怎样写LCD驱动程序
1、分配一个fb_info结构体,使用framebuffer_alloc()函数
2、设置fb_info中的参数,
1)固定参数(fix)
2)可变参数(var)
3)设置操作函数 fbops
4)其他设置 如调色板pseudo_palette和屏幕尺寸screen_size
5)分配显存 dma_alloc_writecombine(),返回的是虚拟地址
3、注册fb_info 使用register_framebuffer
4、硬件相关操作,LCD寄存器等
测试方法:
虚拟机:
1、make menuconfig去掉原来的驱动程序
->Device Drivers
->Graphics support
2、make uImage
make modules
cp arch/arm/boot/uImage /work/nfs_root/mydriver/uImage_nolcd
cp drivers/video/cfb*.ko /work/nfs_root/mydriver/
开发板:
3、使用新的uImage启动开发板
nfs 30000000 192.168.34.251:/work/nfs_root/uImage_nolcd
bootm 30000000
4、加载驱动
insmod cfbfillrect.ko
insmod cfbimgblt.ko
insmod cfbcopyarea.ko
insmod lcd.ko
echo hello > /dev/tty1 //可以在LCD上看见hello
cat lcd.ko > /dev/fb0 //花屏
5、修改inittab
vi /etc/inittab
增加一行
tty1::askfirst:-/bin/sh
重启reboot
insmod cfbimgblt.ko
insmod lcd.ko
insmod buttons.ko //输入子系统中的驱动
函数说明:
s3c_lcd->screen_base = dma_alloc_writecombine(NULL, s3c_lcd->fix.smem_len, &s3c_lcd->fix.smem_start, GFP_KERNEL);
含义:
s3c_lcd->screen_base : 内存的虚拟起始地址,在内核要用此地址来操作所分配的内存
NULL : 可以平台初始化里指定,主要是用到dma_mask之类参数,可参考framebuffer
s3c_lcd->fix.smem_len : 实际分配大小,传入dma_map_size即可
&s3c_lcd->fix.smem_start :返回的内存物理地址,dma就可以用。
s3c_lcd->screen_base 和 s3c_lcd->fix.smem_start是一一对应的,
s3c_lcd->screen_base 是虚拟地址,
而s3c_lcd->fix.smem_start是总线地址。对任意一个操作都将改变写缓冲区内容。
lcd.c
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
static int s3c_lcdfb_setcolreg(unsigned int regno, unsigned int red,
unsigned int green, unsigned int blue,
unsigned int transp, struct fb_info *info);
struct lcd_regs {
unsigned long lcdcon1;
unsigned long lcdcon2;
unsigned long lcdcon3;
unsigned long lcdcon4;
unsigned long lcdcon5;
unsigned long lcdsaddr1;
unsigned long lcdsaddr2;
unsigned long lcdsaddr3;
unsigned long redlut;
unsigned long greenlut;
unsigned long bluelut;
unsigned long reserved[9];
unsigned long dithmode;
unsigned long tpal;
unsigned long lcdintpnd;
unsigned long lcdsrcpnd;
unsigned long lcdintmsk;
unsigned long lpcsel;
static struct fb_ops s3c_lcdfb_ops = {
.owner = THIS_MODULE,
.fb_setcolreg = s3c_lcdfb_setcolreg,
.fb_fillrect = cfb_fillrect,
.fb_copyarea = cfb_copyarea,
.fb_imageblit = cfb_imageblit,
static struct fb_info *s3c_lcd;
static volatile unsigned long *gpbcon;
static volatile unsigned long *gpbdat;
static volatile unsigned long *gpccon;
static volatile unsigned long *gpdcon;
static volatile unsigned long *gpgcon;
static volatile struct lcd_regs* lcd_regs;
static u32 pseudo_palette[16];
/* from pxafb.c */
static inline unsigned int chan_to_field(unsigned int chan, struct fb_bitfield *bf)
chan &= 0xffff;
chan >>= 16 - bf->length;
return chan << bf->offset;
unsigned int val;
if (regno > 16)
return 1;
/* 用red,green,blue三原色构造出val */
val = chan_to_field(red, &info->var.red);
val |= chan_to_field(green, &info->var.green);
val |= chan_to_field(blue, &info->var.blue);
//((u32 *)(info->pseudo_palette))[regno] = val;
pseudo_palette[regno] = val;
return 0;
static int lcd_init(void)
/* 1. 分配一个fb_info **************************************************/
s3c_lcd = framebuffer_alloc(0, NULL);
/* 2. 设置 */
/* 2.1 设置固定的参数 */
strcpy(s3c_lcd->fix.id, "mylcd");
s3c_lcd->fix.smem_len = 480*272*16/8;
s3c_lcd->fix.type = FB_TYPE_PACKED_PIXELS;
s3c_lcd->fix.visual = FB_VISUAL_TRUECOLOR; /* TFT */
s3c_lcd->fix.line_length = 480*2;
/* 2.2 设置可变的参数 */
s3c_lcd->var.xres = 480;
s3c_lcd->var.yres = 272;
s3c_lcd->var.xres_virtual = 480;
s3c_lcd->var.yres_virtual = 272;
s3c_lcd->var.bits_per_pixel = 16;
/* RGB:565 */
s3c_lcd->var.red.offset = 11;
s3c_lcd->var.red.length = 5;
s3c_lcd->var.green.offset = 5;
s3c_lcd->var.green.length = 6;
s3c_lcd->var.blue.offset = 0;
s3c_lcd->var.blue.length = 5;
s3c_lcd->var.activate = FB_ACTIVATE_NOW;
/* 2.3 设置操作函数 */
s3c_lcd->fbops = &s3c_lcdfb_ops;
/* 2.4 其他的设置 */
s3c_lcd->pseudo_palette = pseudo_palette;
//s3c_lcd->screen_base = ; /* 显存的虚拟地址 */
s3c_lcd->screen_size = 480*272*16/8;
/* 3. 硬件相关的操作 */
/* 3.1 配置GPIO用于LCD */
gpbcon = ioremap(0x56000010, 8);//ioremap功能:将一个IO地址空间映射到内核的虚拟地址空间上去,便于访问;
gpbdat = gpbcon+1;
gpccon = ioremap(0x56000020, 4);
gpdcon = ioremap(0x56000030, 4);
gpgcon = ioremap(0x56000060, 4);
*gpccon = 0xaaaaaaaa; /* GPIO管脚用于VD[7:0],LCDVF[2:0],VM,VFRAME,VLINE,VCLK,LEND */
*gpdcon = 0xaaaaaaaa; /* GPIO管脚用于VD[23:8] */
*gpbcon &= ~(3); /* GPB0设置为输出引脚 */
*gpbcon |= 1;
*gpbdat &= ~1; /* 输出低电平 */
*gpgcon |= (3<<8); /* GPG4用作LCD_PWREN */
/* 3.2 根据LCD手册设置LCD控制器, 比如VCLK的频率等 */
lcd_regs = ioremap(0x4D000000, sizeof(struct lcd_regs));
/* bit[17:8]: VCLK = HCLK / [(CLKVAL+1) x 2], LCD手册P14
* 10MHz(100ns) = 100MHz / [(CLKVAL+1) x 2]
* CLKVAL = 4
* bit[6:5]: 0b11, TFT LCD
* bit[4:1]: 0b1100, 16 bpp for TFT
* bit[0] : 0 = Disable the video output and the LCD control signal.
lcd_regs->lcdcon1 = (4<<8) | (3<<5) | (0x0c<<1);
#if 1
/* 垂直方向的时间参数
* bit[31:24]: VBPD, VSYNC之后再过多长时间才能发出第1行数据
* LCD手册 T0-T2-T1=4
* VBPD=3
* bit[23:14]: 多少行, 320, 所以LINEVAL=320-1=319
* bit[13:6] : VFPD, 发出最后一行数据之后,再过多长时间才发出VSYNC
* LCD手册T2-T5=322-320=2, 所以VFPD=2-1=1
* bit[5:0] : VSPW, VSYNC信号的脉冲宽度, LCD手册T1=1, 所以VSPW=1-1=0
//lcd_regs->lcdcon2 = (3<<24) | (319<<14) | (1<<6) | (0<<0);
lcd_regs->lcdcon2 = (1<<24) | (271<<14) | (1<<6) | 9; //同一厂家同一型号的led屏 某些位的值是一样的,查手册获得
/* 水平方向的时间参数
* bit[25:19]: HBPD, VSYNC之后再过多长时间才能发出第1行数据
* LCD手册 T6-T7-T8=17
* HBPD=16
* bit[18:8]: 多少列, 240, 所以HOZVAL=240-1=239
* bit[7:0] : HFPD, 发出最后一行里最后一个象素数据之后,再过多长时间才发出HSYNC
* LCD手册T8-T11=251-240=11, 所以HFPD=11-1=10
//lcd_regs->lcdcon3 = (16<<19) | (239<<8) | (10<<0);
lcd_regs->lcdcon3 = (1<<19) | (479<<8) | (1);
/* 水平方向的同步信号
* bit[7:0] : HSPW, HSYNC信号的脉冲宽度, LCD手册T7=5, 所以HSPW=5-1=4
//lcd_regs->lcdcon4 = 4;
lcd_regs->lcdcon4 = 40;
lcd_regs->lcdcon5 =1<<11|1<<9|1<<8|1<<1;
#else
lcd_regs->lcdcon2 = S3C2410_LCDCON2_VBPD(5) |
S3C2410_LCDCON2_LINEVAL(319) |
S3C2410_LCDCON2_VFPD(3) |
S3C2410_LCDCON2_VSPW(1);
lcd_regs->lcdcon3 = S3C2410_LCDCON3_HBPD(10) |
S3C2410_LCDCON3_HOZVAL(239) |
S3C2410_LCDCON3_HFPD(1);
lcd_regs->lcdcon4 = S3C2410_LCDCON4_MVAL(13) |
S3C2410_LCDCON4_HSPW(0);
#endif
/* 信号的极性
* bit[11]: 1=565 format
* bit[10]: 0 = The video data is fetched at VCLK falling edge
* bit[9] : 1 = HSYNC信号要反转,即低电平有效
* bit[8] : 1 = VSYNC信号要反转,即低电平有效
* bit[6] : 0 = VDEN不用反转
* bit[3] : 0 = PWREN输出0
* bit[1] : 0 = BSWP
* bit[0] : 1 = HWSWP 2440手册P413
// lcd_regs->lcd
