// File Name : 2440lib.c
// Function : S3C2410 PLL,Uart, LED, Port Init
// Date : March 20, 2002
// Version : 0.0
// History
// 0.0 : Programming start (February 20,2002) -> SOP
#include "def.h"
#include "option.h"
#include "2440addr.h"
#include "2440lib.h"
#include "2440slib.h"
#include
#include
#include
#include
#include
extern char Image$RW$Limit[];
void *mallocPt=Image$RW$Limit;
//***************************[ SYSTEM ]***************************************************
void Delay(int time)
U32 val = (PCLK>>3)/1000-1;
rTCFG0 &= ~(0xff<<8);
rTCFG0 |= 3<<8; //prescaler = 3+1
rTCFG1 &= ~(0xf<<12);
rTCFG1 |= 0<<12; //mux = 1/2
rTCNTB3 = val;
rTCMPB3 = val>>1; // 50%
rTCON &= ~(0xf<<16);
rTCON |= 0xb<<16; //interval, inv-off, update TCNTB3&TCMPB3, start timer 3
rTCON &= ~(2<<16); //clear manual update bit
while(time--) {
while(rTCNTO3>=val>>1);
while(rTCNTO3
//***************************[ PORTS ]****************************************************
void Port_Init0(void)
//CAUTION:Follow the configuration order for setting the ports.
// 1) setting value(GPnDAT)
// 2) setting control register (GPnCON)
// 3) configure pull-up resistor(GPnUP)
//32bit data bus configuration
//*** PORT A GROUP
//Ports : GPA22 GPA21 GPA20 GPA19 GPA18 GPA17 GPA16 GPA15 GPA14 GPA13 GPA12
//Signal : nFCE nRSTOUT nFRE nFWE ALE CLE nGCS5 nGCS4 nGCS3 nGCS2 nGCS1
//Binary : 1 1 1 , 1 1 1 1 , 1 1 1 1
//Ports : GPA11 GPA10 GPA9 GPA8 GPA7 GPA6 GPA5 GPA4 GPA3 GPA2 GPA1 GPA0
//Signal : ADDR26 ADDR25 ADDR24 ADDR23 ADDR22 ADDR21 ADDR20 ADDR19 ADDR18 ADDR17 ADDR16 ADDR0
//Binary : 1 1 1 1 , 1 1 1 1 , 1 1 1 1
rGPACON = 0x7fffff;
//**** PORT B GROUP
//Ports : GPB10 GPB9 GPB8 GPB7 GPB6 GPB5 GPB4 GPB3 GPB2 GPB1 GPB0
//Signal : nXDREQ0 nXDACK0 nXDREQ1 nXDACK1 nSS_KBD nDIS_OFF L3CLOCK L3DATA L3MODE nIrDATXDEN Keyboard
//Setting: INPUT OUTPUT INPUT OUTPUT INPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT
//Binary : 00 , 01 00 , 01 00 , 01 01 , 01 01 , 01 01
rGPBCON = 0x044555;
rGPBUP = 0x7ff; // The pull up function is disabled GPB[10:0]
//*** PORT C GROUP for youlong
//Ports : GPC15 GPC14 GPC13 GPC12 GPC11 GPC10 GPC9 GPC8 GPC7 GPC6 GPC5 GPC4 GPC3 GPC2 GPC1 GPC0
//Signal : VD7 VD6 VD5 VD4 VD3 VD2 VD1 VD0 LCDVF2 LCDVF1 LCDVF0 VM VFRAME VLINE VCLK LEND
//Binary : 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 10
rGPCCON = 0xaaaaaaaa;
rGPCUP = 0xffff; // The pull up function is disabled GPC[15:0]
//*** PORT D GROUP
//Ports : GPD15 GPD14 GPD13 GPD12 GPD11 GPD10 GPD9 GPD8 GPD7 GPD6 GPD5 GPD4 GPD3 GPD2 GPD1 GPD0
//Signal : VD23 VD22 VD21 VD20 VD19 VD18 VD17 VD16 VD15 VD14 VD13 VD12 VD11 VD10 VD9 VD8
//Binary : 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 10 ,10 10
rGPDCON = 0xaaaaaaaa;
rGPDUP = 0xffff; // The pull up function is disabled GPD[15:0]
//*** PORT E GROUP
//Ports : GPE15 GPE14 GPE13 GPE12 GPE11 GPE10 GPE9 GPE8 GPE7 GPE6 GPE5 GPE4
//Signal : IICSDA IICSCL SPICLK SPIMOSI SPIMISO SDDATA3 SDDATA2 SDDATA1 SDDATA0 SDCMD SDCLK IN
//Binary : 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 00 ,
//Ports : GPE3 GPE2 GPE1 GPE0
//Signal : IN IN IN IN
//Binary : 00 00 , 00 00
//rGPECON = 0xaaaaaaaa;
//rGPEUP = 0xffff; // The pull up function is disabled GPE[15:0]
rGPECON = 0xaaaaa800; // For added AC97 setting
rGPEUP = 0xffff;
//*** PORT F GROUP
//Ports : GPF7 GPF6 GPF5 GPF4 GPF3 GPF2 GPF1 GPF0
//Signal : nLED_8 nLED_4 nLED_2 nLED_1 nIRQ_PCMCIA EINT2 KBDINT EINT0
//Setting: Output Output Output Output EINT3 EINT2 EINT1 EINT0
//Binary : 01 01 , 01 01 , 10 10 , 10 10
rGPFCON = 0x55aa;
rGPFUP = 0xff; // The pull up function is disabled GPF[7:0]
//*** PORT G GROUP
//Ports : GPG15 GPG14 GPG13 GPG12 GPG11 GPG10 GPG9 GPG8 GPG7 GPG6
//Signal : nYPON YMON nXPON XMON EINT19 DMAMODE1 DMAMODE0 DMASTART KBDSPICLK KBDSPIMOSI
//Setting: nYPON YMON nXPON XMON EINT19 Output Output Output SPICLK1 SPIMOSI1
//Binary : 11 11 , 11 11 , 10 01 , 01 01 , 11 11
//Ports : GPG5 GPG4 GPG3 GPG2 GPG1 GPG0
//Signal : KBDSPIMISO LCD_PWREN EINT11 nSS_SPI IRQ_LAN IRQ_PCMCIA
//Setting: SPIMISO1 LCD_PWRDN EINT11 nSS0 EINT9 EINT8
//Binary : 11 11 , 10 11 , 10 10
rGPGCON = 0xff95ffba;
rGPGUP = 0xffff; // The pull up function is disabled GPG[15:0]
//*** PORT H GROUP
//Ports : GPH10 GPH9 GPH8 GPH7 GPH6 GPH5 GPH4 GPH3 GPH2 GPH1 GPH0
//Signal : CLKOUT1 CLKOUT0 UCLK nCTS1 nRTS1 RXD1 TXD1 RXD0 TXD0 nRTS0 nCTS0
//Binary
