART_IT_TC) != RESET)
USART_ClearFlag(USART6,USART_IT_TC);
//关闭发送完成中断
/*******************************DMA 中断函数*******************************/
//DMA2中断函数。
void DMA2_Stream6_IRQHandler(void)
if(DMA_GetITStatus(DMA2_Stream6,DMA_IT_TCIF6) != RESET)
//清除标志位
DMA_ClearFlag(DMA2_Stream6,DMA_FLAG_TCIF6);
//关闭DMA
//打开发送完成中断,发送最后两个字节
USART_ITConfig(USART6,USART_IT_TC,ENABLE);
到此,F407的串口通过DMA收发数据配置也就完成了,希望能给同行一个参考。
