在 《STM32串口向世界问好》介绍过如何发送消息,那么又如何接收消息呢?
也很简单,只需要配置好串口接收,配置好中断,并在串口中断函数里面进行数据接收就可以了。通用配置代码如下:
/** * @brief 初始化IO 串口1 * @param bound:波特率 * @retval None */void USART1_Debug_Init(u32 bound){ //GPIO端口设置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; assert_param(bound >0 && bound <= 256000); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE); USART_DeInit(USART1); //复位串口1 //USART1_TX PA.9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA9 //USART1_RX PA.10 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA10 //USART 初始化设置 USART_InitStructure.USART_BaudRate = bound; USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 USART_Init(USART1, &USART_InitStructure); //初始化串口 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2 ; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); USART_ClearFlag(USART1, USART_FLAG_TC);//防止第一个数据被覆盖 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启中断 USART_Cmd(USART1, ENABLE); //使能串口}
中断处理接收函数为:
void USART1_IRQHandler(void){ u8 res; if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中断 有数据为 1 SET { res = (u8)USART_ReceiveData(USART1); res = res ; } }
如果此时需要判断当接收的数据为1时点亮LED1,当接收数据为2时熄灭LED1则可在中断里作如下处理:
void USART1_IRQHandler(void){ u8 res; if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中断 有数据为 1 SET { res = (u8)USART_ReceiveData(USART1); if(0x01 == res) { LED1 = ON ; } if(0x02 == res) { LED1 = OFF ; } } }
但这种接收控制方法是不够稳定与灵活的,比如在传输的过程中受到干扰,0x01 变成 0x02,则就会出现错误的控制。又比如我要接收一串数据并进行处理,这样就不好控制了。
这时我们就要想着制定一套通信协议来方便通信。
在此介绍一种简单通信协议,是我在设计一款无人机数据链通信时用到的一开源协议:MAVLink,另外加上CRC校验,进一步保证接收数据的可靠性。
其通信数据格式如下:
红色部分代表起始帧 STX 为 0xFE ; LEN表示要发送的数据长度(PAYLOAD长度);SEQ表示数据的序列号,循环从0至255发送(可以检测是否丢包,并可能过此来判断信号强度);SYS是用来表示区分同一网络中不同飞行器号的,即系统ID;COMP代表组件ID,表示飞行器上各个组成部分,如飞控单元,GPS等;MSG则代表消息ID,即要发送不同控制命令ID;PAYLOAD表示此命令的内容;最后两字节是自动生的的CRC校验码 。
从上图也可以看出PAYLOAD有效长度可为0至255字节(因为LEN来表示,它们都是无符号8位数据类型),所以一条消息长度最小为8字节,最大为263字节。
至此一简单通信协议就介绍过了,说的有点多。下面就是如何对其解析,话不多说直接代码说明:
#define MavlinkLenMin 8#define MavlinkLenMax 263#define STX 0xFE//MAVLINK HEAD#define Add_STX 0x00#define Add_LEN 0x01#define Add_SEQ 0x02#define Add_SYS 0x03#define Add_COMP 0x04#define Add_MSG 0x05#define Add_PAYLOAD 0x06//PAYLOAD start from 0x06typedef enum {BEEN_RECEIVED = 0, RECEIVING = !BEEN_RECEIVED} Receive_Status;typedef struct{ boolean Get ; u16 Len ; u8 Cache[MavlinkLenMax]; }MAVLink_Data_Struct , * MAVLink_Data_Struct_p ; MAVLink_Data_Struct Msg_Rev ; void Msg_Recv_Data_Analyse_Irq(u8 data){ if(RECEIVING == Msg_Rev.Get){ Msg_Rev.Cache[Msg_Rev.Len++] = data; if(STX != Msg_Rev.Cache[Add_STX]){ Msg_Rev.Len = 0 ; } if(((u16)Msg_Rev.Cache[Add_LEN] + MavlinkLenMin)==Msg_Rev.Len){ Msg_Rev.Get = BEEN_RECEIVED ; } } }
可在串口中断接收函数里调用此函数用作协议数据接收解析
void USART1_IRQHandler(void) { u8 res; if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中断 有数据为 1 SET { res = (u8)USART_ReceiveData(USART1); Msg_Recv_Data_Analyse_Irq(res); } }
当一条消息接收完成后,Msg_Rev.Get的状态就会被设置成BEEN_RECEIVED ,这时就可在相关函数中对此条消息进行处理。
另外为了消息的更可靠,还可加入CRC校验,如下函数就是一简单通用的CRC16校验码生成函数:
u16 crc_chk_value(u8 *data_value) { u16 crc_value = 0xFFFF; u16 length = (uint16_t)data_value[1] + 6; u16 i; while(length--) { crc_value ^= *data_value++; for(i=0;i<8;i++) { if(crc_value & 0x0001) crc_value = (crc_value >>1) ^ 0xa001; else crc_value=crc_value >> 1; } } return(crc_value); }
如上述的对LED灯控制,我们可以作如下简单设计,设定发送操控数据的设备SYS ID为1,假定组件串口1的ID为1,消息ID也为1,另外发送的数据长度也为1,则解析控制函数如:
void Msg_Control_Process(void) { u16 checksum; if(BEEN_RECEIVED == Msg_Rev.Get){ checksum = crc_chk_value(Msg_Rev.Cache); if( (Msg_Rev.Cache[Msg_Rev.Cache[Add_LEN] + 6 + 1] == (checksum & 0xFF)) && (Msg_Rev.Cache[Msg_Rev.Cache[Add_LEN] + 6 + 2] == ((checksum >> 8) & 0xFF)) ){ if( (0x01 == Msg_Rev.Cache[Add_SYS]) && (0x01 == Msg_Rev.Cache[Add_COMP]) ){ if(0x01 == Msg_Rev.Cache[Msg_Rev.Cache[Add_LEN] + 6]){ LED1 = ON ; } if(0x02 == Msg_Rev.Cache[Msg_Rev.Cache[Add_LEN] + 6]){ LED1 = OFF ; } } } Msg_Rev.Get = RECEIVING ; Msg_Rev.Len = 0; } }
此函数可在主轮询里调用,当中断里正常接收到一串消息后,就可以根据条件判断及加处控制处理,处理完成后再继续接收。因加入了CRC校验及消息和组件ID检测等,数据可靠性增加,当然软件通信可靠性增强一般是通过增加冗余来实现,此也不例外。
稍微复杂的控制用此比较好,上面的例程用此只是作简单原理性说明,有点大材小用的感觉 。
另在此设计中,你会发现,当接收完一条消息,处理完成后才接收下一条。这样,当处理过程较费时间,并且消息在不断的快速发送时,就容易引起丢包现象 ,所以以上设计并不是很好的。那么这个又如何解决呢?
待我研究下,下篇将会作详细介绍 。
