#define uint unsigned int #define uchar unsigned char sbit lcdrs = P1^0; sbit lcdrw = P1^1; sbit lcden = P1^2; sbit key0 = P2^0;//功能键,选择时分秒 sbit key1 = P2^1;//加1键 sbit key2 = P2^2;//减1键 sbit key4 = P2^4; sbit clk_1302 = P1^5; //1302芯片位定义 sbit io_1302 = P1^6; sbit rst_1302 = P1^7; uchar bdata dat; sbit dat0 = dat^0; sbit dat7 = dat^7; uchar key0_count;//按键0被按的次数(0~3) uchar flag; char hour,minute,second; uchar table_date[] = "2009-4-12 Mon"; uchar table_time[] = "00:00:00"; /****** 函数申明 ********/ void write_cmd_1602(uchar cmd); void write_data_1602(uchar dat); void write_add(uchar add,uchar dat); void init1602(); void delay(uint z); uchar reverse(uchar c); void keyscan(); void init(); void RTC_initial (); void wr_1302(uchar wr_data); uchar rd_1302(void); uchar uc_R1302(uchar ucAddr); void v_W1302(uchar ucAddr, uchar ucDa);
主程序
#include#include #include "header.h" /****** 主函数 ********/ void main() { RTC_initial(); init(); //init1602(); //while(1); while(1) { if(flag) { second = uc_R1302(0x81); minute = uc_R1302(0x83); hour = uc_R1302(0x85); write_add(0x40+10,second); write_add(0x40+7,minute); write_add(0x40+4,hour); } keyscan(); delay(1); } } void RTC_initial () { v_W1302(0x8e,0x00); //使能 v_W1302(0x80,0x80); //停止晶振 v_W1302(0x90,0x00); //关闭充电 v_W1302(0x8c,0x07); //设置年 v_W1302(0x8a,0x06); //设置周 v_W1302(0x88,0x01); //设置月 v_W1302(0x86,0x13); //设置日 v_W1302(0x84,0x18); //设置小时 v_W1302(0x82,0x05); //设置分 v_W1302(0x80,0x00); //启动晶振,设置秒 v_W1302(0x8e,0x80); //使能 } /***************************** * 功 能: 往DS1302写入1Byte数据 * 输 入: wr_data写入的数据 * 返回值: 无 *******************************/ void wr_1302(uchar wr_data) { uchar i = 0; dat = wr_data; rst_1302 = 1; clk_1302 = 0; delay(5); for(i=0;i<8;i++) { io_1302 = dat0; clk_1302 = 0; _nop_(); clk_1302 = 1; _nop_(); dat >>= 1; } //rst_1302 = 0; } /***************************** * 功 能: 从DS1302读出1Byte数据 * 返回值: dat *******************************/ uchar rd_1302(void) { uchar i; rst_1302 = 1; clk_1302 = 1; delay(5); for(i=0;i<8;i++) { dat >>= 1; dat7 = io_1302; clk_1302 = 1; _nop_(); _nop_(); clk_1302 = 0; _nop_(); } rst_1302 = 0; return dat; } /******************************************************************** * 名 称: uc_R1302 * 说 明: 先写地址,后读命令/数据 * 功 能: 读取DS1302某地址的数据 * 调 用: v_RTInputByte() , uc_RTOutputByte() * 输 入: ucAddr: DS1302地址 * 返回值: ucDa :读取的数据 ***********************************************************************/ uchar uc_R1302(uchar add) { uchar temp= 0xff; wr_1302(add); temp = rd_1302(); return temp; } /******************************************************************** * 名 称: v_W1302 * 说 明: 先写地址,后写命令/数据 * 功 能: 往DS1302写入数据 * 调 用: v_RTInputByte() * 输 入: ucAddr: DS1302地址, ucDa: 要写的数据 * 返回值: 无 **********************************************************************/ void v_W1302(uchar ucAddr, uchar ucDa) { wr_1302(ucAddr); wr_1302(ucDa); rst_1302 = 0; clk_1302 = 0; } //1602液晶初始化 void init1602() { lcdrw = 0; //本程序只读不写,故将其置低 lcden = 0; //关闭1602 delay(5); write_cmd_1602(0x01); //清屏 write_cmd_1602(0x38); //显示模式 write_cmd_1602(0x0c); //开显示,不显示光标,不闪烁 write_cmd_1602(0x06); //地址指针自动加1 write_cmd_1602(0x80+1);//将光标指向第一行第二个位置 delay(5); } void delay(uint z) { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); } /** 将发送的数据进行翻转,高位到低位,低位转到高位 **/ uchar reverse(uchar c) { uchar chbuff=0; if (c&0x01) chbuff=chbuff|0x80; if (c&0x02) chbuff=chbuff|0x40; if (c&0x04) chbuff=chbuff|0x20; if (c&0x08) chbuff=chbuff|0x10; if (c&0x10) chbuff=chbuff|0x08; if (c&0x20) chbuff=chbuff|0x04; if (c&0x40) chbuff=chbuff|0x02; if (c&0x80) chbuff=chbuff|0x01; return chbuff; } //向液晶写命令 void write_cmd_1602(uchar cmd) { lcdrs = 0; //低表示写命令,高表示写数据 delay(5); P0 = reverse(cmd); delay(5); lcden = 1; //给一个高脉冲 delay(5); lcden = 0; delay(5); } //向液晶写数据 void write_data_1602(uchar dat) { lcdrs = 1; //低表示写命令,高表示写数据 delay(5); P0 = reverse(dat); delay(5); lcden = 1; //给一个高脉冲 delay(5); lcden = 0; delay(5); } //根据地址向液晶写数据 void write_add(uchar add,uchar dat) { uchar shi,ge; shi = dat/10; ge = dat%10; delay(5); write_cmd_1602(0x80+add); write_data_1602(shi+0x30); delay(5); write_data_1602(ge+0x30); } //键盘扫描函数 void keyscan() { key4 = 0; if(0==key0) //第一个键被按下 { delay(5); //消抖 if(0==key0) { key0_count ++; if(4==key0_count) { key0_count = 0; flag = 1; } while(!key0); //松手检测 flag = 0; if(0==key0_count) { flag = 0; write_cmd_1602(0x0c); //禁止显示光标并不让其闪烁 } if(1==key0_count) { flag = 0; write_cmd_1602(0x80+0x40+11);//将地址指针指向秒的位置 write_cmd_1602(0x0f); //显示光标并闪烁 delay(5); } if(2==key0_count) { flag = 0; write_cmd_1602(0x80+0x40+8);//将地址指针指向分的位置 write_cmd_1602(0x0f); //显示光标并闪烁 delay(5); } if(3==key0_count) { flag = 0; write_cmd_1602(0x80+0x40+5);//将地址指针指向小时的位置 write_cmd_1602(0x0f); //显示光标并闪烁 delay(5); } } } if(0==key1) //第二个键被按下 { delay(5); //消抖 if(0==key1) { while(!key1); //松手检测 flag = 0; if(key0_count==1) { second ++; if(60==second) second = 0; write_add(0x40+10,second); v_W1302(0x80,second); } if(key0_count==2) { minute ++; if(60==minute) minute = 0; write_add(0x40+7,minute); v_W1302(0x82,minute); } if(key0_count==3) { hour ++; if(24==hour) hour = 0; write_add(0x40+4,hour); v_W1302(0x84,hour); } } } if(0==key2) //第三个键被按下 { delay(5); //消抖 if(0==key2) { while(!key2); //松手检测 flag = 0; if(key0_count==1) { second --; if(-1==second) second = 59; write_add(0x40+10,second); v_W1302(0x80,second); } if(key0_count==2) { minute --; if(-1==minute) minute = 59; write_add(0x40+7,minute); v_W1302(0x82,minute); } if(key0_count==3) { hour --; if(-1==hour) hour = 23; write_add(0x40+4,hour); v_W1302(0x84,hour); } } } } //程序初始化函数 void init() { uchar i; flag = 1; hour = 0; minute = 0; second = 0; init1602(); delay(20); //延长时间,确保液晶处于非忙状态 for(i=0;i<14;i++) { write_data_1602(table_date[i]); delay(5); } write_cmd_1602(0x80+0x40+4); //调整地址指针 for (i=0;i<8;i++) { write_data_1602(table_time[i]); delay(5); } delay(50); v_W1302(0x81,25); v_W1302(0x83,48); v_W1302(0x85,10); }
