#include "C8051F040.h"
#define uchar unsigned char
#define uint unsigned int
uchar xdata virt_port;
bit SPI_BUSY;
unsigned char xdata tab1[8]={0x53,0x31,0x53,0x32,0x53,0x33,0x53,0x34};
sbit key1=P2^0;
sbit key2=P2^1;
sbit key3=P2^2;
sbit key4=P2^3;
sbit LCDCs=P2^5;
void os_init();
void port_init();
void spi_init();
void writecode(uchar ins);
void writEDAta(uchar d);
void lcdchar (uchar da);
void lcdinit();
void writelcd(uchar spi_data);
void delay(uint d);
void main()
WDTCN = 0xDE; // 关闭看门狗
WDTCN = 0xAD;
os_init();
port_init();
spi_init();
SFRPAGE = CONFIG_PAGE;
EIE1 = 0x01;
EA=1;
while(1)
if(key1==0)
delay(2000);
lcdinit();
lcdchar(6);
if(key2==0)
{ delay(2000);
lcdinit();
lcdchar(4);
if(key3==0)
{ delay(2000);
lcdinit();
lcdchar(2);
if(key4==0)
{ delay(2000);
lcdinit();
lcdchar(0);
void os_init()
int i = 0;
OSCXCN = 0x67; //外部22.1184M晶振
for (i = 0; i while ((OSCXCN & 0x80) == 0);
CLKSEL = 0x01; //系统时钟不分频
void port_init()
P0MDOUT=0xff;
XBR0 = 0x06;
XBR2 = 0x40;
P2MDOUT=0xff;
void spi_init()
SFRPAGE = SPI0_PAGE;
SPI0CFG = 0x40;
SPI0CN = 0x01;
SPI0CKR = 0x6D;
void delay(uint d)
{uint i,j;
for(i=0;i
for(j=10;j>0;j--);
void delay1us(void)
uchar xdata i;
for(i=10;i>0;i--);
void writelcd(uchar spi_data) //向LV595写数据以SPI方式
uint xdata i,j,k;
for(i=0;i<9;i++);
LcdCs=0;
delay1us();
SPI_BUSY=1;
SPI0DAT=spi_data;
for(j=0;j<500;j++)
if(!SPI_BUSY)break;
delay1us();
LcdCs=1;
delay1us();
delay1us();
delay1us();
delay1us();
delay1us();
delay1us();
for(k=0;k<5000;k++);
// 以下这段代码,是用IO口模拟SPI传输的程序
LcdCs=0;
for(i=0;i<8;i++)
{ SPICLK=0;
if(spi_data&0x80)
spi_mosi=1;
else
spi_mosi=0;
spi_data<<=1;
SPICLK=1;
for(j=0;j<10;j++)
{_nop_();}
SPICLK=0;
LcdCs=1;
void writecode(uchar ins) //向液晶控制模块写命令
uchar xdata t;
uint xdata j;
for(j=0;j<500;j++);
virt_port|=ins&0xf0; //取高字节向1602写数据
writelcd(virt_port); //先写高4位后再写低4位 这是在选择四个数据线的时候
virt_port|=0x08;
writelcd(virt_port); //使能E脚为高电平
virt_port&=~0x08;
writelcd(virt_port); //使能E脚为低电平
t=ins<<4;
virt_port|=t&0xf0; //取低字节向1602写数据
virt_port|=0x08; //使能E脚为高电平
virt_port&=~0x08; //使能E脚为低电平
virt_port=0;
void writedata(uchar d) //写数据到1602
uchar xdata i,t;
uint xdata j;
for(j=0;j<500;j++);
virt_port|=0x02; //光标返回指令
virt_port|=d&0xf0; //取高字节数据给数据寄存器
virt_port&=0xf7; //使能E脚为低电平
virt_port&=0x07; //设置光标右移,文字也右移
t=d&0x0f;
virt_port|=t<<4; //取低字节数据给数据寄存器
for(i=3;i>0;i--);
virt_port=0; //数据清零
uint xdata i,j,k;
for(j=0;j<5000;j++); //数据读、写操作,画面不动
for(i=da;i
writedata(tab1[i]);
for(j=0;j<1000;j++);
for(k=0;k<1000;k++);
void lcdinit()
uint xdata i;
virt_port=0x00;
writelcd(virt_port); //RS脚为零写指令寄存器 RW为低电平
virt_port|=0x08; //使能脚E=1
virt_port&=0xf7; //使E=0使能脚发生跳变高--低
for(i=1000;i>0;i--); //3次延时,重要!
for(i=8000;i>0;i--); //用延时代替查询
virt_port=0; //写入20码,设置为4位总线方式,非常重要!!!!!
virt_port|=0x20; //只写高字节
virt_port|=0x08; //E=1
for(i=20;i>0;i--); //使命令执行
virt_port&=0xf7; //E=0
for(i=10;i>0;i--);
virt_port=0;
writecode(0x38); //设两行显示,4线方式5*10字符显示
for(i=50;i>0;i--);
writecode(0x06); //光标右移
for(i=50;i>0;i--);
writecode(0x0c); //开显示指令
for(i=50;i>0;i--);
writecode(0x02); //光标返回指令
for(i=50;i>0;i--);
writecode(0x01); //清屏指令
for(i=50;i>0;i--);
void spi_srs () interrupt 6
if(SPIF)
SPIF=0;
SPI_BUSY=0;
if(WCOL)
WCOL=0;
