单片机源程序如下:
//ICC-AVR application builder :
// Target : M16
// Crystal: 8.0000Mhz
#include
#include
//--------------------------------NRF24L01接口定义--------------------------------
//#define NRF24L01_MISO PB4 //输入0
#define Hign_24L01_MISO PORTB |= (1 << PB4)
#define Low_24L01_MISO PORTB &= ~(1 << PB4)
#define Read_24L01_MISO PINB & (1 << PB4)
//#define NRF24L01_MOSI PB2 //输出1
#define Hign_24L01_MOSI PORTB |= (1 << PB2)
#define Low_24L01_MOSI PORTB &= ~(1 << PB2)
#define Read_24L01_MOSI PINB & (1 << PB2)
//#define NRF24L01_CSN PB7 //输出1
#define Low_24L01_CSN PORTB &= ~(1 << PB7)
#define Hign_24L01_CSN PORTB |= (1 << PB7)
//#define NRF24L01_SCK PB6 //输出1
#define Hign_24L01_SCK PORTB |= (1 << PB6)
#define Low_24L01_SCK PORTB &= ~(1 << PB6)
#define Read_24L01_SCK PINB & (1 << PB6);
//#define NRF24L01_CE PB5 //输出1
#define Hign_24L01_CE PORTB |= (1 << PB5)
#define Low_24L01_CE PORTB &= ~(1 << PB5)
#define Read_24L01_CE PINB & (1 << PB5)
//#define NRF24L01_IRQ PB3 //输入
#define Hign_NRF24L01_IRQ PORTB |= (1 << PB3)
#define Low_NRF24L01_IRQ PORTB &= ~(1 << PB3)
#define Read_NRF24L01_IRQ PINB & (1 << PB3)
//------------------------------数码管位选--------------------------------------
//#define Display1 PA1 //输出1
#define Hign_Display1 PORTA |= (1 << PA1);
#define Low_Display1 PORTA &= ~(1 << PA1);
//#define Display2 PA2 //输出1
#define Hign_Display2 PORTA |= (1 << PA2);
#define Low_Display2 PORTA &= ~(1 << PA2);
//#define Display3 PA3 //输出1
#define Hign_Display3 PORTA |= (1 << PA3);
#define Low_Display3 PORTA &= ~(1 << PA3);
//#define Display4 PA4 //输出1
#define Hign_Display4 PORTA |= (1 << PA4);
#define Low_Display4 PORTA &= ~(1 << PA4);
//-------------------------------BELL蜂明器-------------------------------------
#define Hign_BELL PORTD |= (1 << PD5)
#define Low_BELL PORTD &= ~(1 << PD5)
//-------------------------------JDQ继电器--------------------------------------
#define Hign_JDQ PORTD |= (1 << PD7)
#define Low_JDQ PORTD &= ~(1 << PD7)
//***********************************数码管0-9编码*******************************************
char seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段码
char TxBuf[32]=
0x01,0x02,0x03,0x4,0x05,0x06,0x07,0x08,
0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16,
0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24,
0x25,0x26,0x27,0x28,0x29,0x30,0x31,0x32,
char sta,tf,KEY0;
//*********************************************NRF24L01*************************************
#define TX_ADR_WIDTH 5 // 5 uints TX address width
#define RX_ADR_WIDTH 5 // 5 uints RX address width
#define TX_PLOAD_WIDTH 32 // 20 uints TX payload
#define RX_PLOAD_WIDTH 32 // 20 uints TX payload
char TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址
char RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址
//***************************************NRF24L01寄存器指令*******************************************************
#define READ_REG 0x00 // 读寄存器指令
#define WRITE_REG 0x20 // 写寄存器指令
#define RD_RX_PLOAD 0x61 // 读取接收数据指令
#define WR_TX_PLOAD 0xA0 // 写待发数据指令
#define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令
#define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令
#define REUSE_TX_PL 0xE3 // 定义重复装载数据指令
#define NOP1 0xFF // 保留
//*************************************SPI(nRF24L01)寄存器地址****************************************************
#define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式
#define EN_AA 0x01 // 自动应答功能设置
#define EN_RXADDR 0x02 // 可用信道设置
#define SETUP_AW 0x03 // 收发地址宽度设置
#define SETUP_RETR 0x04 // 自动重发功能设置
#define RF_CH 0x05 // 工作频率设置
#define RF_SETUP 0x06 // 发射速率、功耗功能设置
#define STATUS 0x07 // 状态寄存器
#define OBSERVE_TX 0x08 // 发送监测功能
#define CD 0x09 // 地址检测
#define RX_ADDR_P0 0x0A // 频道0接收数据地址
#define RX_ADDR_P1 0x0B // 频道1接收数据地址
#define RX_ADDR_P2 0x0C // 频道2接收数据地址
#define RX_ADDR_P3 0x0D // 频道3接收数据地址
#define RX_ADDR_P4 0x0E // 频道4接收数据地址
#define RX_ADDR_P5 0x0F // 频道5接收数据地址
#define TX_ADDR 0x10 // 发送地址寄存器
#define RX_PW_P0 0x11 // 接收频道0接收数据长度
#define RX_PW_P1 0x12 // 接收频道0接收数据长度
#define RX_PW_P2 0x13 // 接收频道0接收数据长度
#define RX_PW_P3 0x14 // 接收频道0接收数据长度
#define RX_PW_P4 0x15 // 接收频道0接收数据长度
#define RX_PW_P5 0x16 // 接收频道0接收数据长度
#define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置
void Delay(int s);
void inerDelay_us(char n);
void init_NRF24L01(void);
char SPI_RW(char data);
char SPI_Read(char reg);
char SPI_RW_Reg(char reg, char value);
char SPI_Read_Buf(char reg, char *pBuf, char uchars);
char SPI_Write_Buf(char reg, char *pBuf, char uchars);
void SetRX_Mode(void);
char nRF24L01_RxPacket(char* rx_buf);
void nRF24L01_TxPacket(char * tx_buf);
//*****************************************长延时*****************************************
void Delay(int s)
unsigned int i;
for(i=0; i
for(i=0; i
/*延时函数
void iner
