一、GDB基础知识
1、控制命令
n: 单步运行
c: 继续运行
q: 退出gdb
2、设置、查看和删除断点
(gdb) br start_kernel
Breakpoint 6 at 0x809009b0: file ../init/main.c, line 483.
(gdb) br __irq_svc
Breakpoint 7 at 0x806e8e60: file ../arch/arm/kernel/entry-armv.S, line 219.
(gdb) br gic_handle_irq
Breakpoint 8 at 0x801014f4: file ../drivers/irqchip/irq-gic.c, line 352.
(gdb) info br
Num Type Disp Enb Address What
6 breakpoint keep y 0x809009b0 in start_kernel at ../init/main.c:483
7 breakpoint keep y 0x806e8e60 ../arch/arm/kernel/entry-armv.S:219
8 breakpoint keep y 0x801014f4 in gic_handle_irq at ../drivers/irqchip/irq-gic.c:352
(gdb) delete br 8
(gdb) info br
(gdb) delete br // 删除所有断点
Delete all breakpoints? (y or n) y
(gdb) info br
No breakpoints or watchpoints.
(gdb)
3、查看调用栈
(gdb) bt
#0 ftrace_traceoff (ip=2157986736, parent_ip=0, data=0x80a01f48
#1 0x80109a18 in arch_cpu_idle () at ../arch/arm/kernel/process.c:73
#2 0x806dbd54 in p9_write_work (work=0x80a043b0
#3 0x8016575c in __list_del (next=
#4 __list_del_entry (entry=
#5 list_del_init (entry=
#6 __finish_swait (q=
#7 0x80165abc in current_thread_info () at ../arch/arm/include/asm/thread_info.h:94
#8 need_resched () at ../include/linux/sched.h:3500
#9 do_idle () at ../kernel/sched/idle.c:222
#10 0x806d56f8 in svc_seq_show (seq=0x80a01f94
#11 0x80900d64 in start_kernel () at ../init/main.c:653
#12 0x6000807c in ?? ()
Backtrace stopped: frame did not save the PC
4、查看寄存器的值
info registers (除了浮点寄存器)
(gdb) info registers
r0 0x80a043b0 -2136980560
r1 0x0 0
r2 0x80a01f48 -2136989880
r3 0x8011b8c0 -2146322240
r4 0x0 0
r5 0x80a03cd0 -2136982320
r6 0x80a03c6c -2136982420
r7 0x8097f5d8 -2137524776
r8 0x80a03cd8 -2136982312
r9 0x80a1cace -2136880434
r10 0x0 0
r11 0x80a01f44 -2136989884
r12 0x80a01f38 -2136989896
sp 0x80a01f38 0x80a01f38
lr 0x80109a18 -2146395624
pc 0x801d0ae4 0x801d0ae4
cpsr 0x60000093 1610612883
info registers 寄存器名称 (查看指定的寄存器的值)
(gdb) info registers cpsr
(gdb) info registers pc
(gdb) info registers r0
(gdb) info registers r0 r1
r1 0x0 0
print/x $寄存器名 (查看指定的寄存器)
(gdb) print/x $r0
$7 = 0x80a043b0
(gdb) print/x $pc
$8 = 0x801d0ae4
(gdb) print/x $cpsr
$9 = 0x60000093
下面的字符用于设置数据显示的格式:
x 按十六进制格式显示变量。
d 按十进制格式显示变量。
u 按十六进制格式显示无符号整型。
o 按八进制格式显示变量。
t 按二进制格式显示变量。
a 按十六进制格式显示变量。
c 按字符格式显示变量。
f 按浮点数格式显示变量
5、查看内存的值
x/
n 是一个正整数,表示显示内存的长度,也就是说从当前地址向后显示几个地址的内容
f 表示显示的格式:
x 按十六进制格式显示变量
d 按十进制格式显示变量
u 按十六进制格式显示无符号整型
o 按八进制格式显示变量
t 按二进制格式显示变量
a 按十六进制格式显示变量
c 按字符格式显示变量
f 按浮点数格式显示变量
u 表示将多少个字节作为一个值取出来,如果不指定的话,GDB默认是4个bytes,如果不指定的话,默认是4个bytes。当我们指定了字节长度后,GDB会从指内存定的内存地址开始,读写指定字节,并把其当作一个值取出来,可以设置如下几种:
b 表示单字节
h 表示双字节
w 表示四字 节
g 表示八字节
r1 0x0 0
r4 0x0 0
r10 0x0 0
(gdb) x/16xw 0x801d0ae4
0x801d0ae4
0x801d0af4
0x801d0b04
0x801d0b14
(gdb) x/16xw 0x80a01f38
0x80a01f38
0x80a01f48
0x80a01f58
0x80a01f68
上面查看了pc和sp指向的内存地址的内容。
二、TQ2440 + KGDB + 串口
配置内核
Kernel hacking
----> Compile-time checks and compiler options
----> [*] Compile the kernel with debug info
----> [*] Kernel debugging
----> [*] KGDB: kernel debugger
----> KGDB: use kgdb over the serial console
然后编译内核,然后我们就可以在uboot中配置bootargs,用新的kernel启动, 由于目前板子上只有一个调试串口,所以在使用gdb打开串口时,需要把其他
使用该串口的应用关闭,如ckermit以及minicom。
具体调试有两种方式
方式一:开机启动阶段kernel自动等待连接
设置uboot的bootargs如下:
setenv bootargs 'noinitrd roo
