- #include
- #define uchar unsigned char
- #define uint unsigned int
- #define rs_h (PORTC|=0x01)
- #define rs_l (PORTC&=0xfe)
- #define rs_o (TRISC&=0xfe)
- #define rw_h (PORTC|=0x02)
- #define rw_l (PORTC&=0xfd)
- #define rw_o (TRISC&=0xfd)
- #define en_h (PORTC|=0x04)
- #define en_l (PORTC&=0xfb)
- #define en_o (TRISC&=0xfb)
- #define temp_h (PORTC|=0x08)
- #define temp_l (PORTC&=0xf7)
- #define temp_o (TRISC&=0xf7)
- #define temp_i (TRISC|=0x08)
- #define led_o (TRISC&=0xef)
- #define led_l (PORTC&=0xef)
- #define led_h (PORTC|=0x10)
- #define LCD PORTB
- uchar dat1,dat2;//保存读出的温度z
- unsigned long int dat;
- void delayms(uint x) //4M晶振下,延时1ms
- uint y,z;
- for(y=x;y>0;y--)
- for(z=110;z>0;z--);
- void Ds18b20_reset(void)//DS18B20初始化
- uint count;
- uchar i,flag=1;
- temp_o;
- temp_l;
- for(count=60;count>0;count--);//延时480us
- temp_i;
- while(flag)
- if(RC3)
- flag=1;
- else
- flag=0;
- led_o;
- led_l;//开指示灯
- void Ds18b20_write(uchar datt)//向DS18B20写一个字节
- uchar count;
- uchar i;
- temp_o;
- for(i=8;i>0;i--)
- temp_o;
- temp_l;
- for(count=1;count>0;count--);
- if(datt&0x01==0x01)
- temp_i;
- else
- temp_o;
- temp_l;
- for(count=23;count>0;count--);//延时60us
- temp_i;
- datt>>=1;
- uchar Ds18b20_read(void) //从DS18B20读一个字节
- uchar i,datt;
- uchar count;
- for(i=8;i>0;i--)
- datt>>=1;
- temp_o;
- temp_l;
- temp_i;//改为输入方向时,上拉电阻把数据线拉高,释放总线,此语句必须有,参考datasheet的P15
- if(RC3)
- datt|=0x80;
- return datt;
- void lcd_com(uchar com)//向LCD1602写命令
- rs_o;
- rw_o;
- en_o;
- TRISB=0x00;//配置RB为输出方向
- rs_l;
- rw_l;
- LCD=com;
- delayms(1);
- en_h;
- delayms(1);
- en_l;
- delayms(1);
- void lcd_dat(uchar dat)//向LCD1602写数据
- rs_o;
- rw_o;
- en_o;
- rs_h;
- rw_l;
- LCD=dat;
- delayms(1);
- en_h;
- delayms(1);
- en_l;
- delayms(1);
- void lcd_write(uchar c,uchar r,uchar dat)//向LCD1602指定行、指定列、写数据
- lcd_com(0x80+0x40*c+r);
- lcd_dat(dat);
- delayms(1);
- void lcd_init(void)//LCD1602初始化,初始化后第一行显示temperature:,第二行显示.C
- lcd_com(0x38);
- lcd_com(0x0c);
- lcd_com(0x06);
- lcd_write(0,2,0x54);
- lcd_write(0,3,0x65);
- lcd_write(0,4,0x6d);
- lcd_write(0,5,0x70);
- lcd_write(0,6,0x65);
- lcd_write(0,7,0x72);
- lcd_write(0,8,0x61);
- lcd_write(0,9,0x74);
- lcd_write(0,10,0x75);
- lcd_write(0,11,0x72);
- lcd_write(0,12,0x65);
- lcd_write(0,13,0x3a);
- lcd_write(1,11,0xdf);
- lcd_write(1,12,0x43);
- void show(void)//把温度值送LCD1602显示
- uchar flag;
- uchar t[4];
- uint temp;
- if(dat2>=240)
- dat= (~(dat2*256+dat1)+1)*(0.0625*10);//取反加一,保留一位小数
- flag=1;
- else
- dat=(dat2*256+dat1)*(0.0625*10);
- flag=0;
- temp=dat%10;
- t[0]=(0x30+temp);
- temp=dat%100;
- temp=temp/10;
- t[1]=(0x30+temp);
- temp=dat%1000;
- temp=temp/100;
- t[2]=(0x30+temp);
- temp=dat/1000;
- t[3]=(0x30+temp);
- if(flag==1)//负温度显示
- lcd_write(1,10,t[0]);
- lcd_write(1,9,0xa5);
- lcd_write(1,8,t[1]);
- lcd_write(1,7,t[2]);
- lcd_write(1,6,t[3]);
- lcd_write(1,5,0x2d);
- if(flag==0)//正温度显示
- lcd_write(1,5,0x20);//显示空格,刷掉负号
- void main(void)
- lcd_init();
- while(1)
- Ds18b20_reset();
- Ds18b20_write(0xcc);
- Ds18b20_write(0x44);//发送温度转换命令
- delayms(1000);//延时1s,等待温度转换完成
- Ds18b20_reset();
- Ds18b20_write(0xbe);//发送读温度寄存器命令
- dat1=Ds18b20_read();
- dat2=Ds18b20_read();
- show();
- led_h;//关指示灯
- delayms(2000);
- //调试总结:
- //某IO口8位未全使用时,对整个IO口读取进行位运算无效
关键字:PIC16F877A 温度DS18B20 『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
