我们来看看 timer.c文件中,我们添加的两个函数的内容:
TIM_ICInitTypeDef TIM5_ICInitStructure;
//定时器 5通道1 输入捕获配置
//arr:自动重装值(TIM2,TIM5 是 32位的!!) psc:时钟预分频数
void TIM5_CH1_Cap_Init(u32 arr,u16 psc)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5,ENABLE); //TIM5时钟使能
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); //使能PORTA时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //GPIOA0
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; //速度 100MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN; //下拉
GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PA0
GPIO_PinAFConfig(GPIOA,GPIO_PinSource0,GPIO_AF_TIM5); //PA0复用位定时器5
TIM_TimeBaseStructure.TIM_Prescaler=psc; //定时器分频
TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up; //向上计数模式
TIM_TimeBaseStructure.TIM_Period=arr; //自动重装载值
TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
TIM_TimeBaseInit(TIM5,&TIM_TimeBaseStructure);
TIM5_ICInitStructure.TIM_Channel = TIM_Channel_1; //选择输入端 IC1 映射到TI1上
TIM5_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //上升沿捕获
TIM5_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到 TI1 上
TIM5_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置输入分频,不分频
TIM5_ICInitStructure.TIM_ICFilter = 0x00;//IC1F=0000 配置输入滤波器 不滤波
TIM_ICInit(TIM5, &TIM5_ICInitStructure); //初始化 TIM5输入捕获参数
TIM_ITConfig(TIM5,TIM_IT_Update|TIM_IT_CC1,ENABLE);//允许更新和捕获中断
TIM_Cmd(TIM5,ENABLE ); //使能定时器 5
NVIC_InitStructure.NVIC_IRQChannel = TIM5_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2;//抢占优先级2
NVIC_InitStructure.NVIC_IRQChannelSubPriority =0;//响应优先级0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ 通道使能
NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC 寄存器、
//捕获状态
//[7]:0,没有成功的捕获;1,成功捕获到一次.
//[6]:0,还没捕获到低电平;1,已经捕获到低电平了.
//[5:0]:捕获低电平后溢出的次数(对于32位定时器来说,1us计数器加1,溢出时间:4294秒)
u8 TIM5CH1_CAPTURE_STA=0; //输入捕获状态
u32 TIM5CH1_CAPTURE_VAL; //输入捕获值(TIM2/TIM5是 32位)
//定时器 5中断服务程序
void TIM5_IRQHandler(void)
if((TIM5CH1_CAPTURE_STA&0X80)==0)//还未成功捕获
if(TIM_GetITStatus(TIM5, TIM_IT_Update) != RESET)//溢出
if(TIM5CH1_CAPTURE_STA&0X40)//已经捕获到高电平了
if((TIM5CH1_CAPTURE_STA&0X3F)==0X3F)//高电平太长了
TIM5CH1_CAPTURE_STA|=0X80; //标记成功捕获了一次
TIM5CH1_CAPTURE_VAL=0XFFFFFFFF;
}else TIM5CH1_CAPTURE_STA++;
if(TIM_GetITStatus(TIM5, TIM_IT_CC1) != RESET)//捕获 1发生捕获事件
if(TIM5CH1_CAPTURE_STA&0X40) //捕获到一个下降沿
TIM5CH1_CAPTURE_STA|=0X80; //标记成功捕获到一次高电平脉宽
TIM5CH1_CAPTURE_VAL=TIM_GetCapture1(TIM5);//获取当前的捕获值.
TIM_OC1PolarityConfig(TIM5,TIM_ICPolarity_Rising); //设置上升沿捕获
}else //还未开始,第一次捕获上升沿
TIM5CH1_CAPTURE_STA=0; //清空
TIM5CH1_CAPTURE_VAL=0;
TIM5CH1_CAPTURE_STA|=0X40;//标记捕获到了上升沿
TIM_SetCounter(TIM5,0); //计数器清空
TIM_OC1PolarityConfig(TIM5,TIM_ICPolarity_Falling);//设置下降沿捕获
TIM_ClearITPendingBit(TIM5, TIM_IT_CC1|TIM_IT_Update); //清除中断标志位
此部分代码包含两个函数,其中TIM5_CH1_Cap_Init函数用于 TIM5通道 1的输入捕获设置,其设置和我们上面讲的步骤是一样的,这里就不多说,特别注意:TIM5 是 32 位定时器,所以 arr是u32 类型的。接下来,重点来看看第二个函数。
TIM5_IRQHandler 是 TIM5 的中断服务函数,该函数用到了两个全局变量,用于辅助实现高电平捕获。其中TIM5CH1_CAPTURE_STA,是用来记录捕获状态,该变量类似我们在usart.c里面自行定义的USART_RX_STA 寄存器(其实就是个变量,只是我们把它当成一个寄存器那样来使用)。TIM5CH1_CAPTURE_STA各位描述如表15.3.1所示:
TIM5CH1_CAPTURE_STA
bit7 bit6 bit5~0
捕获完成标志 捕获到高电平标志 捕获高电平后定时器溢出的次数
表15.3.1 TIM5CH1_CAPTURE_STA各位描述
另外一个变量TIM5CH1_CAPTURE_VAL,则用来记录捕获到下降沿的时候,TIM5_CNT的值。
现在我们来介绍一下,捕获高电平脉宽的思路:首先,设置TIM5_CH1 捕获上升沿,这在TIM5_Cap_Init函数执行的时候就设置好了,然后等待上升沿中断到来, 当捕获到上升沿中断,此时如果TIM5CH1_CAPTURE_STA的第6 位为 0,则表示还没有捕获到新的上升沿,就先把TIM5CH1_CAPTURE_STA、TIM5CH1_CAPTURE_VAL和计数器值TIM5->CNT 等清零,然后再设置TIM5CH1_CAPTURE_STA的第6 位为1, 标记捕获到高电平, 最后设置为下降沿捕获,等待下降沿到来。如果等待下降沿到来期间,定时器发生了溢出(对 32 位定时器来说,很难溢出) ,就在TIM5CH1_CAPTURE_STA 里面对溢出次数进行计数,当最大溢出次数来到的时候,就强制标记捕获完成(虽然此时还没有捕获到下降沿)。当下降沿到来的时候,先设置TIM5CH1_CAPTURE_STA 的第 7 位为1,标记成功捕获一次高电平,然后读取此时的定时器值到TIM5CH1_CAPTURE_VAL里面,最后设置为上升沿捕获,回到初始状态。
这样,我们就完成一次高电平捕获了,只要TIM5CH1_CAPTURE_STA的第7位一直为1,那么就不会进行第二次捕获,我们在main函数处理完捕获数据后,将TIM5CH1_CAPTURE_STA置零,就可以开启第二次捕获。
timer.h头文件内容比较简单,主要是函数申明,这里我们不做过多讲解。
接下来,我们看看main函数内容
extern u8 TIM5CH1_CAPTURE_STA; //输入捕获状态
extern u32 TIM5CH1_CAPTURE_VAL; //输入捕获值
int main(void)
long long temp=0;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
delay_init(168); //初始化延时函数
uart_init(115200);//初始化串口波特率为115200
TIM14_PWM_Init(500-1,84-1);
//84M/84=1Mhz的计数频率计数到500,频率为1M/500=2Khz
TIM5_CH1_Cap_Init(0XFFFFFFFF,84-1);//以 84M/84=1Mhz的频率计数
while(1)
{ delay_ms(10);
TIM_SetCompare1(TIM14,TIM_GetCapture1(TIM14)+1);
if(TIM_GetCapture1(TIM14)==300)TIM_SetCompare1(TIM14,0);
if(TIM5CH1_CAPTURE_STA&0X80)//成功捕获到了一次高电平
temp=TIM5CH1_CAPTURE_STA&0X3F;
temp*=0XFFFFFFFF; //溢出时间总和
temp+=TIM5CH1_CAPTURE_VAL; //得到总的高电平时间
printf("HIGH:%lld us\r\n",temp);//打印总的高点平时间
TIM5CH1_CAPTURE_STA=0; //开启下一次捕获
该 main 函数是在 PWM 实验的基础上修改来的,我们保留了 PWM 输出,同时通过设置TIM5_Cap_Init(0XFFFFFFFF,84-1),将 TIM5_CH1 的捕获计数器设计为 1us 计数一次,并设置重装载值为最大以达到不让定时器溢出的作用(溢出时间为 232-1 us),所以我们的捕获时间精度为 1us。主函数通过 TIM5CH1_CAPTURE_STA 的第 7 位,来判断有没有成功捕获到一次高电平,如果成功捕获,则将高电平时间通过串口输出到电脑。至此,我们的软件设计就完成了。
